Styles Posted February 24, 2021 Share Posted February 24, 2021 If I am playing a 2,000pt Grand Tournament 2020 game is the maximum number of canoptek plasmacytes i can have 3, even if I have over 3 destroyer units? As the rules for a game that size seem to say you can only have the same datasheet 3 times. Does the viral construct rule allow more? As it is not clear to me it does over rule the 3 datasheet rule, although I think that is what it is meant to do? Link to comment https://bolterandchainsword.com/topic/369227-canoptek-plasmacyte-maximum-question/ Share on other sites More sharing options...
Emicus Posted February 25, 2021 Share Posted February 25, 2021 (edited) Interesting question regarding GWs uniform rules writing. Cherubs and watchers in the dark are models with stats, no separate datasheet, counted as unit upgrades. Plasmacyte is a stand-alone unit upgrade and AFAIK can't be taken without destroyers anyway? Reason doesn't stand, not after their latest 'movement modifiers don't modify movement distance' mind puzzle. Tldr: better safe than sorry, max3? Although you bring a lot of destroyers! Edited February 25, 2021 by Emicus Styles 1 Back to top Link to comment https://bolterandchainsword.com/topic/369227-canoptek-plasmacyte-maximum-question/#findComment-5671079 Share on other sites More sharing options...
Styles Posted March 1, 2021 Author Share Posted March 1, 2021 Thanks for your thoughts. I think GW did mean that you could have a plasmacyte per destroyer unit, but messed up the rules, as I think technically I could only have 3, so plan to do that. Bit annoying though as i am making a destroyer themed army and maxing out on destroyer units. Link to comment https://bolterandchainsword.com/topic/369227-canoptek-plasmacyte-maximum-question/#findComment-5672780 Share on other sites More sharing options...
Mandragola Posted March 6, 2021 Share Posted March 6, 2021 It doesn’t look like there’s anything in the plasmacyte’s rules to override the rule of three I’m afraid. The Viral construct rule does two things: makes them not take up a slot and prevents you from taking more of these guys than you have destroyer units. Link to comment https://bolterandchainsword.com/topic/369227-canoptek-plasmacyte-maximum-question/#findComment-5675041 Share on other sites More sharing options...
