Pacific81 Posted July 1, 2022 Share Posted July 1, 2022 Hi bug debuggers! 99% certain that I posted in this topic earlier today (about 0800 GMT I think). My post has since disappeared (not sure when - I just checked around 2200 GMT) - pretty sure someone quote-responded, which looks like it has disappeared also? Link to topic: http://bolterandchainsword.com/topic/374735-saturnine-terminators/ I can't see anything in my content in terms of posted comments. My post wasn't off topic or inappropriate in any way so don't think it has been moderated (I haven't received any notification of that in any case) Link to comment https://bolterandchainsword.com/topic/374764-disappearing-post/ Share on other sites More sharing options...
sibomots Posted July 2, 2022 Share Posted July 2, 2022 It's possible that your post happened during a brief window of time that required a DB roll back. I had a glitch in some code to repair post upgrade issue. I had to revert to a backup to restore the topics to a point about 25 minutes earlier. You might have been caught in that. My apologies. Pacific81 1 Back to top Link to comment https://bolterandchainsword.com/topic/374764-disappearing-post/#findComment-5840394 Share on other sites More sharing options...
Pacific81 Posted July 2, 2022 Author Share Posted July 2, 2022 No problem it wasn't a big post! Just wanted to say about in case it was part of a wider issue that you weren't aware of. Great work on the site BTW it is definitely a step forward! Link to comment https://bolterandchainsword.com/topic/374764-disappearing-post/#findComment-5840439 Share on other sites More sharing options...
sibomots Posted July 2, 2022 Share Posted July 2, 2022 3 minutes ago, Pacific81 said: No problem it wasn't a big post! Just wanted to say about in case it was part of a wider issue that you weren't aware of. Great work on the site BTW it is definitely a step forward! Thanks. The last little bits I need to sort out are a surgical scrub of the forums that became infested with some malformed content You might have seen this already. The tell-tale sign is the embedding of URLs to an image, when the actual image is supposed to be rendered. Or signatures (and other posts actually) that contain URLs that are prefix with the wrong hostname (image, www, etc..) within the domain. It's going to get sorted out. Pacific81 and Codex Grey 2 Back to top Link to comment https://bolterandchainsword.com/topic/374764-disappearing-post/#findComment-5840442 Share on other sites More sharing options...
Codex Grey Posted July 2, 2022 Share Posted July 2, 2022 (edited) Yup, my post in another topic was eaten up around the same time as well. I assumed the db rollback was the reason so I guess this pretty much confirms it. Edited July 2, 2022 by Codex Grey Pacific81 1 Back to top Link to comment https://bolterandchainsword.com/topic/374764-disappearing-post/#findComment-5840443 Share on other sites More sharing options...
sibomots Posted July 2, 2022 Share Posted July 2, 2022 12 hours ago, Codex Grey said: Yup, my post in another topic was eaten up around the same time as well. I assumed the db rollback was the reason so I guess this pretty much confirms it. Sorry about that. Your sacrifice led to the discovery of the glitch that I in the last hour or so fixed. I've bulk-edited a massive trove of forum posts fixing the literal URL text of images and other things. Many things have been automagically edited in the last hour. In essence the patch did this: Was: <span>URL</span> Is: <img src="URL"> That general pattern was applied throughout the forum posts for image (URL) that were hosted on B&C. Marshal Mattias and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/374764-disappearing-post/#findComment-5840640 Share on other sites More sharing options...
