tinpact Posted June 30, 2022 Share Posted June 30, 2022 A few questions as listed: 1. So, in 1.0 the Support Officer and Support Squad rules meant you couldn't take certain units in Compulsory slots. As far as I can tell, however, those rules don't exist anymore. Are there other restrictions besides just missing out on Master of the Legion and Line? 2. When an ability says something along the lines of "Unit A may be taken as Troops choices in XYZ" does that mean "Unit A may be taken as Troops choices instead of their usual slot" or "Unit A may be taken as Troops in addition to their usual slot"? 3. Is there a difference between "+1 to Wound" and "requires one lower result To Wound"? The former seems to be more common (I think the latter is just Blood Angels and a maybe a few other units). Versus increasing Strength it makes sense since for high Toughness units you can go up by 1S and still wound on 6s. The best answer I can think of is that you can't add to your roll to succeed a "-" result on the wound table, but one less is 6+, although that seems shaky to me. Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/ Share on other sites More sharing options...
Stitch5000 Posted June 30, 2022 Share Posted June 30, 2022 1: Support Squad is a rule on page 248 of the AoD Rulebook 2: Instead... 3: In effect it is similar, but subtly different in a number of circumstances. tinpact 1 Back to top Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5839253 Share on other sites More sharing options...
ShadowCore67 Posted July 2, 2022 Share Posted July 2, 2022 On 6/30/2022 at 4:15 AM, Stitch5000 said: 1: Support Squad is a rule on page 248 of the AoD Rulebook 2: Instead... 3: In effect it is similar, but subtly different in a number of circumstances. 2. is not instead. It's in addition to. tinpact and GodEmperorOfMankind 2 Back to top Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5840426 Share on other sites More sharing options...
tinpact Posted July 2, 2022 Author Share Posted July 2, 2022 Ah, okay. That seems much more convenient. Now, how about bonuses to wound? I haven't checked it comprehensively, but it seems to me the two bonuses are identical in normal cases. I read through the rulebook and there's rules for how characteristics may be modified but very little on how attack roll modifiers work (can you modify a roll higher than 6?). Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5840494 Share on other sites More sharing options...
ShadowCore67 Posted July 2, 2022 Share Posted July 2, 2022 2 hours ago, tinpact said: Ah, okay. That seems much more convenient. Now, how about bonuses to wound? I haven't checked it comprehensively, but it seems to me the two bonuses are identical in normal cases. I read through the rulebook and there's rules for how characteristics may be modified but very little on how attack roll modifiers work (can you modify a roll higher than 6?). Honestly I'm not sure of any cases where the difference in wording matters. There might be a use case out there where it does but I'm not aware of any. One example I can think of is if a unit has rule that said wound rules can't be modified against them, then maybe the "one lower result" would still work. You can modify dice above a 6 but it's doesn't really do anything since all rules regarding dice results are worded as "4+" or "equal to or greater than". Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5840537 Share on other sites More sharing options...
tinpact Posted July 2, 2022 Author Share Posted July 2, 2022 Well that is strange. Maybe one of the unreleased armies has an interaction with it and it'll become retroactively apparent? Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5840641 Share on other sites More sharing options...
Cactus Posted July 3, 2022 Share Posted July 3, 2022 It's most likely inconsistent writing and slipped through the editing process. Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5841034 Share on other sites More sharing options...
GodEmperorOfMankind Posted July 12, 2022 Share Posted July 12, 2022 On 7/2/2022 at 5:20 AM, ShadowCore67 said: 2. is not instead. It's in addition to. I would also say in addition to, it states they may be taken as troops in xyz, not must. Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5845297 Share on other sites More sharing options...
arnesh88 Posted July 15, 2022 Share Posted July 15, 2022 On 7/2/2022 at 7:26 AM, ShadowCore67 said: Honestly I'm not sure of any cases where the difference in wording matters. There might be a use case out there where it does but I'm not aware of any. One example I can think of is if a unit has rule that said wound rules can't be modified against them, then maybe the "one lower result" would still work. You can modify dice above a 6 but it's doesn't really do anything since all rules regarding dice results are worded as "4+" or "equal to or greater than". I think the difference between "one lower result" and "+1" is that the first one just makes it more likely to occur, while the other one is that plus more likely to trigger special rules. For example, +1 to wound could increase the chance of triggering Breaching, Rending, or Murderous Strike, but "one lower result" would mean you still need the bracketed number as a natural roll to trigger. Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5846189 Share on other sites More sharing options...
SkimaskMohawk Posted July 15, 2022 Share Posted July 15, 2022 1 hour ago, arnesh88 said: I think the difference between "one lower result" and "+1" is that the first one just makes it more likely to occur, while the other one is that plus more likely to trigger special rules. For example, +1 to wound could increase the chance of triggering Breaching, Rending, or Murderous Strike, but "one lower result" would mean you still need the bracketed number as a natural roll to trigger. Page 151 disagrees; no easier rends or breaches from +1 to wound. Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5846201 Share on other sites More sharing options...
arnesh88 Posted July 15, 2022 Share Posted July 15, 2022 2 minutes ago, SkimaskMohawk said: Page 151 disagrees; no easier rends or breaches from +1 to wound. Then it's :cuss:ty writing Link to comment https://bolterandchainsword.com/topic/374721-a-few-questions-legion-support-officersupport-squad-etc/#findComment-5846202 Share on other sites More sharing options...
