FormelyKnownAsSmashyPants Posted July 12, 2022 Share Posted July 12, 2022 (edited) Hey all I’m wanting use some Deimos Rhinos for my 40k DA andI’m wondering whether the turret ring for the 40k Rhino will fit in place of the top hatches of the Deimos so I can run them as Razorbacks also. Also do the tracks for the 40k Rhino fit the Deimos Rhino without needing too much modification? Anybody who has both kits and could check for me, I would greatly appreciate it. Thanks in advance, Dusty. Edited July 12, 2022 by Captain Smashy Pants Link to comment https://bolterandchainsword.com/topic/374954-deimos40k-rhino-size-comparison/ Share on other sites More sharing options...
Anticontrarian Posted July 27, 2022 Share Posted July 27, 2022 The turret ring fits perfectly. I'm working on a Chaos "Razorback" conversion (Havoc Launcher and two Combi-Bolters in a Taurox turret) for my 40k army, and it's thankfully exactly the same slot size/notch position for the 2 rhino kits. I'll check the tracks for you this evening. FormelyKnownAsSmashyPants, Karhedron and tinpact 3 Back to top Link to comment https://bolterandchainsword.com/topic/374954-deimos40k-rhino-size-comparison/#findComment-5850252 Share on other sites More sharing options...
FormelyKnownAsSmashyPants Posted July 27, 2022 Author Share Posted July 27, 2022 Cool that’s a huge help. Now I know the turret ring fits. If you could check the tracks later and get back to me that would be greatly appreciated too. Link to comment https://bolterandchainsword.com/topic/374954-deimos40k-rhino-size-comparison/#findComment-5850261 Share on other sites More sharing options...
Anticontrarian Posted July 27, 2022 Share Posted July 27, 2022 Glad to be of assistance! I've just checked the tracks (had a conveniently-trackless MkII chassis lying around), and it looks like the spacing is a tiny bit off - with the rearmost wheels aligned, the front wheels are a little bit further forward on the MkII as you can see in the pic attached. Probably not a significant shift, but it might be a little awkward getting the fit perfectly aligned. Width-wise they work just fine, although you might need to file down the little nubs where they clash with the wheel axles. FormelyKnownAsSmashyPants and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/374954-deimos40k-rhino-size-comparison/#findComment-5850426 Share on other sites More sharing options...
FormelyKnownAsSmashyPants Posted July 28, 2022 Author Share Posted July 28, 2022 Thank you for the comparison. Very much appreciated. Link to comment https://bolterandchainsword.com/topic/374954-deimos40k-rhino-size-comparison/#findComment-5850609 Share on other sites More sharing options...
