Khulu Posted August 5, 2022 Share Posted August 5, 2022 So, I sealed a Rhino and a Contemptor earlier. Both had transfers. The Contemptor ones came out fine. But there's little flecks of damage on the Rhino ones. It looks almost like bubbles popped under the transfer or something. I don't mind the effect this time but I would like to avoid it in the future if I can. Any thoughts? I used micro set and micro Sol but they were dry. I sealed with Munitorum Varnish. Link to comment https://bolterandchainsword.com/topic/375375-transfers-damaged-by-varnish/ Share on other sites More sharing options...
Guest Posted August 6, 2022 Share Posted August 6, 2022 Which did you varnish first? Do you think it was not shaken well enough? Are you 100% sure they were dry? Link to comment https://bolterandchainsword.com/topic/375375-transfers-damaged-by-varnish/#findComment-5854300 Share on other sites More sharing options...
Khulu Posted August 6, 2022 Author Share Posted August 6, 2022 I varnished them next to each other so whichever got hit first was only seconds ahead of the other. How long does micro sol take to dry completely? It had been an hour or more bit I guess I didn't touch it to check or anything. Link to comment https://bolterandchainsword.com/topic/375375-transfers-damaged-by-varnish/#findComment-5854301 Share on other sites More sharing options...
Guest Posted August 6, 2022 Share Posted August 6, 2022 (edited) 10 minutes ago, Nemesor Tyriks said: I varnished them next to each other so whichever got hit first was only seconds ahead of the other. How long does micro sol take to dry completely? It had been an hour or more bit I guess I didn't touch it to check or anything. OK purely anecdotal I have had Sol reactivate after using Set, time scale might be about the same so its possible thats what happens. I am in no way saying thats what happened I can only give you my opinion based on my experience. I use my airbrush for varnishing and use Ammo Mig Lucky Varnish, I tend to let transfers sit for a while as I varnish in batches. So with me participating in 12 Months of Hobby I will paint my months stuff, transfers then bases and do them at the end. I suppose the only real advice I can offer is maybe just wait some more hours or even a day. Sorry I can't be of more help. Edited August 6, 2022 by Wolf Guard Einar Link to comment https://bolterandchainsword.com/topic/375375-transfers-damaged-by-varnish/#findComment-5854302 Share on other sites More sharing options...
Khulu Posted August 6, 2022 Author Share Posted August 6, 2022 No that's very helpful! Thanks! Link to comment https://bolterandchainsword.com/topic/375375-transfers-damaged-by-varnish/#findComment-5854308 Share on other sites More sharing options...
WrathOfTheLion Posted August 6, 2022 Share Posted August 6, 2022 To me it sounds like you need to give it more time before varnishing. If it was something like a day later, I'd think it might be something else, but that there was still some there is almost certainly what was going on if it had only been an hour or two. That it only happened to one could vary based on how much you applied, or that the rhino has a flat panel vs the round one of the dreadnought. Link to comment https://bolterandchainsword.com/topic/375375-transfers-damaged-by-varnish/#findComment-5854336 Share on other sites More sharing options...
Karhedron Posted August 6, 2022 Share Posted August 6, 2022 I have had spray varnish attack transfers once or twice. I would let them dry for 24 hours if possible. The other thing I tend to do is seal them before I spray them. Lahmian medium will do the trick or a dab of acrylic varnish. WrathOfTheLion and Khulu 2 Back to top Link to comment https://bolterandchainsword.com/topic/375375-transfers-damaged-by-varnish/#findComment-5854401 Share on other sites More sharing options...
