NKirkham24 Posted April 16, 2022 Share Posted April 16, 2022 I was creating a list using the army of renown rules and while doing so, saw the potential to upgrade a sergeant to have a warlord trait. Initially I thought adding something like Imperium’s Sword to a sergeant gives a squad a good chance to make a charge with the +1 and a reroll. Checking the FAQs, it states the warlord trait only effects the sergeant, not the squad. I’m not sure how the rules would work in this scenario. Do you roll twice to charge unit, one for the sergeant alone? As far as I know that’s unprecedented, rolling two charges for a unit. And what happen if he makes it but the squad doesn’t? Coherency kicks in? Once he’s in combat, does the pile-in/consolidate only effect him? It’s an odd interaction, which has probably been FAQ’d somewhere that I haven’t seen, but wanted to get your steer on it. Cheers Link to comment https://bolterandchainsword.com/topic/373871-sergeant-%E2%80%98warlord%E2%80%99-traits/ Share on other sites More sharing options...
BloodyB Posted April 16, 2022 Share Posted April 16, 2022 Personally, I would allow that trait to affect the squad. Link to comment https://bolterandchainsword.com/topic/373871-sergeant-%E2%80%98warlord%E2%80%99-traits/#findComment-5816488 Share on other sites More sharing options...
MadEdric Posted April 19, 2022 Share Posted April 19, 2022 I'd say the part that allows rerolls on charges be ignored. It only works for the Sgt, not the squad. Since you cannot reroll for one model of the squad, the ability is not of any use. Link to comment https://bolterandchainsword.com/topic/373871-sergeant-%E2%80%98warlord%E2%80%99-traits/#findComment-5817490 Share on other sites More sharing options...
Lemondish Posted April 22, 2022 Share Posted April 22, 2022 I'd say the part that allows rerolls on charges be ignored. It only works for the Sgt, not the squad. Since you cannot reroll for one model of the squad, the ability is not of any use. Well there's certainly no precedent either way, so the safest way to go is this way. Link to comment https://bolterandchainsword.com/topic/373871-sergeant-%E2%80%98warlord%E2%80%99-traits/#findComment-5818549 Share on other sites More sharing options...
Cleon Posted April 23, 2022 Share Posted April 23, 2022 I have no idea how the re-roll should work, but in my mind the +1 is easy - assuming you roll a 7, then you make the charge if any member of the squad gets to engagement with 7" or the Sgt gets to engagement with 8", so the positioning of the Sgt in the squad matters. Duke Danse Macabre 1 Back to top Link to comment https://bolterandchainsword.com/topic/373871-sergeant-%E2%80%98warlord%E2%80%99-traits/#findComment-5818685 Share on other sites More sharing options...
Duke Danse Macabre Posted April 24, 2022 Share Posted April 24, 2022 I have no idea how the re-roll should work, but in my mind the +1 is easy - assuming you roll a 7, then you make the charge if any member of the squad gets to engagement with 7" or the Sgt gets to engagement with 8", so the positioning of the Sgt in the squad matters. I would be inclined to agree purely because of how mixed kill teams work with different movement values using bikes and jump packs to stretch the squad but still remain In coherency. That said it going to be something that’s not 100% clear and the benefits are so negligible I would not take it as it would interrupt the game flow just to review and make the case for this rule which to be fair is as clear as mud at first glance. Link to comment https://bolterandchainsword.com/topic/373871-sergeant-%E2%80%98warlord%E2%80%99-traits/#findComment-5818950 Share on other sites More sharing options...
MadEdric Posted April 26, 2022 Share Posted April 26, 2022 I have no idea how the re-roll should work, but in my mind the +1 is easy - assuming you roll a 7, then you make the charge if any member of the squad gets to engagement with 7" or the Sgt gets to engagement with 8", so the positioning of the Sgt in the squad matters. I would be inclined to agree purely because of how mixed kill teams work with different movement values using bikes and jump packs to stretch the squad but still remain In coherency. That said it going to be something that’s not 100% clear and the benefits are so negligible I would not take it as it would interrupt the game flow just to review and make the case for this rule which to be fair is as clear as mud at first glance. This is why I take the WL traits that don't affect an individual, but rather squads. An Indomitor killteam with either double obsec or with still able to shoot while doing an action are the 2 I usually go for. Duke Danse Macabre 1 Back to top Link to comment https://bolterandchainsword.com/topic/373871-sergeant-%E2%80%98warlord%E2%80%99-traits/#findComment-5819794 Share on other sites More sharing options...
