Greenmon Posted September 2, 2022 Share Posted September 2, 2022 Okay, so first I put down my model and scatter it. If it lands 1” away from enemies or impassable terrain its fine, if not then my opponent places the model within 18” of the scattered point. My first question is about the first paragraph of pg 311: “Once the model’s final position has been decided, the remainder of the unit may be deployed anywhere that is within unit coherency and more than 1" from any enemy model or piece of Impassable Terrain. Any models that cannot be placed are removed as casualties.” 1. 1. Who places the remaining models of the unit? Do I only place them when my deepstriking model doesn’t scatter within 1” of enemies or impassable terrain? Does my opponent place them when he relocates them within 18”, or do I place them in both instances? The text doesn't mention which player places the remining models. 2. Can I make a line of models in coherency towards the next enemy unit? 2. It says the unit must be placed within unit coherency and 1” away from enemies and impassable terrain, but there is no maximum distance I can place those models. So could I just line them up in maximum unit coherency towards my enemy like in the following picture? Follow Up-Question 2.5: If my opponent places the rest of my unit when he relocates the deepstrike, could he do a similar thing and make a line towards my own battlefield edge? The next part of the rules explains the difference between a disordered and ordered deepstrike: “Once this first unit has been deployed, roll a D6. On the roll of a ‘1’, the Deep Strike Assault is Disordered, and the opposing player may deploy each other unit in the Deep Strike Assault anywhere within 24" of the first unit without scattering, though no model may be within 1" of an enemy model or within Impassable Terrain. If the roll is a ‘2’ or higher, then the controlling player deploys each other unit anywhere within 12" of the first, though no model may be within 1" of an enemy model or within Impassable Terrain.” . 3. If for example I don’t roll a disordered Assault result, the text says that the unit must be placed within 12” of the first unit, but it doesn`t say “wholly within”. So could I place a second unit like in the following picture? 4. If for the 1. Question the answer is that my opponent places my models when he places the scattered first model, and in the case of an disordered result he can place my 2. Unit within 24”, could he do the following? Because for our gaming group this is all “Rules as Written”, but probably not “Rules as Intended” so my gaming group would probably homebrew this. Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/ Share on other sites More sharing options...
Solution Cactus Posted September 2, 2022 Solution Share Posted September 2, 2022 1. I think we can assume that you deploy the models as the rule does not specify otherwise. The rest, yes I think you're correct. Compared with the 1 in 6 chance of a deep striking unit just being destroyed from earlier editions of 40k, I'll accept some deployment shenanigans if it means the models at least get deployed, and not necessarily all clumped up. 1 Back to top Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5863436 Share on other sites More sharing options...
Greenmon Posted September 2, 2022 Author Share Posted September 2, 2022 50 minutes ago, Cactus said: 1. I think we can assume that you deploy the models as the rule does not specify otherwise. The rest, yes I think you're correct. Compared with the 1 in 6 chance of a deep striking unit just being destroyed from earlier editions of 40k, I'll accept some deployment shenanigans if it means the models at least get deployed, and not necessarily all clumped up. Tbh, I interpret the Paragraph for the 1. question more like that the player who placed the first model, places the rest of the unit too. 2 Back to top Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5863454 Share on other sites More sharing options...
Brother_Angelus Posted September 2, 2022 Share Posted September 2, 2022 All the placement shenanigans you've proposed are correct. There is a lot of flexibility in the positioning of deepstrikers now. It's somewhat offset by Intercept reactions but generally you can engineer a favourable drop by chaining a unit out. Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5863500 Share on other sites More sharing options...
Greenmon Posted September 2, 2022 Author Share Posted September 2, 2022 46 minutes ago, Brother_Angelus said: All the placement shenanigans you've proposed are correct. There is a lot of flexibility in the positioning of deepstrikers now. It's somewhat offset by Intercept reactions but generally you can engineer a favourable drop by chaining a unit out. It just seems so RNG -heavy (I am a new player so maybe its that). If I dont scatter into impassable terrain/enemy units and my assault isnt disordered, I could position myself in a way in which I could force pinning checks for most of my opponents army (especially with Skirmish units with 3“ unit coherency). If I do scatter and my opponent moves my deepstriking model, and then I roll a disordered assault, my opponent could place most of my deepstriking units within one of my table corners and I would need 1-2 turns to even reach him. 1-2 turns in which his units can shoot mine. And then the disordered assault chance can be increased to 1-3 by keeping a Master of Signals on the field. If my opponent keeps that model out of Line of Sight, I will have a hard time removing it before my Reserves arrive. Basically two rolls will determine the outcome of a large part of my strategy. Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5863515 Share on other sites More sharing options...
Slips Posted September 3, 2022 Share Posted September 3, 2022 Yeah, thats the inherent risk of Deepstriking my guy. If there was no downside to Deepstriking, then everyone would probably go out of their way to do it. 3 Back to top Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5863574 Share on other sites More sharing options...
D3L Posted September 3, 2022 Share Posted September 3, 2022 agreed with Slips it's a make or break option if you pull of a proper DSA, you're achieving much, but at high inherent risk check 'n' balances innit? Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5863584 Share on other sites More sharing options...
Greenmon Posted September 3, 2022 Author Share Posted September 3, 2022 Hmm, okay thanks. @D3L @Slips @Brother_Angelushow do you three interpret the first paragraph? Do I place the rest of my unit in both cases, or does my opponent place the rest of my unit if he placed the first model? Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5863603 Share on other sites More sharing options...
Slips Posted September 3, 2022 Share Posted September 3, 2022 (edited) They place the first model only since it doesnt say that your opponent deploys the rest of the unit as well. Edited September 3, 2022 by Slips 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5863706 Share on other sites More sharing options...
SkimaskMohawk Posted September 3, 2022 Share Posted September 3, 2022 It's probably not the intent, but ya, scattering into other units only allows your opponent to place the initial model. 1 Back to top Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5863734 Share on other sites More sharing options...
TheNineteenth Posted September 7, 2022 Share Posted September 7, 2022 On 9/3/2022 at 4:51 PM, SkimaskMohawk said: It's probably not the intent, but ya, scattering into other units only allows your opponent to place the initial model. Another ill thought rule with no ramifications considered. Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5864576 Share on other sites More sharing options...
SkimaskMohawk Posted September 7, 2022 Share Posted September 7, 2022 6 hours ago, TheNineteenth said: Another ill thought rule with no ramifications considered. It's possible. Or they might have many it to be less punitive than getting disrupted, as the placement distance is shorter when you scatter into stuff. Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5864643 Share on other sites More sharing options...
Lord Krungharr Posted September 7, 2022 Share Posted September 7, 2022 I am favoring a Flanking Assault for some units now but I'll try both next week and see what pans out. Link to comment https://bolterandchainsword.com/topic/375756-questions-about-deepstriking-and-its-sequence/#findComment-5864740 Share on other sites More sharing options...
