Lord Raven 19 Posted August 3, 2021 Share Posted August 3, 2021 My pot of Armageddon dust is running low and I have heard that vallejo texture pastes are much better value for money. Does anyone know which one is most similar in texture and colour to Armageddon dust (which is very similar to zandri dust btw), or have a conversion chart between the two brands that includes texture pastes? Thanks. Link to comment https://bolterandchainsword.com/topic/371186-vallejo-gw-texture-paste-comparisons/ Share on other sites More sharing options...
Imren Posted August 3, 2021 Share Posted August 3, 2021 A quick search suggests these two: 26.217 Desert sand 26.810 Light brown mud I suspect Desert sand is the closest. I strongly suggest you visit your FLGS and take a pot of GW armageddon dust and Vallejo desert sand and compare them side-by-side looking at the pot bottoms. Link to comment https://bolterandchainsword.com/topic/371186-vallejo-gw-texture-paste-comparisons/#findComment-5726077 Share on other sites More sharing options...
Firedrake Cordova Posted August 4, 2021 Share Posted August 4, 2021 (edited) You probably want to have a look at this Reddit thread and blog post: https://www.reddit.com/r/wargaming/comments/eymfpn/vallejo_basing_paste_sample_comparison_thick/ http://plastickrak.blogspot.com/2013/12/vallejo-modelling-pastes.html Probably Desert Sand is closest in colour, although obviously you can paint over it to get any colour you want. The Vallejo texture pastes are more for reproducing a "realistic" texture, so the texture is not as coarse as the GW ones (i.e. they use finer sand). ++EDIT: In my experience, Vallejo texture pastes are "stickier" than GW ones, so have a tendency to make "peaks" a bit like icing. Personally, I decant some onto a pallet, thin it a bit to reduce the stickiness, and mix in some modelling sand to give a less uniform texture. Edited August 4, 2021 by Firedrake Cordova cretacianborn, Azekai, Lord Marshal and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/371186-vallejo-gw-texture-paste-comparisons/#findComment-5726560 Share on other sites More sharing options...
Khulu Posted August 6, 2021 Share Posted August 6, 2021 I like using Vallejo "Rough White Pumice" and then slapping contrast over it. Iyanden Yellow might be a good match but I don't know if it is. Link to comment https://bolterandchainsword.com/topic/371186-vallejo-gw-texture-paste-comparisons/#findComment-5726960 Share on other sites More sharing options...
Firedrake Cordova Posted August 6, 2021 Share Posted August 6, 2021 Iyanden Yellow might be a good match but I don't know if it is. I'd have thought Aggaros Dunes was a better match (Iiyanden Yellow is very yellow/orange, Aggaros Dunes is more of a brown) :) Khulu 1 Back to top Link to comment https://bolterandchainsword.com/topic/371186-vallejo-gw-texture-paste-comparisons/#findComment-5727042 Share on other sites More sharing options...
Khulu Posted August 6, 2021 Share Posted August 6, 2021 (edited) I haven't used zandri dust so you are likely right, Iyanden is just the one I use to get yellow desert Edit: Not zandri dust, not sure where I got that from. Aggaros Dunes Edited August 6, 2021 by Nemesor Tyriks Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/371186-vallejo-gw-texture-paste-comparisons/#findComment-5727115 Share on other sites More sharing options...
Lord Raven 19 Posted August 6, 2021 Author Share Posted August 6, 2021 Thanks everyone, I think the desert sand sounds best. I have some modelling sand, so I might mix some of that in to adjust the texture, thanks for the tip Cordova. If the colour is too far off, I can always just paint it with zandri dust. Khulu 1 Back to top Link to comment https://bolterandchainsword.com/topic/371186-vallejo-gw-texture-paste-comparisons/#findComment-5727158 Share on other sites More sharing options...
