TheUnlikelyGamer84 Posted June 8, 2021 Share Posted June 8, 2021 I plan on adding a vindicare to my army. Is the stratagem “priority threat neutralized” limited to once per phase? In theory if I use the “double kill” stratagem and kill two characters I could use it to generate 2-3cp. Link to comment https://bolterandchainsword.com/topic/370596-vindicare-assassin/ Share on other sites More sharing options...
sairence Posted June 8, 2021 Share Posted June 8, 2021 Unless you have a rule specifically saying otherwise, all strats are limited to once per phase. The most common exception you'd see would go in another direction, limiting the use further to once per game. Pretty sure nothing like that exists for this one though. Link to comment https://bolterandchainsword.com/topic/370596-vindicare-assassin/#findComment-5708253 Share on other sites More sharing options...
Karhedron Posted June 8, 2021 Share Posted June 8, 2021 Not only is the stratagem once per phase but the matched play rules limiting you to generating only 1 bonus CP per turn so there would be no point in playing it, even if it were allowed. Link to comment https://bolterandchainsword.com/topic/370596-vindicare-assassin/#findComment-5708285 Share on other sites More sharing options...
sairence Posted June 8, 2021 Share Posted June 8, 2021 Not only is the stratagem once per phase but the matched play rules limiting you to generating only 1 bonus CP per turn so there would be no point in playing it, even if it were allowed. There's an exception for certain strategems I think, should be in the rare rules. So you can get your D3 CP from this. Link to comment https://bolterandchainsword.com/topic/370596-vindicare-assassin/#findComment-5708311 Share on other sites More sharing options...
Xenith Posted June 9, 2021 Share Posted June 9, 2021 Not only is the stratagem once per phase but the matched play rules limiting you to generating only 1 bonus CP per turn so there would be no point in playing it, even if it were allowed. As per above, 'passive' CP recovery is one per turn, but things like stratagems which return CP are not bound by this. OP, it's in the core rules that stratagems are one use per phase. Link to comment https://bolterandchainsword.com/topic/370596-vindicare-assassin/#findComment-5708682 Share on other sites More sharing options...
