Orange Knight Posted June 29, 2022 Share Posted June 29, 2022 I'm curious about what people are running? Initially I was thinking about 2 Plasmas and a Plasma Pistol, but then I noticed that their weapons skill is better. Now I think that some melee weapons are in order, but have noticed that costs could spiral out of control very easily. All advice is appreciated! Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/ Share on other sites More sharing options...
xxxjtmxxx Posted June 29, 2022 Share Posted June 29, 2022 i ll do squads with 2-3 combi melter and a mix of e axe and clans and a few normal ones. So you could burn a tank and also be very strong in melee. Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5839014 Share on other sites More sharing options...
SmorcInc Posted June 30, 2022 Share Posted June 30, 2022 Combi melta or plasma, either a combo or not depending on what targets you want to clap (things inside or outside of cars) with either legion special weapons or the classic spears or axes power weapons. Stick em in a drop pod, just being 2w and their melee profile means thst even if we make them kinda expensive the enemy needs to use some heavy firepower to remove. With power weapons they tear apart any possible tac chaff balls people throw at them to distract with. Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5839198 Share on other sites More sharing options...
Uberlord Gendo Posted June 30, 2022 Share Posted June 30, 2022 In melee oriented vets, I'm going to be giving them at least a few shotguns to see if I can trigger concussive. Since they're relentless, they're also not bad for running around with grav. Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5839207 Share on other sites More sharing options...
bushman101 Posted June 30, 2022 Share Posted June 30, 2022 At minimum, I'd pay for the chainswords. 2 pts per model isn't bad. And the squad max is 10, so it won't get out of control. The rest depends on what you do with the unit. A few pow weapons and a fist isn't bad. I kit mine out to a bit of everything. I play BA so I tend to get close to the enemy. Adding combis keeps them relevant and flexible Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5839210 Share on other sites More sharing options...
Skullheart Posted June 30, 2022 Share Posted June 30, 2022 It's quite expensive points vise but I think a few Nemesis Bolters per unit are worth a try. Since they're relentless they still move, shoot and charge normally. Cruor Vault and crabking 2 Back to top Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5839282 Share on other sites More sharing options...
Trixie Posted July 5, 2022 Share Posted July 5, 2022 Playing as Iron Warriors so a couple of combi meltas and a good amount of power mauls. I'll use em to bully power armour off objectives and force the enemy to worry about the flanks of their precious vehicles. Trench raidin' armour hatin' goon squads. Chronotonic 1 Back to top Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5841951 Share on other sites More sharing options...
Scammel Posted July 5, 2022 Share Posted July 5, 2022 On 6/30/2022 at 10:32 AM, Skullheart said: It's quite expensive points vise but I think a few Nemesis Bolters per unit are worth a try. Since they're relentless they still move, shoot and charge normally. There's more than a little irony in the fact that the Fists - renowned for eschewing 'underhand' tactics - boast pretty terrifying snipers and a unique character who can double-tap with a Nemesis bolter. tinpact 1 Back to top Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5842060 Share on other sites More sharing options...
Bung Posted July 6, 2022 Share Posted July 6, 2022 As a Fist Player i am thinking about a pair of Assault Cannons in a Veteran Squad. That should give me a bit more flexibility than a HSS. Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5842228 Share on other sites More sharing options...
Noserenda Posted July 6, 2022 Share Posted July 6, 2022 For effectiveness? I suspect Gravs are amazing while relentless. As ive been building things more for aesthetics ive gone for a shootier squad with 2 missile launchers and 2 nemesis bolters and a more focused melee squad with 2 meltas and 2 combi meltas. Both have a Fist on the sergeant, 6 cthonian power axes and a couple of chainswords on the wound takers for the hell of it really. Both aim to be mechanised, probably land raiders, rhinos if not :P My main worry really is terminators rinsing them due to the invulnerable save, but their melee options are so cheap :) Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5842574 Share on other sites More sharing options...
Chronotonic Posted July 10, 2022 Share Posted July 10, 2022 The two grav weapons in the veteran squad is always a good way to go...I put in two swords and a few combi-weapons but I keep my squad at 7-8 man squads too because the rhino use to hold 10...now its 12... bAcK iN mY DaY tHe rHiNO hELd a SqUaD Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5844614 Share on other sites More sharing options...
Marshal Mittens Posted July 11, 2022 Share Posted July 11, 2022 How I am doing mine is SGT with Plasma pistol + power weapon, and then either 2 meltas or 2 combi meltas (what I had the bits for at the time). It is tempting to add 2 power axes to each squad, to give them a little melee umph. Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5844706 Share on other sites More sharing options...
GodEmperorOfMankind Posted July 11, 2022 Share Posted July 11, 2022 Got a 5 man squad, HB with lightning claw, 2 lightning claws, combi Plas and swords and the Sgt with power fist and pistol. I figure the HB and combis can have shrapnel bolts (being iron warriors) to pin units, then charge and shred them. Obviously only PA units nothing heavier. May build out the squad to 10 man, but it's a slow grow army against my main opponent Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5844942 Share on other sites More sharing options...
Hfran Morkai Posted July 11, 2022 Share Posted July 11, 2022 I kind of like the idea of building a "Veteran Recon" squad with a couple of Nemesis Bolters, a Heavy Bolter and some other nice bits. Possibly MkVI. Chronotonic 1 Back to top Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5844945 Share on other sites More sharing options...
GodEmperorOfMankind Posted July 11, 2022 Share Posted July 11, 2022 7 minutes ago, Hfran Morkai said: I kind of like the idea of building a "Veteran Recon" squad with a couple of Nemesis Bolters, a Heavy Bolter and some other nice bits. Possibly MkVI. Now relentless nemesis bolters have been mentioned so do I! Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5844950 Share on other sites More sharing options...
Chronotonic Posted July 11, 2022 Share Posted July 11, 2022 4 hours ago, Altis said: Now relentless nemesis bolters have been mentioned so do I! thats why I take the gravaton guns for the relentless rule and their rule being heavy... Heavy...thats fine...I have been doing this a few centuries...I know how to move and shoot Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5845047 Share on other sites More sharing options...
Noserenda Posted July 12, 2022 Share Posted July 12, 2022 Im assuming the relentless is because they used to have suspensors, but its obviously a lot better :D GodEmperorOfMankind 1 Back to top Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5845069 Share on other sites More sharing options...
Interrogator-Chaplain Ezra Posted July 13, 2022 Share Posted July 13, 2022 I'm toying with the idea of banestrikes, 2 heavy flamers, and some mauls. They'll bully PA squads off objectives and clean away chaff. 2 units in Rhinos to make up my mandatories in a PotL list. As an alternative to banestrikes, combi-grenades. Link to comment https://bolterandchainsword.com/topic/374707-how-are-people-equipping-veteran-tactical-units/#findComment-5845568 Share on other sites More sharing options...
