Jolemai Posted May 1, 2022 Share Posted May 1, 2022 When firing a ranged weapon at a Cullexus, you treat the model as having BS6+. If you have a vehicle in engagement range and wish to fire it's heavy weapons at it, you need a 7+ to hit thanks to the -1 from Big Guns Never Tire, correct? Smite targets the nearest unit. A Cullexus may never be the target of a psychic attack. If the nearest unit to a psyker is a Cullexus, then Smite cannot be used (or rather it can be but nothing happens), correct? Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/ Share on other sites More sharing options...
Karhedron Posted May 1, 2022 Share Posted May 1, 2022 (edited) I believe you are correct for Smite, it just bounces off like a psychic nerf dart. Edited May 2, 2022 by Karhedron Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/#findComment-5821604 Share on other sites More sharing options...
BluejayJunior Posted May 2, 2022 Share Posted May 2, 2022 The Core Rules, under the making attacks section, states that an unmodified 6 always hits. So no matter what, you would be hitting the Culexus on 6s. But I think you're correct about smite. Wugo_Heaving, Tawnis and Xenith 3 Back to top Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/#findComment-5821928 Share on other sites More sharing options...
Jolemai Posted May 2, 2022 Author Share Posted May 2, 2022 Despite needing a 7 to hit? Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/#findComment-5821931 Share on other sites More sharing options...
Khulu Posted May 2, 2022 Share Posted May 2, 2022 Yes - the core rules section in question states simply that an unmodified 6 always hits and an unmodified 1 always fails with no qualifiers to either. I agree that the Culexus being the closest target would simply nullify Smite and similar powers. Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/#findComment-5821971 Share on other sites More sharing options...
Xenith Posted May 4, 2022 Share Posted May 4, 2022 (edited) unmodified 6 always hits, even if they'd need a 7+ normall - same with overwatch - I can't use a -1 to hit strat or anything when charging to make overwatch miss, as the 6 always hits. On smite, above is correct, no target meets the eligibility requirements so it just does nothing - best way is to break LOS to the culexus. Culexus are pretty tough [to hit], but flamers are pretty effective - they're still T4 4+ save weedy things. Edited May 4, 2022 by Xenith Karhedron and Tawnis 2 Back to top Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/#findComment-5822607 Share on other sites More sharing options...
Valkyrion Posted May 18, 2022 Share Posted May 18, 2022 Bumping this due to the Chaos Knights; Collar of Infernal Brass - favoured ability This model cannot be targeted or affected by psychic powers. I don't know the Culexus wording, so I don't know if it's the same issue as already solved above, but if a unit with the Collar of Infernal Brass is the closest enemy unit, then enemy psykers cannot cast Smite or other powers that affect the closest unit, correct? Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/#findComment-5829189 Share on other sites More sharing options...
Khulu Posted May 18, 2022 Share Posted May 18, 2022 Correct, the situation is rhe same. Karhedron and Valkyrion 2 Back to top Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/#findComment-5829207 Share on other sites More sharing options...
Diagramdude Posted May 27, 2022 Share Posted May 27, 2022 Unfortunately the maleceptor psychic overload still hurts culexus and probably goes through khorne collar too Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/#findComment-5832724 Share on other sites More sharing options...
phandaal Posted May 27, 2022 Share Posted May 27, 2022 Unfortunately the maleceptor psychic overload still hurts culexus and probably goes through khorne collar too Going strictly by RAW, yes, since it is an "ability" rather than a psychic power. Someone is definitely going to get challenged on that though, as it goes against the obvious intention of the Culexus. Link to comment https://bolterandchainsword.com/topic/374019-cullexus-queries/#findComment-5832802 Share on other sites More sharing options...
