Banks Posted February 8, 2022 Share Posted February 8, 2022 (edited) Can someone with leaks or access to those with leaks tell us what the NL legion trait will be? I can only pray it is not about leadership or morale phase. It is such a useless trait and it never works. Praying we get something that actually is useful in games. http://www.bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/?p=5790824 thanks. So looking at this: NL -2LD & -1CA @ 9'' +1 to advance & +1 to charges Wanton Slaughter: When using a pistol/assault/melee vs below half strenght unit or LD 6 and below = +1 to wound (Super doctrine) I'm guessing -1CA at 9 inches is -1 to combat attrition. Once again NL are stuck with a mechanic that simply does not work. Morale checks are either too broken to make the game not fun for the other player or the opposing player simply ignores it which means your special unique gimmick is worthless. Is the -2LD stackable like it currently is? Even then, you have to risk getting your units close enough to trigger it and for 2 CP you just auto pass morale anyways. I like the +1 to advance and charge, very fitting with the legion. The +1 to wound is also nice. You are looking its usage all wrong. It no longer about forcing the enemy to fail a moral test and cause fleeing, but its about lowering leadership to gain consistent buffs. Getting most armies down to 6ld will be easy with -2 LD,which is NOT going to be stackable. But what that means that you can spread this debuff out a bit better,especially with Raptors who will be a -3LD on their own, so almost always getting that +1 to wound, except vs Custodes and Necrons. The -1 CA(Combat Attrition) is just kind of a cherry on top. Going back to the -2 LD and the +1 Wound, means things like Bale Flamers will be auto-hitting and wounding on 2+s for a lot of units, which seems quite attractive to me. This is a big buff to our legion trait in my opinion I'd also like to add, that forcing someone to spend 2 CP just to ignore a single morale test, that to me seems pretty worth it as well. Thats CP that could have been 2 failed re-rolls, or important buffs later on. Edited February 8, 2022 by Banks Iron Father Ferrum, Grand_Master_Alpharius, dice4thedicegod and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794583 Share on other sites More sharing options...
Bulwyf Posted February 8, 2022 Share Posted February 8, 2022 When everything else about their traits encourages charging, having an element that only works when you're close to the enemy isn't a bug, it's a feature. As for the "you can just auto-pass" argument, I have two countervailing considerations. First, make them spend those CPs -- it's less they can use on something else. Second, that strat can be used on one unit once per phase, whereas your trait will affect every enemy unit in range in every morale phase. Spread the love enough to trigger multiple checks and force your opponent to make tough decisions on which unit to spend those CPs on. I can't spend CP to turn off BT 5++ army rules. I can't spend CP to turn off other armies army special rules. But for two CP I can turn off NL's special rules. And let's be honest, it is highly unlikely you will be needing that on more than one unit per phase. No one cares if a squad of Intercessors runs but I will absolutely use it on BGV to keep them there. Same thing for other armies. I'll quote this: It disproportionally affects larger units (thus promoting MSU) by making them not only more likely to take higher losses, but more likely to take losses at all. Many units can simply skip the entire phase by being small, 3 man units with LD 8 effectively ignore morale, while 5 man units with good LD are almost never affected. It’s been poorly implemented in books, with very few things playing into the rules and many armies having next to no bonus, positive or negative. Whole armies are effectively immune. Even when it has an effect, it tends to be a very minor one with a handful of models at best being lost. It’s next to impossible to destroy a unit with morale. Due to its often minor effects, it’s better to just wipe units out with overwhelming firepower, which in turn leads to fewer morale checks and it having less effect. Source: https://www.belloflostsouls.net/2021/09/warhammer-40k-how-to-fix-9th-editions-worst-part-morale.html This sums up much of my problems with morale phase/leadership shenanigans. It doesn't work. Some armies are effectively immune to it. Someone said the -2 LD debuff no longer will stack. Great. So unless I am playing Orks (which I just did this weekend against a friend and actually won with my NL because he had units wrecked by LD debuffs) I'm really having a hard go at it. As I said, I like the +1 to advance and charge. At least my trait will give me something as NL besides an effectively useless morale gimmick. +1 to wound for LD 6 or lower for melee? That's cool. Even with most SM armies I can get to that and get +1 to wound plus using LC which is fluffy for NL I can also reroll the wound rolls. So it definitely is a better legion trait than what we have in our dinosaur 8th edition codex. But the problems with morale phase/armies being effectively immune to morale checks still remain. Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794592 Share on other sites More sharing options...
techsoldaten Posted February 8, 2022 Share Posted February 8, 2022 thanks. So looking at this: NL -2LD & -1CA @ 9'' +1 to advance & +1 to charges Wanton Slaughter: When using a pistol/assault/melee vs below half strenght unit or LD 6 and below = +1 to wound (Super doctrine) I'm guessing -1CA at 9 inches is -1 to combat attrition. Once again NL are stuck with a mechanic that simply does not work. Morale checks are either too broken to make the game not fun for the other player or the opposing player simply ignores it which means your special unique gimmick is worthless. Is the -2LD stackable like it currently is? Even then, you have to risk getting your units close enough to trigger it and for 2 CP you just auto pass morale anyways. I like the +1 to advance and charge, very fitting with the legion. The +1 to wound is also nice. You are looking its usage all wrong. It no longer about forcing the enemy to fail a moral test and cause fleeing, but its about lowering leadership to gain consistent buffs. Getting most armies down to 6ld will be easy with -2 LD,which is NOT going to be stackable. But what that means that you can spread this debuff out a bit better,especially with Raptors who will be a -3LD on their own, so almost always getting that +1 to wound, except vs Custodes and Necrons. The -1 CA(Combat Attrition) is just kind of a cherry on top. Going back to the -2 LD and the +1 Wound, means things like Bale Flamers will be auto-hitting and wounding on 2+s for a lot of units, which seems quite attractive to me. This is a big buff to our legion trait in my opinion I'd also like to add, that forcing someone to spend 2 CP just to ignore a single morale test, that to me seems pretty worth it as well. Thats CP that could have been 2 failed re-rolls, or important buffs later on. Night Lords are not my army, but there's a lot to like about this Legion Trait. 9" auras cover a large part of the board. Deep striking melee units with +1 to charge / wound could deny objectives better than most other units in the game. Ranged shooting on demoralized units could stop opponents from achieving primaries. I don't think you try to table anyone with Night Lords, instead you make it impossible for them to win. And not many people prepare for that style of play. WrathOfTheLion and Iron Father Ferrum 2 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794605 Share on other sites More sharing options...
Toldavf Posted February 8, 2022 Share Posted February 8, 2022 In regards to the NL trait, it is defiantly stronger vs some armies than against others I might even go as far to say that the variance ranges from doing nothing all the way to being absolutely crippling. The +1 to wound is tasty and easy enough to get vs a number of armies. Really though what will define it's strength is the other synergies that are available, I'm thinking warlord traits, relics, strats and paid for upgrades if there is even a little synergy it will become much stronger. Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794621 Share on other sites More sharing options...
MegaVolt87 Posted February 8, 2022 Share Posted February 8, 2022 (edited) Can someone with leaks or access to those with leaks tell us what the NL legion trait will be? I can only pray it is not about leadership or morale phase. It is such a useless trait and it never works. Praying we get something that actually is useful in games. http://www.bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/?p=5790824 thanks. So looking at this: NL -2LD & -1CA @ 9'' +1 to advance & +1 to charges Wanton Slaughter: When using a pistol/assault/melee vs below half strenght unit or LD 6 and below = +1 to wound (Super doctrine) I'm guessing -1CA at 9 inches is -1 to combat attrition. Once again NL are stuck with a mechanic that simply does not work. Morale checks are either too broken to make the game not fun for the other player or the opposing player simply ignores it which means your special unique gimmick is worthless. Is the -2LD stackable like it currently is? Even then, you have to risk getting your units close enough to trigger it and for 2 CP you just auto pass morale anyways. I like the +1 to advance and charge, very fitting with the legion. The +1 to wound is also nice. Erm... Many SM units top out at 8 Ld, so they will be 6 Ld in melee so you will be using the super doctrine quite a bit. Ditto against many other things. You don't need a Ld check to proc the super doctrine, just the Ld at 6 to proc. EDIT- also good, burning CP on that ignore LD is good less points to use on better strats like transhuman, honour the chapter etc. Edited February 8, 2022 by MegaVolt87 Iron Father Ferrum, WrathOfTheLion and Khornestar 3 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794656 Share on other sites More sharing options...
Grand_Master_Alpharius Posted February 9, 2022 Share Posted February 9, 2022 Can someone with leaks or access to those with leaks tell us what the NL legion trait will be? I can only pray it is not about leadership or morale phase. It is such a useless trait and it never works. Praying we get something that actually is useful in games. http://www.bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/?p=5790824 thanks. So looking at this: NL -2LD & -1CA @ 9'' +1 to advance & +1 to charges Wanton Slaughter: When using a pistol/assault/melee vs below half strenght unit or LD 6 and below = +1 to wound (Super doctrine) I'm guessing -1CA at 9 inches is -1 to combat attrition. Once again NL are stuck with a mechanic that simply does not work. Morale checks are either too broken to make the game not fun for the other player or the opposing player simply ignores it which means your special unique gimmick is worthless. Is the -2LD stackable like it currently is? Even then, you have to risk getting your units close enough to trigger it and for 2 CP you just auto pass morale anyways. I like the +1 to advance and charge, very fitting with the legion. The +1 to wound is also nice. "I like the +1 to advance and charge, very fitting with the legion. The +1 to wound is also nice. " Dude, this is totally the bit you should be focusing on, +1 to wound on most marines (and by proxy this is pretty much everything in the game) in pretty much any situation is awesome! Afterall, you don't need to worry about attrition, if they're all dead. Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794673 Share on other sites More sharing options...
WrathOfTheLion Posted February 9, 2022 Share Posted February 9, 2022 (edited) An extra +1 to wound will work on almost all SM with a little diminishing returns. Deathwing with their permanent transhuman and auto pass morale tests will basically hard counter that part of the Night Lords shenanigans (very fitting in the historical conflict with each other), but everything else is open season. SM taking the minor transhuman (1-2 always fail to wound) will keep anything S5 and up from becoming a 2+ to wound, but also if the SM players doing successor tactics choose that, they didn't choose something else. Oh man, if I wasn't priming these dudes I'm working on as Red Corsairs, they would be Night Lords. Will have to wait until next time. Edited February 9, 2022 by WrathOfTheLion Iron Father Ferrum 1 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794675 Share on other sites More sharing options...
Marshal Loss Posted February 9, 2022 Author Share Posted February 9, 2022 Worth noting that "Insane Bravery" is a once per battle not a once per phase stratagem, and forcing your opponent to blow it early can have massive ramifications later on in the game. RolandTHTG, TheGodOfHammers, Cheex and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794681 Share on other sites More sharing options...
Toldavf Posted February 9, 2022 Share Posted February 9, 2022 (edited) A question to those who are interested. We are starting to see some rules that ignore fnp and wound gating, when will we see something that ignores transhuman like effects? Edited February 9, 2022 by Toldavf Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794698 Share on other sites More sharing options...
Clockworkchris Posted February 9, 2022 Share Posted February 9, 2022 I play night lords competively, and as others have said you do not aim to table with them. Their whole kit is aimed at disruption tactics. which is very lore friendly, being the guys that use dirty tricks. The way to win in 8th edition is knowing the ennemies gameplan, surgically removing key units and using stratagems to disrupt the ennemies phases. Everything down to my list is a trick, you can look at my typical competitive list and not know what the frack my list is suppose to do. Also every unit in my list follows the Xanatos principle, so even when i fail, I suceed. MegaVolt87, techsoldaten, SanguinaryGuardsman and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794701 Share on other sites More sharing options...
Clockworkchris Posted February 9, 2022 Share Posted February 9, 2022 Update post CSM doctrine: Similar to SM Doctrine, except exploding 6s (unmodified hits) instead of +1AP. Still 3 levels that affefct different weapons (the weapons listed below are not confirmed by my sources, but the ones in the legion traits are confirmed by my sources as well as the names, so what I am about to list may be subject to change) Destruction ''Doctrine'': Heavy/grenade Massacre ''Doctrine'': Rapid fire/assault Slaughter ''Doctrine'': pistol/melee Marks: Can only be applied to CORE & CHARACTERSIcons: (purchaseable upgrade) vengeance +1 CA wrath +1ap melee flame +1ap shooting excess +1 to hit melee despair 6s to hit = autowound ''Daemonic Gifts'': (purchaseable upgrade) Khorne: +1S on the charge Nurgle: -1 to wound Tzeentch: ignore all damage on first missed save Slaanesh: fight first in the fight phase All legions are getting 6 WT, 8 relics & 8 stratagems each (seems to be a lot from F&F but with some tweaks) Each chaos god is getting a couple stratagems, 1 relic & 1 daemon weapon each Legion rule: NL -2LD & -1CA @ 9'' +1 to advance & +1 to charges Wanton Slaughter: When using a pistol/assault/melee vs below half strenght unit or LD 6 and below = +1 to wound (Super doctrine) WLT 6" aura that cancels obsec Relics Jump pack: moving over or charging units causes d3 MW on a 2+ Stratagems Vox scream: cancels AURAS Jump pack DS turn 1 IW Ignores cover Reduce ap1/2 by 1 Wanton Destruction: Heavy/grenade vs vehicules/buildings/units in cover = +1 to wound (Super doctrine) WLT Some way to give +1 damage to certain units WB Charges/HI = reroll hits 5+++ vs MW Wanton Slaughter: When using a pistol/assault/melee = 6s to wound cause 1MW (capped @ 3MW per unit) (Super doctrine) BL ignore CA +1 to hit when charge or shoot closest unit Wanton Massacre: rapid fire/assault/pistol = exploding 5s (hit) (Super doctrine) Alpha legion -1 to hit 12" away, if wounds are 10+ then it's 18" Can charge and perform actions if they fell back Wanton massacre (super doctrine):Rapid fire, assault, pistol if within half range +1 ap Emperor's children Ignore any/all negative modifiers to ws / bs Any attack on a 6 to wound +1ap wanton slaughter (super doctrine): Melee hits on a 6 gives additional hit, combine this with the slaughter bonus and you'd get 2 additional hits on 6 Side note, this matches up with a 4chan leak that said TH chosen could hit on 2s with EC (legion trait+icon of excess) Red corsairs Charge if they advanced Models count as 2 for obsec; Models with 10+ wounds count as 5 wanton destruction (super doctrine): Heav, rapid, grenade get +1ap Creations of bile +1 str/move Fight after death in melee wanton slaughter (super doctrine): Melee hits on 6 auto wound ''Build a warband'' renegade traits +4" to range other than grenade and relic After killing a unit, the unit is then considered to be in destruction, massacre and slaughter for the rest of the game WE Not in the codex Datasheet info: Disco lord not much changeSorcerer in terminator armor can have a chaos familiarCultist HQ squad buff cultist moralCypher In the codexCSM legionaries legionaries is the new name for the csm troop unit choice same profile as before but 2W and 3a (4a on the AC) (not confirmed but my guess is 10 man squad like plague marines and rubrics) loadout: AC gets a daemon blade (S user ap2 d2; 6s to wound= 1MW); plasma pistol; can choose 1 weapon fron the melee weapons list Any of all legionaires can replace bolter for chainswords 1 legionaire can take a special weapon 1 legionaire can take a heavy weapon 1 legionaire can take balefire tome (cast 1/deny 1) 1 legionaire can take a heavy chainaxe (S+4 ap4 d2; -1 to hit) 1 legionaire can take a chaos icon Mutant cultists a squad made of a mix of big mutant and small mutants big mutant at S5 t4 & ap2 in melee small mutant are S4 t4 & ap1 in melee Cult units (berzerkers/rubrics/plague marines, only noise marines are stille in the codex because EC wont be getting their own book very soon) Are no longuer in the codex Act like harlequins in CWE army, or like Scions in Guard (including them is like including fabius bile, it doesnt cancel you legion trait) Always Elites can benefit from army rules Cannot gain a legion trait Fallen No in the codexChosen 3w Stat wise similar to CSM troops (6'' S4 T4 3+/no invul) WS 3+/BS 3+/ 3A (champion 4a) Gain gain an additional trait that you can choose, this trait is one of traits from the list of build a warband traits Loadout: everyone comes with a bolter, bolt pistol and accursed weapon (S+1 ap3 d1; +1A) 2 per 5 chosen can replace their bolt pistol with a plasma pistol 2 per 5 chosen can replace their bolter with a combi-weapon 1 per 5 chosen can replace their bolter with an additional accursed weapon (S+1 ap3 d1; +1A) Terminators Base loadout combi-bolters, accursed weapons (S+1 ap3 d1; +1a) 1 per 5 can replace combibolter with autocannon or heavy flamer 1 per 5 can replace combi bolter with an extra accursed weapon 3 per 5 can replace accursed weapon with a powerfist 1 per 5 can replace accursed weapon with a chainfist 2 per 5 can replace combi bolters with up to 2 combi flamers 2 per 5 can replace combi bolter with 2 combi melta 1 per 5 can replace combibolters with 1 combi plasma Greater possessed Not in the codex (my guess is the models are the new regular possessed models)Possessed S5 T5 3W 5A unit of 10 (do not know if this is total or max) Personnal guess: either the greater possessed model will be the new stand possessed model, or it will be an upgrade to the standard possessed unit Mutilators no longer in the book Warp talon lost cancel overwatch gained no fallback 5a (these are total with claws) Raptors still have the -1LD aura +2a Venomcrawler is now FA is a bit faster (my guess 12" instead of 10") now gives +1 to psychic tests claws and mechatentrites are now just 1 weapon (again my guess this means the claw profile may be getting +2a) ws3 bs3 Obliterators have essentially big guns never tire(shoot into engagement range with -1 to hit) ignore modifier for heavy weapons armed with powerfists without -1 to hit Has 3 shooting profiles: Heavy 9+d6 s5 ap1 d1 Heavy 3+d3 s7 ap2 d2 Heavy d3 s9 ap3 d4 Havocs exactly the same as right now but 2wOther: Unmarked units gain some support from stratagems and renegade traits (build a warband) The combat patrol is Legionaries/Havocs/Helbrute/Dank apostle Vanger, Bulwyf, Jorgend Lupus and 7 others 10 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794716 Share on other sites More sharing options...
WrathOfTheLion Posted February 9, 2022 Share Posted February 9, 2022 For Fallen, do you think they're folded into an existing datasheet with some faction rules in the Codex, or that we'll see a Fallen Supplement for Codex: Chaos Space Marines later? Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794717 Share on other sites More sharing options...
Lagrath Posted February 9, 2022 Share Posted February 9, 2022 If marks can't go on vehicles does that mean the daemonic upgrades like -1 to wound can't go on vehicles? Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794725 Share on other sites More sharing options...
BadgersinHills Posted February 9, 2022 Share Posted February 9, 2022 I thought the contents of the Combat Patrol would be the Shadowspear Chaos plus something else, so the news of the contents are interesting. Hope this leads to a separate Shadowspear Chaos release. Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794732 Share on other sites More sharing options...
Cheex Posted February 9, 2022 Share Posted February 9, 2022 CSM legionaries legionaries is the new name for the csm troop unit choice same profile as before but 2W and 3a (4a on the AC) (not confirmed but my guess is 10 man squad like plague marines and rubrics) loadout: AC gets a daemon blade (S user ap2 d2; 6s to wound= 1MW); plasma pistol; can choose 1 weapon fron the melee weapons list Any of all legionaires can replace bolter for chainswords 1 legionaire can take a special weapon 1 legionaire can take a heavy weapon 1 legionaire can take balefire tome (cast 1/deny 1) 1 legionaire can take a heavy chainaxe (S+4 ap4 d2; -1 to hit) 1 legionaire can take a chaos icon I don't see GW releasing an upgrade sprue for a box that's only a couple of years old (what are we, Space Marines?), and I don't buy them having rules for models that don't exist while in the same codex removing rules for models that don't exist. Either GW's being even more internally inconsistent than usual, or someone is having a laugh. (Or, third option: this is a playtest version so GW is just trying out a bunch of ideas at once.) Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794733 Share on other sites More sharing options...
Excessus Posted February 9, 2022 Share Posted February 9, 2022 It sucks that Legionnaires/Termies lose options they've had since 2nd ed... Vettanker, Bulwyf, Slave to Darkness and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794735 Share on other sites More sharing options...
Maschinenpriester Posted February 9, 2022 Share Posted February 9, 2022 I thought the contents of the Combat Patrol would be the Shadowspear Chaos plus something else, so the news of the contents are interesting. Hope this leads to a separate Shadowspear Chaos release. That would be indeed quite interesting news. I wonder what would happen tonoblits in that case? New kit? Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794754 Share on other sites More sharing options...
TrawlingCleaner Posted February 9, 2022 Share Posted February 9, 2022 CSM legionaries legionaries is the new name for the csm troop unit choice same profile as before but 2W and 3a (4a on the AC) (not confirmed but my guess is 10 man squad like plague marines and rubrics) loadout: AC gets a daemon blade (S user ap2 d2; 6s to wound= 1MW); plasma pistol; can choose 1 weapon fron the melee weapons list Any of all legionaires can replace bolter for chainswords 1 legionaire can take a special weapon 1 legionaire can take a heavy weapon 1 legionaire can take balefire tome (cast 1/deny 1) 1 legionaire can take a heavy chainaxe (S+4 ap4 d2; -1 to hit) 1 legionaire can take a chaos icon I don't see GW releasing an upgrade sprue for a box that's only a couple of years old (what are we, Space Marines?), and I don't buy them having rules for models that don't exist while in the same codex removing rules for models that don't exist. Either GW's being even more internally inconsistent than usual, or someone is having a laugh. (Or, third option: this is a playtest version so GW is just trying out a bunch of ideas at once.) Shadowspear came out in March 2019 as did the multi-part kit which makes the kits nearly 3 years old. At this point I wouldn't be surprised at all at an upgrade sprue as the base kit is fantastic. As you say, we're not Loyalists but we're likely one of the largest player counts outside of the various shades of Marines. If the restrictions of CSM/Legionnaries comes to pass, it will be unfortunate for sure and I'll lament the loss of Combiweapons on Aspiring Champions but demon weapons on ACs sounds pretty hilarious as does a 2 handed Chain-axe We'll see what comes to pass when we get the book, some stuff is likely to change between playtests as we've seen with the Eldar Leaks WrathOfTheLion 1 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794766 Share on other sites More sharing options...
Doctor Perils Posted February 9, 2022 Share Posted February 9, 2022 CSM legionaries legionaries is the new name for the csm troop unit choice same profile as before but 2W and 3a (4a on the AC) (not confirmed but my guess is 10 man squad like plague marines and rubrics) loadout: AC gets a daemon blade (S user ap2 d2; 6s to wound= 1MW); plasma pistol; can choose 1 weapon fron the melee weapons list Any of all legionaires can replace bolter for chainswords 1 legionaire can take a special weapon 1 legionaire can take a heavy weapon 1 legionaire can take balefire tome (cast 1/deny 1) 1 legionaire can take a heavy chainaxe (S+4 ap4 d2; -1 to hit) 1 legionaire can take a chaos icon I don't see GW releasing an upgrade sprue for a box that's only a couple of years old (what are we, Space Marines?), and I don't buy them having rules for models that don't exist while in the same codex removing rules for models that don't exist. Either GW's being even more internally inconsistent than usual, or someone is having a laugh. (Or, third option: this is a playtest version so GW is just trying out a bunch of ideas at once.) The prevailing rumours indicate that the Kill Team Nachmund boxset is those corsairs versus Chaos Space Marines with an extra sprue (similar to the Tau pathfinders in Kill Team Chalnath) - still, better to remain skeptical/cautious, because that Legionaries unit sounds too good to be true imo. Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794788 Share on other sites More sharing options...
Maschinenpriester Posted February 9, 2022 Share Posted February 9, 2022 <p> CSM legionaries legionaries is the new name for the csm troop unit choice same profile as before but 2W and 3a (4a on the AC) (not confirmed but my guess is 10 man squad like plague marines and rubrics) loadout: AC gets a daemon blade (S user ap2 d2; 6s to wound= 1MW); plasma pistol; can choose 1 weapon fron the melee weapons list Any of all legionaires can replace bolter for chainswords 1 legionaire can take a special weapon 1 legionaire can take a heavy weapon 1 legionaire can take balefire tome (cast 1/deny 1) 1 legionaire can take a heavy chainaxe (S+4 ap4 d2; -1 to hit) 1 legionaire can take a chaos icon I don't see GW releasing an upgrade sprue for a box that's only a couple of years old (what are we, Space Marines?), and I don't buy them having rules for models that don't exist while in the same codex removing rules for models that don't exist. Either GW's being even more internally inconsistent than usual, or someone is having a laugh. (Or, third option: this is a playtest version so GW is just trying out a bunch of ideas at once.) The prevailing rumours indicate that the Kill Team Nachmund boxset is those corsairs versus Chaos Space Marines with an extra sprue (similar to the Tau pathfinders in Kill Team Chalnath) - still, better to remain skeptical/cautious, because that Legionaries unit sounds too good to be true imo. I am also sceptical because if they would use the "old" csm sprue that would mean 10 models? Might be a little too many marines for kill team maybe. Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794823 Share on other sites More sharing options...
Plague _Lord Posted February 9, 2022 Share Posted February 9, 2022 They can just do a mixed sprue of marines and cultists with the marines having an upgrade sprue with whatever gadgets and upgrades they are planning for the new dex so something like this: 7 cultists/renegade guardsmen with gizmos 1 CSM with double handed chainaxe 1 CSM with Icon 1 CSM with Balefire tome that would seem like something possible at least. What bugs me though is that GW sees CSM as barbarians and none of their upgrades are every tech related, just sorcery or BIG CHAINAXE GOES WRRR. I mean come on the dark mech actually innovates so marines should have a lot of weird tech that could be infused with the demonic, but wouldnt have to. Give my marines some cool tech :cuss! MegaVolt87, Balthamal, Vettanker and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794827 Share on other sites More sharing options...
SanguinaryGuardsman Posted February 9, 2022 Share Posted February 9, 2022 Other: Unmarked units gain some support from stratagems and renegade traits (build a warband) The combat patrol is Legionaries/Havocs/Helbrute/Dank apostle I can hardly wait for the new Dank Apostle. He is gonna be spitting out 10,000 year old memes straight from the Eye of Terror. Prot, Iron Father Ferrum, Hollenweger and 10 others 13 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794887 Share on other sites More sharing options...
Maschinenpriester Posted February 9, 2022 Share Posted February 9, 2022 They can just do a mixed sprue of marines and cultists with the marines having an upgrade sprue with whatever gadgets and upgrades they are planning for the new dex so something like this: 7 cultists/renegade guardsmen with gizmos 1 CSM with double handed chainaxe 1 CSM with Icon 1 CSM with Balefire tome that would seem like something possible at least. What bugs me though is that GW sees CSM as barbarians and none of their upgrades are every tech related, just sorcery or BIG CHAINAXE GOES WRRR. I mean come on the dark mech actually innovates so marines should have a lot of weird tech that could be infused with the demonic, but wouldnt have to. Give my marines some cool tech :cuss! That would be quite fun if they would do that. Would not even be that much of an outloer considering the ork commandos have a mixed unit composituon as well. Tipsy Techpriest and Doctor Perils 2 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794899 Share on other sites More sharing options...
WrathOfTheLion Posted February 9, 2022 Share Posted February 9, 2022 They might still sell the sprues for some of the shadowspear stuff, like they do for part of Indomitus and for part of Dark Imperium. Those have usually been kind of expensive, so might be worth grabbing one of the Start Collecting boxes over the next few months if there's stuff in there you want. Vesalius 1 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794901 Share on other sites More sharing options...
Sandviper Posted February 9, 2022 Share Posted February 9, 2022 Has there been any leaks or speculation on the bikes? What about princes? They need a ton of help. techsoldaten and Khornestar 2 Back to top Link to comment https://bolterandchainsword.com/topic/371366-what-to-expect-from-9e-csm/page/35/#findComment-5794929 Share on other sites More sharing options...
