.Torch. Posted July 17, 2022 Share Posted July 17, 2022 Evening all, I am looking for a match for the OOP Mordhiem tufts. I believe GW sources them through a third party, but I cannot remember the name of the company? Need some to finish some army bases. Any help appreciated. Found a few through Gamers grass, but not sure which ones will match up. Cheers for the help! Link to comment https://bolterandchainsword.com/topic/375027-mordhiem-tuft-non-gw-match/ Share on other sites More sharing options...
Solution Arkhanist Posted July 17, 2022 Solution Share Posted July 17, 2022 Gw used to source them from mininatur, don't know if they still do. I've also seem them branded silflor. IIRC (though I may not!) mordheim turf was Late fall grass tufts; they come in a 4mm and 6mm version; 4mm would be the GW length I think. I like the karst late fall tufts also, they've a nice brown two tone effect going on for some dead grass variety to mix in. .Torch. 1 Back to top Link to comment https://bolterandchainsword.com/topic/375027-mordhiem-tuft-non-gw-match/#findComment-5846962 Share on other sites More sharing options...
Sword Brother Adelard Posted July 18, 2022 Share Posted July 18, 2022 The outlay isn't the cheapest, as you need an applicator, but it's super easy to make static grass tufts yourself. Then you could make your own blend from the grasses sold my places like Geek Gaming Scenics or War World scenics. .Torch. and Magos Takatus 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/375027-mordhiem-tuft-non-gw-match/#findComment-5847009 Share on other sites More sharing options...
Guest Posted July 18, 2022 Share Posted July 18, 2022 11 hours ago, Arkhanist said: I like the karst late fall tufts also, they've a nice brown two tone effect going on for some dead grass variety to mix in. Are the Karst ones what Middenland ones were? Link to comment https://bolterandchainsword.com/topic/375027-mordhiem-tuft-non-gw-match/#findComment-5847061 Share on other sites More sharing options...
.Torch. Posted July 18, 2022 Author Share Posted July 18, 2022 14 hours ago, Arkhanist said: Gw used to source them from mininatur, don't know if they still do. I've also seem them branded silflor. IIRC (though I may not!) mordheim turf was Late fall grass tufts; they come in a 4mm and 6mm version; 4mm would be the GW length I think. I like the karst late fall tufts also, they've a nice brown two tone effect going on for some dead grass variety to mix in. Thank you! Those are exactly what I am looking for. Link to comment https://bolterandchainsword.com/topic/375027-mordhiem-tuft-non-gw-match/#findComment-5847115 Share on other sites More sharing options...
Arkhanist Posted July 18, 2022 Share Posted July 18, 2022 I never had any middenland, but I think karst late fall is browner than it was, looking at random photos online. Karst late fall tufts on the top (737-34s), karst early fall (737-33s) on the bottom, the longer version of both. Link to comment https://bolterandchainsword.com/topic/375027-mordhiem-tuft-non-gw-match/#findComment-5847122 Share on other sites More sharing options...
Guest Posted July 18, 2022 Share Posted July 18, 2022 (edited) 35 minutes ago, Arkhanist said: I never had any middenland, but I think karst late fall is browner than it was, looking at random photos online. Karst late fall tufts on the top (737-34s), karst early fall (737-33s) on the bottom, the longer version of both. Bought some Karst late fall as a test only €13 to the UK... So its not a huge cost for a test if its the same then I will never worry about ebay again. Pic attached of Middenland Tufts. Edited July 18, 2022 by Wolf Guard Einar Link to comment https://bolterandchainsword.com/topic/375027-mordhiem-tuft-non-gw-match/#findComment-5847129 Share on other sites More sharing options...
