yan Posted July 6, 2021 Share Posted July 6, 2021 Here I am again, just trying to learn 9th correctly. So can you stack light cover bonuses? For example my Eliminators with their camo-cloaks receive the benefit of being in light cover (+1 save). does that mean that if I put them actually in light cover terrain they get +2 on their saves? Thanks! XeonDragon 1 Back to top Link to comment https://bolterandchainsword.com/topic/370925-stacking-light-cover/ Share on other sites More sharing options...
Closet Skeleton Posted July 6, 2021 Share Posted July 6, 2021 Camo-cloaks don't work that way. They give +1 save when they're in cover which stacks to +2 but does nothing in open ground. yan and Cruor Vault 2 Back to top Link to comment https://bolterandchainsword.com/topic/370925-stacking-light-cover/#findComment-5717119 Share on other sites More sharing options...
yan Posted July 6, 2021 Author Share Posted July 6, 2021 Camo-cloaks don't work that way. They give +1 save when they're in cover which stacks to +2 but does nothing in open ground. a yea your right! thanks thats helpfull. But then still my question stands. but with another example: My space wolves librarian casts stromcaller, witch gives the units within 6" of the librarian the benefit of light cover (+1 save). Does that mean they get +2 on their save's if they are actually in cover of a terrain piece and are within 6" of the lib? Link to comment https://bolterandchainsword.com/topic/370925-stacking-light-cover/#findComment-5717138 Share on other sites More sharing options...
Lord Raven 19 Posted July 6, 2021 Share Posted July 6, 2021 No, I don't believe so. Link to comment https://bolterandchainsword.com/topic/370925-stacking-light-cover/#findComment-5717145 Share on other sites More sharing options...
Khulu Posted July 14, 2021 Share Posted July 14, 2021 A bit late here, but Lord Raven is correct. Being in cover gives you the benefit of light cover, so from a rules perspective they're saying the same thing, so it does not stack. Link to comment https://bolterandchainsword.com/topic/370925-stacking-light-cover/#findComment-5719776 Share on other sites More sharing options...
Xenith Posted July 14, 2021 Share Posted July 14, 2021 (edited) The wording of Camo Cloaks is pretty specific: Each time a ranged attack is allocated to the bearer while it is receiving the benefits of cover, add an additional 1 to any armour saving throw made against that attack. Light cover doesn't stack with other light cover, but does with dense/heavy etc. As per above, your reading of the rule is slightly incorrect, cloaks dont give the benefit of light cover, ut enhance the effect of any light cover bonus the model already gets. As such, this will be triggered by Stormcaller, and other effects which make the models count as if they were in light cover such as the Raven Guard or 'Stealthy' Chapter Tactics. Edited July 14, 2021 by Xenith Link to comment https://bolterandchainsword.com/topic/370925-stacking-light-cover/#findComment-5719829 Share on other sites More sharing options...
