lansalt Posted August 19, 2022 Share Posted August 19, 2022 I was trying to find posts talking about Iron Warriors Dominators when I noticed that searching for "Dominators", both with and without double quotes return a lot of posts with dominant, dominance, dominated, etc. burying the actual content about Dominators. I've found no way to tell the the search function to only return posts with "dominators" inside. Seems like a bug to me, but I would be happy to be proven wrong and be told how to do it if there's a way. Link to comment https://bolterandchainsword.com/topic/375575-searching-for-exact-words-doesnt-work/ Share on other sites More sharing options...
Grotsmasha Posted August 20, 2022 Share Posted August 20, 2022 I've found the best way to search the B&C is with Google, as it DOES do all that fancy stuff. Start your search withe "site:bolterand chainsword.com" than a space, then add all the fancy stuff to really get a precise search. This will also help finding Member content that has become dissociated with them lansalt 1 Back to top Link to comment https://bolterandchainsword.com/topic/375575-searching-for-exact-words-doesnt-work/#findComment-5858753 Share on other sites More sharing options...
lansalt Posted August 20, 2022 Author Share Posted August 20, 2022 I now, I use google a lot but its results are almost never in chronological order unlike the B&C search, so in this case I got a mess of "Dominators" mentions from even before the actual IW unit was released. I was just trying to find info about them with the new HH 2.0 rules. Link to comment https://bolterandchainsword.com/topic/375575-searching-for-exact-words-doesnt-work/#findComment-5858757 Share on other sites More sharing options...
Grotsmasha Posted August 20, 2022 Share Posted August 20, 2022 I don't know it off the top my head, but I'm *sure* there's a date range thingy.... Link to comment https://bolterandchainsword.com/topic/375575-searching-for-exact-words-doesnt-work/#findComment-5858779 Share on other sites More sharing options...
sibomots Posted August 21, 2022 Share Posted August 21, 2022 The search is controlled by Elastic Search. It may be trying to do you a favor but apparently it is not successful. I will look at the parameters to control search. Link to comment https://bolterandchainsword.com/topic/375575-searching-for-exact-words-doesnt-work/#findComment-5858961 Share on other sites More sharing options...
sibomots Posted August 22, 2022 Share Posted August 22, 2022 I've posted the question to the IPS team https://invisioncommunity.com/forums/topic/468919-ips-471-and-elasticsearch-7174-precise-exact-match-vs-loose-match/ I'll follow up if I get response and a working solution to the problem. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/375575-searching-for-exact-words-doesnt-work/#findComment-5859613 Share on other sites More sharing options...
