FelipeFlops Posted July 14, 2022 Share Posted July 14, 2022 Hey guys, I've started doing a lot more magnetising of models alternate loadouts. It now means I have a load bits kicking around that I want some form of storage for. What's the best for of storage for something like this? Thank! Link to comment https://bolterandchainsword.com/topic/374982-alternative-loadouts-bits-box/ Share on other sites More sharing options...
Harrowmaster Posted July 14, 2022 Share Posted July 14, 2022 I would reccomend a segmented box (like a tool box) with loads of different compartments to help you keep track. This is what I use: Casual Heresy and derLumpi 2 Back to top Link to comment https://bolterandchainsword.com/topic/374982-alternative-loadouts-bits-box/#findComment-5845913 Share on other sites More sharing options...
FormelyKnownAsSmashyPants Posted July 14, 2022 Share Posted July 14, 2022 For my left over bits I use compartmented boxes I got from an auto supply store, but you can get them at camping and fishing stores, I believe fishermen use them their fish hooks and such, craft stores, electronics stores as well as the likes of eBay and Amazon. If you’re talking about a way of storing your magnetised, painted bits between games then you can still use a compartmented box, just wrap each bit in a tissue to stop them from scratching up against each other. Also I would recommend varnishing your bits for protection, as you should do for the rest of your models anyway. Link to comment https://bolterandchainsword.com/topic/374982-alternative-loadouts-bits-box/#findComment-5845940 Share on other sites More sharing options...
FelipeFlops Posted July 14, 2022 Author Share Posted July 14, 2022 3 hours ago, Captain Smashy Pants said: For my left over bits I use compartmented boxes I got from an auto supply store, but you can get them at camping and fishing stores, I believe fishermen use them their fish hooks and such, craft stores, electronics stores as well as the likes of eBay and Amazon. If you’re talking about a way of storing your magnetised, painted bits between games then you can still use a compartmented box, just wrap each bit in a tissue to stop them from scratching up against each other. Also I would recommend varnishing your bits for protection, as you should do for the rest of your models anyway. Yes it is for painted weapons etc; Sounds like a tackle box of some sort would be the best idea. Link to comment https://bolterandchainsword.com/topic/374982-alternative-loadouts-bits-box/#findComment-5846014 Share on other sites More sharing options...
Helias_Tancred Posted July 14, 2022 Share Posted July 14, 2022 I use cheap plastic Flambeaux tackle boxes from WalMart. I've got one each dedicated to Blood Angel bits, Dark Angel bits, and Space Marine bits. I also store my paint pots in them. I use smaller ones for all of my extra bases, and paints especially game inks, etc. Link to comment https://bolterandchainsword.com/topic/374982-alternative-loadouts-bits-box/#findComment-5846084 Share on other sites More sharing options...
NovemberIX Posted July 15, 2022 Share Posted July 15, 2022 I've got a bead box from the local craft store I use if I'm traveling and I need to make sure I have some options. Otherwise my bitz box (technically a craft cabinet) usually works well enough. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/374982-alternative-loadouts-bits-box/#findComment-5846325 Share on other sites More sharing options...
Bryan Blaire Posted July 16, 2022 Share Posted July 16, 2022 Given that these are magnetized pieces you probably don’t want whacking into each other, and to avoid any kind of wrapping possibly damaging your painting on them, you could also use some metal strips glued to the sides of the separator pieces (although I would probably put them in the bottom of the sectioned off areas) in the tackle/craft box to have the bits remain (mostly) separated. Link to comment https://bolterandchainsword.com/topic/374982-alternative-loadouts-bits-box/#findComment-5846582 Share on other sites More sharing options...
