Jings Posted July 16, 2022 Share Posted July 16, 2022 (edited) Sup Fraters, Ya boi picked up a Spartan for a steal on eBay. Thing is, I don't particularly want a Spartan. I want a Typhon. Anyone got ideas for 3rd party bits or scratch building the Dreadhammer Cannon? While I've got a pretty huge plasma gun bit, I don't think that would be very in keeping with the Iron Warriors theme I'm going for (although the idea of making a Dark Angels Typhon/Cerberus with it is tempting). I think I want to keep it as a regular giant cannon as I want to be able to field the piece alongside my 30K/40K Iron Warriors force and still match the recently corrupted aesthetic. Ideally, I'd like to make this modular, so I can swap out the front ramp section with the cannon (and potentially, later, a Cerberus-style laser) as needs must. It's not essential, but if anyone has some good ideas for how to approach such a method I'll absolutely give it a shot. Cheers lads. Edited July 16, 2022 by Jings Link to comment https://bolterandchainsword.com/topic/375015-plastic-spartan-to-typhon-conversion-ideas/ Share on other sites More sharing options...
Lord Raven 19 Posted August 5, 2022 Share Posted August 5, 2022 On 7/16/2022 at 6:19 PM, Jings said: Sup Fraters, Ya boi picked up a Spartan for a steal on eBay. Thing is, I don't particularly want a Spartan. I want a Typhon. Anyone got ideas for 3rd party bits or scratch building the Dreadhammer Cannon? While I've got a pretty huge plasma gun bit, I don't think that would be very in keeping with the Iron Warriors theme I'm going for (although the idea of making a Dark Angels Typhon/Cerberus with it is tempting). I think I want to keep it as a regular giant cannon as I want to be able to field the piece alongside my 30K/40K Iron Warriors force and still match the recently corrupted aesthetic. Ideally, I'd like to make this modular, so I can swap out the front ramp section with the cannon (and potentially, later, a Cerberus-style laser) as needs must. It's not essential, but if anyone has some good ideas for how to approach such a method I'll absolutely give it a shot. Cheers lads. Unless you have access to a 3D printer, I suggest you experiment with PVC pipe, or similar, as a base for the cannon. Plasticard would likely be suited to rebuilding the front of the tank. As for modularity, it'll be easiest if you give up the front ramp opening (I believe the kit does that), and glue it together into a solid structure, then, glue magnets in where the hinges go, and in place of the axles on the door. Corresponding magnet placements could then be determined on your scratchbuilt cannon front. Then later, a similar scratchbuilt front could be made for the Cerberus laser. Link to comment https://bolterandchainsword.com/topic/375015-plastic-spartan-to-typhon-conversion-ideas/#findComment-5854179 Share on other sites More sharing options...
LameBeard Posted August 14, 2022 Share Posted August 14, 2022 Would a conversion along the lines of the Land Raider Aries work? I mean the gun would be a bit smaller, but I think your opponent would know what you were trying to do. I think there are some 3d files around for Land Raider Achilles as well - could try to adapt that and replace weapon with single big gun? Link to comment https://bolterandchainsword.com/topic/375015-plastic-spartan-to-typhon-conversion-ideas/#findComment-5857030 Share on other sites More sharing options...
Evil Eye Posted August 25, 2022 Share Posted August 25, 2022 This is a bit of a naughty suggestion but if you can get an actual Typhon for cheap (either a second hand wreck or a... reproduction version) you could transplant the cannon onto the plastic kit. Link to comment https://bolterandchainsword.com/topic/375015-plastic-spartan-to-typhon-conversion-ideas/#findComment-5860649 Share on other sites More sharing options...
Cadmus Tyro Posted August 25, 2022 Share Posted August 25, 2022 Yes it’s possible, the question is, is it worth the effort knowing a plastic typhon is probably around the corner. I rescued an old Resin Spartan some years ago and converted it to a typhon. I used the plastic storm sword kit for the main gun, which scales a little smaller but still looks right. Used the housing from the sprue to finish up some details and then the siege shield was made from plasticard. The only other thing you would need are the single lascannon/heavy bolters for the sponsons. Here she is in all her painted glory: Cadmus lost_angel, Grotsmasha, Dr_Ruminahui and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/375015-plastic-spartan-to-typhon-conversion-ideas/#findComment-5860674 Share on other sites More sharing options...
Jolemai Posted August 25, 2022 Share Posted August 25, 2022 There's always this option: https://puppetswar.eu/big-momma-attachment.html Link to comment https://bolterandchainsword.com/topic/375015-plastic-spartan-to-typhon-conversion-ideas/#findComment-5860681 Share on other sites More sharing options...
