Inquisitor_Lensoven Posted August 14, 2022 Share Posted August 14, 2022 I am not particularly good at painting cloth or anything, anyone know any good tutorials for capes? Link to comment https://bolterandchainsword.com/topic/375507-video-tutorial-for-capes/ Share on other sites More sharing options...
Grotsmasha Posted August 18, 2022 Share Posted August 18, 2022 I don't know of any good vids, and can only share what I've learned personally, BUT, the biggest improvement in my capes came when I moved to a poor mans "wet blending". By that I mean, painting the cape in the traditional, step-by-step (Base, Shade, Layer, Highlight) way, but not stopping to allow the paint to dry. My process. Spoiler Base 1 - This is the only colour I allow to dry as the shade will strip it right off. Shade - Heavy or light however you like it. Base 2 - 2nd coat base colour, dipping in and mixing with the shade about half way into the shade, leaving unmixed shade in the middle. Layer 1 Colour 1 - Same deal, paint halfway through the new base layer, but not all the way to the base/shade mix. Layer 2 Colour 2 - Same deal, paint halfway through the 1st colour layer, but not all the way through the previous mix mix. (This step could also act as your first highlight layer). Highlight 1 Colour 1 - Bottom of the cloak to 2/3rds the way up. Highlight 2 Colour 2 - Classic edge / corners only highlight. Check out this Trajaan Valoris, he's a commission piece I did, using this method, I went the extra step of adding the final highlight as a textured method vs. straight highlighting. and a more traditional Inquisitor Coteaz, andes 1 Back to top Link to comment https://bolterandchainsword.com/topic/375507-video-tutorial-for-capes/#findComment-5858135 Share on other sites More sharing options...
Guest Posted August 18, 2022 Share Posted August 18, 2022 Red Cloak - Warhammer TV - RedDarren Latham - Eliminator CamoMore Red - JuanHidalgo Here are some of the ones that have helped me. Link to comment https://bolterandchainsword.com/topic/375507-video-tutorial-for-capes/#findComment-5858219 Share on other sites More sharing options...
Rik Lightstar Posted August 18, 2022 Share Posted August 18, 2022 I don't have a video recommendation, but your mobile phone can be one of your best tools for cloth or for highlighting and shading any irregularly shaped object. You'll need: Some white paper Something to prop up the paper behind the miniature Something to prop your phone up with to avoid shaking Your miniature primed black Some reasonably strong lighting Get a picture: Set your miniature up on the paper with it bending up behind it so you have a white background for it Set up your phone on a stand or prop so that the miniature is central in the image and there is only white in the background Turn off your flash on your phone camera and set it to timer mode, 3 seconds is fine Take your picture Edit your image: Crop the image to size with just the miniature in and a small border around it Edit the brightness so you get some really stark contrast showing up You now have a reference image for how light naturally falls on the surface you're painting The pics I've taken were of the only model with lots of cloth I had handy and it took me less than 5 minutes to get them done and edited. You'll see that the shading in the recesses is very stark immediately beneath any fold with a gradient to the next fold. You can add in a specific light source with a torch or lamp so that the lighting comes from a particular direction, you can also play around with your primer colour and with adding a light zenithal highlight before you take the picture just to exaggerate the effect. Hope this comes in handy. Rik Mechanicus Tech-Support 1 Back to top Link to comment https://bolterandchainsword.com/topic/375507-video-tutorial-for-capes/#findComment-5858254 Share on other sites More sharing options...
Firedrake Cordova Posted August 25, 2022 Share Posted August 25, 2022 It's not specifically on capes, but Angel Giraldez's video on Mephiston might be along the lines of what you're looking for, as the model has a fairly prominent robe and cape? Link to comment https://bolterandchainsword.com/topic/375507-video-tutorial-for-capes/#findComment-5860682 Share on other sites More sharing options...
