Brad911 Posted September 13, 2022 Share Posted September 13, 2022 (edited) Hi there. I'm trying to make a Deathwing themed list. I have my doubts about the options of the veteran squad and their dedicated transport and the choice of a second Proteus. What do you think ? + HQ : + Legion Praetor . Warlord, Marshal of the Crown . Terranic Greatsword Deathwing Companion Detachement . 2x Cytheron Pattern Aegis, Terranic Greatsword . 2x Cytheron Pattern Aegis, Calibanite Warblade . 2x Calibanite Warblade, Combi-Melta . 1x Bolter, Terranic Greatsword . Sergent : Bolter, Terranic Greatsword . Legion Vexilla Land Raider Proteus Centurion Cataphractii . Paladin of Hekatonystika . Volkite charger, Terranic Greatsword + ELITES : + Inner Circle Knights Cenobium . Reaper of Hosts . 5x Terranic Greatsword, Plasma Caster . Legion Vexilla Land Raider Proteus Terminator Cataphractii Squad . 2x Pair of lighting claws . 1x Combi-bolter, Power fist . 6x Combi-bolter, Power sword . Sergent : Combi-bolter, Thunder hammer . Legion Vexilla Land Raider Spartan Veteran Squad . 2x Plasma burner, chainsword . 2x Combi-Melta, chainsword . 2x Bolter, Power sword . 1x Pair of lighting claws . 2x Bolter, chainsword . Sergent : Artificer armour, Power fist . Legion vexilla, Nuncio-vox Rhino Transport Apothecary Contemptor Dreadnought Talon . 1x Gravis plasma canon, Gravis power fist w/plasma blaster + TROOPS : + Assault squad . 7x chainsword, bolt pistol . 2x Heavy chainsword, bolt pistol . sergent : Artificier armour, Pair of lighting claws Assault squad . 7x chainsword, bolt pistol . 2x Heavy chainsword, bolt pistol . Sergent : Artificier armour, Power fist, bolt pistol Of course all the entries are Deathwing except the contemptor which I hesitate to put in Ravenwing to gain movement. The preator with the deathwing companions in a proteus, the cataphractii (troop line1) in the spartan, the centurion joins the cenobium knights and goes to the second proteus. The apothecary joins the veterans (troop line 2). Edited September 13, 2022 by Brad911 Link to comment https://bolterandchainsword.com/topic/375865-3000-pts-da-pride-of-the-l%C3%A9gion/ Share on other sites More sharing options...
jaxom Posted September 24, 2022 Share Posted September 24, 2022 It could be worth finding the points to upgrade the Paetor's terranic greatblade to a paragon blade for a little more AP2 in melee without having to rely on rolling 5+. You have a lot of high Ld veteran stat line units, I recommend Seneschal of the Keys instead of Marshal of the Crown. You still get an extra Assault phase reaction, but instead of +1 Ld, you can turn your army's big charge turn into a nightmare. Your units would be hitting almost anything on a 2+ (except the Dreadnought and Assault Squad sergeants), and getting hit on 5+. Link to comment https://bolterandchainsword.com/topic/375865-3000-pts-da-pride-of-the-l%C3%A9gion/#findComment-5869288 Share on other sites More sharing options...
Brad911 Posted October 3, 2022 Author Share Posted October 3, 2022 Yes good idea in order to manage the 2+, I should be able to find the necessary points. For senechal of the key the gain is indeed more "impactful", on the other hand it seemed to me that it only worked with the squad joined by the warlord. Thanks for your advice. Link to comment https://bolterandchainsword.com/topic/375865-3000-pts-da-pride-of-the-l%C3%A9gion/#findComment-5871679 Share on other sites More sharing options...
