Gorgoff Posted August 2, 2022 Share Posted August 2, 2022 On p. 160 it says that all Charges are announced and rolled first, then reactions are carried out. P. 182 says that the next charge is only announced when all models of the first unit have been moved. Suggested solutions? Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/ Share on other sites More sharing options...
Harrowmaster Posted August 2, 2022 Share Posted August 2, 2022 Personally I think it makes more sense to do each charge one by one, that way you don't lose track. But until an FAQ comes along the answer will probably be to agree with your opponent. Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/#findComment-5852776 Share on other sites More sharing options...
Brofist Posted August 2, 2022 Share Posted August 2, 2022 Going one by one is easier, but in my last game the sequence mattered. You should do them all at once as it can impact the combats. Spagunk 1 Back to top Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/#findComment-5852843 Share on other sites More sharing options...
stretch_135 Posted August 2, 2022 Share Posted August 2, 2022 I suspect this might be some overthinking on the Editor's part the exact quote on pg. 160: Quote During the Assault phase, the Reactive player may react when any enemy unit declares a Charge targeting a unit they control. Once the Active player has resolved all Charge Rolls, whether successful or not, but before any models are moved as part of either a Charge Move or a Surge Move, the Reactive player may choose to expend one of their Reactions for the phase... The key phrase here is "resolved all Charge Rolls, whether successful or not", the implication being that there may be more than one Charge Roll. However, per pgs 180-182 each Charge is explicitly resolved before declaring the next Charge. My thinking is that the wording for Charge Rolls on pg 160 is structured like that to account for re-rolls of charge distances - ie. you have one Charge Roll, it's unsuccessful but you re-roll, so that's another Charge Roll to resolve. jaxom and Harrowmaster 2 Back to top Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/#findComment-5852874 Share on other sites More sharing options...
Cactus Posted August 3, 2022 Share Posted August 3, 2022 2 hours ago, Brofist said: Going one by one is easier, but in my last game the sequence mattered. You should do them all at once as it can impact the combats. What happened in your last game? Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/#findComment-5852880 Share on other sites More sharing options...
Stitch5000 Posted August 3, 2022 Share Posted August 3, 2022 "All Charge rolls..." on Pg160 seems to refer to all charge rolls pertaining to that particular unit, not army-wide, as mentioned above. Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/#findComment-5852955 Share on other sites More sharing options...
Gorgoff Posted August 3, 2022 Author Share Posted August 3, 2022 10 hours ago, stretch_135 said: I suspect this might be some overthinking on the Editor's part the exact quote on pg. 160: The key phrase here is "resolved all Charge Rolls, whether successful or not", the implication being that there may be more than one Charge Roll. However, per pgs 180-182 each Charge is explicitly resolved before declaring the next Charge. My thinking is that the wording for Charge Rolls on pg 160 is structured like that to account for re-rolls of charge distances - ie. you have one Charge Roll, it's unsuccessful but you re-roll, so that's another Charge Roll to resolve. Yes, that is it. Thanks. Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/#findComment-5852967 Share on other sites More sharing options...
Spagunk Posted August 3, 2022 Share Posted August 3, 2022 15 hours ago, Cactus said: What happened in your last game? We were trying to get the game finished (it ran a bit late) and I declared/charged the wrong unit first. I then couldn't get a possible critical charge off to wipe the one squad sitting on the objective with two melee units. As such, the squad survived and scored the winning objective at the end of the game. Cactus and Brofist 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/#findComment-5853075 Share on other sites More sharing options...
Cactus Posted August 3, 2022 Share Posted August 3, 2022 So it was a 'models in the way' problem then? If you had resolved them in a different sequence I guess it would have worked out how you wanted. I was curious if there was a fundamental difference that produced some strange skewed outcome. Anyway, I'm certain now that the bullet points on page 180 are the intended way (completely resolve the unit's charge move and reactions before moving on to another unit). I just can't believe that is a mistake that slipped through editing and the odd plural usage on page 160 is not, rather than vice versa. Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/#findComment-5853160 Share on other sites More sharing options...
Spagunk Posted August 3, 2022 Share Posted August 3, 2022 1 hour ago, Cactus said: So it was a 'models in the way' problem then? If you had resolved them in a different sequence I guess it would have worked out how you wanted. I was curious if there was a fundamental difference that produced some strange skewed outcome. Anyway, I'm certain now that the bullet points on page 180 are the intended way (completely resolve the unit's charge move and reactions before moving on to another unit). I just can't believe that is a mistake that slipped through editing and the odd plural usage on page 160 is not, rather than vice versa. TECHNICALLY, a jump pack unit ignores all models and terrain. But we were running late and so we couldn't waste time arguing the situation. Just that if I charged first with unit A, I could have allowed unit B to mop up the one scoring unit while unit C charged something else without getting in the way. Link to comment https://bolterandchainsword.com/topic/375319-declaring-charges-and-resolving-them/#findComment-5853191 Share on other sites More sharing options...
