Maggotlord Posted August 9, 2022 Share Posted August 9, 2022 Hi all, I absolutely love the Centurion models therefore I´m about to buy a squad. But how should I assemble them? As Assault or Devastator ones? What du think is better all around? Link to comment https://bolterandchainsword.com/topic/375425-centurion-devastator-or-centurion-assault-squad/ Share on other sites More sharing options...
Helias_Tancred Posted August 9, 2022 Share Posted August 9, 2022 I don't run them, but I *think* people tend to run them as the devastator variant, more than the assault variant? Maggotlord 1 Back to top Link to comment https://bolterandchainsword.com/topic/375425-centurion-devastator-or-centurion-assault-squad/#findComment-5855312 Share on other sites More sharing options...
Majkhel Posted August 9, 2022 Share Posted August 9, 2022 (edited) I would lean more towards the Assault Variant because you will not be able to buff their shooting as Cents are not CORE. To be frank you also cannot buff their melee but at least you get our native buffs. Edited August 10, 2022 by Majkhel Maggotlord, Spyros and XeonDragon 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/375425-centurion-devastator-or-centurion-assault-squad/#findComment-5855328 Share on other sites More sharing options...
Tokugawa Posted August 12, 2022 Share Posted August 12, 2022 After AoC rules, assault centurions really seen some tournament play. They can't receive <core> related buffs from characters, but could be revived by apothecary as normal. Comparing with other "bulky shooty walking stuff", like paragon or obliterator, raw power of shooty centurion is just toooo weak. I don't even mentioned battlesuits… Maggotlord 1 Back to top Link to comment https://bolterandchainsword.com/topic/375425-centurion-devastator-or-centurion-assault-squad/#findComment-5856184 Share on other sites More sharing options...
XeonDragon Posted August 12, 2022 Share Posted August 12, 2022 Bigger and tougher than Aggressors. More shots (and potentially higher strength/AP shots) than Terminators. More wounds than both. Worth a look. Maggotlord 1 Back to top Link to comment https://bolterandchainsword.com/topic/375425-centurion-devastator-or-centurion-assault-squad/#findComment-5856208 Share on other sites More sharing options...
CCE1981 Posted August 12, 2022 Share Posted August 12, 2022 There are ways to buff them. They just lack core. Soulwarden would still give them a 5++. I think there are ways to make them work just gotta find them. Maggotlord and XeonDragon 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/375425-centurion-devastator-or-centurion-assault-squad/#findComment-5856225 Share on other sites More sharing options...
Majkhel Posted August 12, 2022 Share Posted August 12, 2022 (edited) 3 hours ago, XeonDragon said: Bigger and tougher than Aggressors. More shots (and potentially higher strength/AP shots) than Terminators. More wounds than both. Worth a look. Tougher than Aggressors, true although you would take 4 Aggressors for the points of 3 Cents. More shots than both, that's true, but no buffs. More wounds base, yes. But for the same points - not really. In a 180-205pts area (depending on loadouts) squad of Cents will have 12 wounds, Termies - 15, Aggressors - 12. 1 hour ago, CCE1981 said: There are ways to buff them. They just lack core. Soulwarden would still give them a 5++. I think there are ways to make them work just gotta find them. As for buffing - I meant damage output buffing. Soulwarden and Narthecium auras will work as will Veil of Time, Psychic Fortress and Shield of Sanguinius psychic powers. Also Sergeant can be given Master-crafted for one of his weapons and that's I the only damage buff I found (I'd happily take it for his Siege Drills) Their main strength is persistence - number of wounds, 2+Save and AoC mean a dedicated AT weapons need to be directed against them and even then it's not guaranteed it will be possible to wipe the whole squad. And if thy are not killed outright, a single raise from the SP brings back 33% of the unit. I'm not saying they are bad. Siege drills attacking at S10 and -4AP and 3D (4D if you master-craft the Sergeant) are scary on their own. Especially since Cents are not the only thing in our army that wants to get to grips with the enemy. They also can turn-off overwatch/cause some MWs with a strat (only Infantry/bikers). Edited August 12, 2022 by Majkhel XeonDragon 1 Back to top Link to comment https://bolterandchainsword.com/topic/375425-centurion-devastator-or-centurion-assault-squad/#findComment-5856233 Share on other sites More sharing options...
Dont-Be-Haten Posted August 12, 2022 Share Posted August 12, 2022 Seems like 5 assault cents for under 300 points stock is a good investment. 20Ws that can be healed, revived looks pretty strong Maggotlord, Helias_Tancred and XeonDragon 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/375425-centurion-devastator-or-centurion-assault-squad/#findComment-5856243 Share on other sites More sharing options...
Tokugawa Posted August 15, 2022 Share Posted August 15, 2022 AP-4 and flat dmg3 is at a totally different threat level with "a power fist". You can ask any DG player you know to confirm it. Maggotlord and XeonDragon 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/375425-centurion-devastator-or-centurion-assault-squad/#findComment-5857083 Share on other sites More sharing options...
