Deathwing - 2000pts (Double Vanguard)
GenerationTerrorist
I don't think Battlescribe has worked out the Command Points correctly. But here goes my first attempt for a 9th Edition Deathwing list.
++ Vanguard Detachment -3CP (Imperium - Adeptus Astartes - Dark Angels) [49 PL, 10CP, 1,055pts] ++
+ Configuration +
**Chapter Selection**: Dark Angels
Battle Size [12CP]: 3. Strike Force (101-200 Total PL / 1001-2000 Points)
Detachment Command Cost [-3CP]
+ HQ +
Azrael [8 PL, 2CP, 170pts]: 1. Brilliant Strategist, Warlord
Ezekiel [7 PL, 125pts]: 1) Mind Worm, 2) Aversion, 3) Righteous Repugnance
+ Elites +
Deathwing Ancient [6 PL, 125pts]: Chapter Command: Chapter Ancient, Lightning Claw (Pair), Pennant of Remembrance
Deathwing Apothecary [6 PL, -1CP, 115pts]: Chapter Command: Chief Apothecary, Selfless Healer, Stratagem: Hero of the Chapter
Deathwing Champion [4 PL, 80pts]
Deathwing Terminator Squad [18 PL, 440pts]: Watcher in the Dark
. Deathwing Sergeant
. . Thunder Hammer & Storm Shield: Thunder hammer
. Deathwing Terminator
. . Cyclone Missile Launcher, Storm Bolter, Chainfist: Chainfist, Cyclone missile launcher
. . Storm Bolter & Power Fist: Power fist
++ Vanguard Detachment -3CP (Imperium - Adeptus Astartes - Dark Angels) [47 PL, -3CP, 945pts] ++
+ Configuration +
+ HQ +
Belial [7 PL, 140pts]
. Sword of Silence & Storm Bolter
+ Elites +
Contemptor Dreadnought [9 PL, 165pts]: Multi-melta, Rites of Initiation
Deathwing Knights [22 PL, 475pts]: Knight Master, Watcher in the Dark
. 9x Deathwing Knight: 9x Mace of Absolution, 9x Storm shield
++ Total: [96 PL, 7CP, 2,000pts] ++
Created with BattleScribe
https://bolterandchainsword.com/topic/369052-deathwing-2000pts-double-vanguard/
Ok, question: are you running double vanguard because you want to run Azrael+Bel+Ezy?
In any case if I had to say I'd drop a few DWK for a 5 man DW termies ( you'd need a couple of points, maybe from the chainfist), because 10 obsec troops are a bit few imho.
  • 2 weeks later...
I also think Belial is redundant when you already have Azrael in the list. I'm also going to point out the Deathwing Champion, while cool in concept, really isn't bringing much to the table when you have so much beatdown capability in this list. I would field maybe 1 Dreadnought with long-range weapons as a backfield objective holder and use the points from Belial, the Champion, and the other Dread to field a couple 5-man Terminator Squads, just with the basic equipment, to give you something to deep strike to disrupt your opponents' backlines.
