dees Posted August 4, 2022 Share Posted August 4, 2022 Hello Everyone, It seems to me that a lot of IG players are not putting heavy weapons in their infantry squads. Because they are free I don't see a downside to taking them. I would like to know your thoughts on why not taking them is helpful. And don't have a good day, have a great day. Slave to Darkness and Emperor Ming 2 Back to top Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/ Share on other sites More sharing options...
Emperor Ming Posted August 4, 2022 Share Posted August 4, 2022 Its to do with having one less obsec body While there free, ill always be taking one They die so quickly 9 or ten has make zero difference in my games duz_, Slave to Darkness, Inquisitor_Lensoven and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5853600 Share on other sites More sharing options...
Inquisitor_Lensoven Posted August 4, 2022 Share Posted August 4, 2022 3 hours ago, dees said: Hello Everyone, It seems to me that a lot of IG players are not putting heavy weapons in their infantry squads. Because they are free I don't see a downside to taking them. I would like to know your thoughts on why not taking them is helpful. And don't have a good day, have a great day. Some people see the -1 to hit on the heavy weapon after moving as a negative. I don’t see it that way, I’ll trade a harder hitting weapon with a 16% lower chance to hit over a lasgun hitting at normal BS. Slave to Darkness and hardcore1six 2 Back to top Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5853678 Share on other sites More sharing options...
dees Posted August 4, 2022 Author Share Posted August 4, 2022 Thanks for the incites friends. I hadn't thought about the model count being one less TBH. I think I'll be taking them until they are no longer free as well. I play Cadia mostly, but even if I was playing a more aggressive movement list I'd still miss the long range heavy shots IMO. And can't the HWT shoot their lasguns even it they shoot the heavy weapon? Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5853693 Share on other sites More sharing options...
Slave to Darkness Posted August 4, 2022 Share Posted August 4, 2022 I dont use heavy weapon squads at the moment because I lack the minis. Ill keep some without just to use as bullet shields though. Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5853714 Share on other sites More sharing options...
Emperor Ming Posted August 5, 2022 Share Posted August 5, 2022 I suppose some people might not want to jump the gun either and shell out on models that may become irrelevant again, if gw ever reverse the free stuff Its a good incentive to sell the new heavy weapons teams Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5853797 Share on other sites More sharing options...
TCC Posted August 5, 2022 Share Posted August 5, 2022 I run my squads all with lascannons (I tried other weapon systems but found you need the armour penetration against AoC). I then run a mixture of plasma and melta - plasma on the squads that are further back defending the armour as they need the range, then melta on the squads assaulting. im running at least two command squads for the secondaries and run them with mortars because I like to keep them hidden in cover and the mortar is the only system that can indirect fire. Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5853848 Share on other sites More sharing options...
Diagramdude Posted August 5, 2022 Share Posted August 5, 2022 The heavy weapon team only has one lasgun between the two operators so you lose out one lasgun worth of shooting. Worth it IMO. Also the large base of the HWT is great for melee because you can get the HWT in engagement range then get everyone else in the squad easily within 0.5” of the big base so they all can swing Inquisitor_Lensoven, Emperor Ming and hardcore1six 3 Back to top Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5853864 Share on other sites More sharing options...
Inquisitor_Lensoven Posted August 5, 2022 Share Posted August 5, 2022 6 hours ago, Diagramdude said: The heavy weapon team only has one lasgun between the two operators so you lose out one lasgun worth of shooting. Worth it IMO. Also the large base of the HWT is great for melee because you can get the HWT in engagement range then get everyone else in the squad easily within 0.5” of the big base so they all can swing Let’s face it though, getting your troopers into melee isn’t particularly an ideal situation lol duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5854037 Share on other sites More sharing options...
TCC Posted August 5, 2022 Share Posted August 5, 2022 8 minutes ago, Inquisitor_Lensoven said: Let’s face it though, getting your troopers into melee isn’t particularly an ideal situation lol It’s a great tactical decision - block them getting to a high value target like a tank commander for a turn or two (throw another squad in there to guarantee it) then fall back from combat next turn and let the tank do its job Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5854043 Share on other sites More sharing options...
dees Posted August 5, 2022 Author Share Posted August 5, 2022 A agree with you Diagramdude, I typically wrap my squad around the HWT base unless they're in cover or on terrain that prohibits it. It makes them almost impossible to get pinned in combat so you can always back out. Inquisitor_Lensoven you are right that its not ideal for the infantry to be in combat, but I unfortunately end up there in all most all games lol. duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5854075 Share on other sites More sharing options...
Diagramdude Posted August 6, 2022 Share Posted August 6, 2022 Most of the time when I’m charging with my infantry I am trying to get extra movement to pile in and consolidate onto an objective or turn off an enemy shooter. There are some enemies it’s an absolutely terrible idea to charge but there are a lot of enemy units and situations you gain a huge advantage by charging your infantry. Link to comment https://bolterandchainsword.com/topic/375353-infantry-squad-upgrade-question/#findComment-5854337 Share on other sites More sharing options...
