Guest Posted August 15, 2022 Share Posted August 15, 2022 I know its not available rues wise but sometimes rule of cool is better. In a change of direction i plan on making my 3rd Company Gravis heavy. So I come asking about ideas to make a Gravis armoured Chaplain and Apothecary. Anyone did this? Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/ Share on other sites More sharing options...
Surreal Cruelty Posted August 15, 2022 Share Posted August 15, 2022 Depends on what chapter you are doing, and how complex you are interested in making them. I did an extremely simple Crimson Fist Gravis chaplain when Indomitus came out. Just didn't like the model as a captain. It's on my WIP log here. The crozius is just part of either a grey knight staff with a banner top swapped out for the skull. As for the Apothecary...I would just take the bits you want from the primaris apothecary kit. With some filing/sanding, the chirugeon bits on his back could be made to fit the gravis pack. Then just some hand swaps for the weapons. With all the upgrade kits out now, there's probably a lot more you can do with it too. Khornestar 1 Back to top Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/#findComment-5857481 Share on other sites More sharing options...
Khornestar Posted August 15, 2022 Share Posted August 15, 2022 (edited) I have a gravis apothecary on the back burner as a project, though that's not very helpful. :D As for ideas, I think simply doing some cutting and swapping with existing apothecary kits can get the job done. Some creative kitbashing is in order, for sure. Edited August 15, 2022 by Khornestar Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/#findComment-5857482 Share on other sites More sharing options...
Guest Posted August 15, 2022 Share Posted August 15, 2022 3 minutes ago, Khornestar said: I have a gravis apothecary on the back burner as a project, though that's not very helpful. :D As for ideas, I think simply doing some cutting and swapping with existing apothecary kits can get the job done. Some creative kitbashing is in order, for sure. 4 minutes ago, Surreal Cruelty said: Depends on what chapter you are doing, and how complex you are interested in making them. I did an extremely simple Crimson Fist Gravis chaplain when Indomitus came out. Just didn't like the model as a captain. It's on my WIP log here. The crozius is just part of either a grey knight staff with a banner top swapped out for the skull. As for the Apothecary...I would just take the bits you want from the primaris apothecary kit. With some filing/sanding, the chirugeon bits on his back could be made to fit the gravis pack. Then just some hand swaps for the weapons. With all the upgrade kits out now, there's probably a lot more you can do with it too. I have some ideas will keep it posted... I need to buy 4 characters lol... Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/#findComment-5857484 Share on other sites More sharing options...
Rik Lightstar Posted August 17, 2022 Share Posted August 17, 2022 The Grey Knights Paladins set has quite a lot of bits you could use and should be around the right size, A set of Apothecary bits, The Force Staff which could look like a suitable Crozius, Lots of Tilting Shields and Purity Seals, Some Tabard bits and a Book, A bunch of open and empty hands, I'd mix them with a Heavy Intercessors box. Once you count in the variety of other weapons you get in that Grey Knights box I think you could make a fair amount of your Company Command out of them. I'd run them as the Terminator equivalents where possible especially as you'll have all those wrist mountable Storm Bolters Captain with Thunder Hammer (using the Nemesis Hammer) Chaplain (as above) Librarian (use any of the Force Weapons and an appropriate head) Apothecary (as above) Captain with *Relic Blade* (using the any of the Force Weapons, I like the idea of the 2 handed Force Halberd for this if you can make it fit) Rik Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/#findComment-5857951 Share on other sites More sharing options...
KJB Posted August 17, 2022 Share Posted August 17, 2022 (edited) Here are 2 I did a while ago, I'll see if I can remember what bits I used... Bodies are both from the Aggressor kit Chaplains arms are from Feirros Crozius head from the Bike Chaplain Narthecium and vials are from the Deathwing terminator kit Bionic bolt pistol arm is from the Eradicator box Head with Bionic eye from the Heavy Intercessor box Apothecary bits on the backpack are from the Primaris Apothecary Edited August 17, 2022 by KJB LameBeard, Rik Lightstar, Arkhanist and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/#findComment-5857955 Share on other sites More sharing options...
Guest Posted August 17, 2022 Share Posted August 17, 2022 10 minutes ago, KJB said: Here are 2 I did a while ago, I'll see if I can remember what bits I used... Bodies are both from the Aggressor kit Chaplains arms are from Feirros Crozius head from the Bike Chaplain Narthecium and vials are from the Deathwing terminator kit Bionic bolt pistol arm is from the Eradicator box Head with Bionic eye from the Heavy Intercessor box Apothecary bits on the backpack are from the Primaris Apothecary I found this too... I do like them both... So I think I need some GK bits like the Narthecium. Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/#findComment-5857958 Share on other sites More sharing options...
Guest Posted August 18, 2022 Share Posted August 18, 2022 Here is my Chaplain offerings.... I need to do something about the sword, and not 100% sold on Pistol. Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/#findComment-5858349 Share on other sites More sharing options...
Guest Triszin Posted August 18, 2022 Share Posted August 18, 2022 Rad. I've found I like the normal marine shoulder pads over the gravis pads. You should try it out to see if you like the silhouette more Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/#findComment-5858358 Share on other sites More sharing options...
Guest Posted August 18, 2022 Share Posted August 18, 2022 3 minutes ago, Triszin said: Rad. I've found I like the normal marine shoulder pads over the gravis pads. You should try it out to see if you like the silhouette more The pad is temp till I fine something suitable. Just not sure what needs a skull type feeling. Link to comment https://bolterandchainsword.com/topic/375526-gravis-chaplain-apothecary/#findComment-5858360 Share on other sites More sharing options...
