Hey!
New to oilpaints/washes and got some n00by questions for yall:
1. How long should I leave the model to dry before wiping off the excess oilwash?
2. Once excess is wiped of to a satisfactory result, how long do models need to dry before matt-sealing them?
3. Can I paint acrylics directly ontop oilwash, or do I need matt varnish in between?
Cheers!
https://bolterandchainsword.com/topic/376038-questions-about-oilwash/
1. depends on the effect you are after and how thin your wash is. I come in with a q tip or sponge in like 15 min to an hour or so after application.  I usually am batch applying so it is often just when I get done with applying the wash to a line of models and then going back and cleaning things up.
2. Oils take forever to properly cure.  I do a week myself but a few days should be ok.
3. You can paint on top.  The better cured the oil layer is the lower the risk of damage. I gone in for highlights very quickly after application with wash still wet in the recesses.  Don't recommend it but sometimes its crunch time!
4 hours ago, TheMarsian said:
Hey!
 - until its "matt" it will no longer be shiny about 30 mins really faster if you use a hair dryer.
- 24-48 hours by nature 2-3 if ive sped things up with a hairdryer
yes no need to varnish but i prefer to. Gloss then matt.
Cheers!
It really depends on how much you want to wipe off. Also remember that oils can always be reactivated with a little bit of thinner, so unless you've varnished the model and sealed the oil layer underneath you can theoretically mess with the oils indefinitely.
I'd give it a good few days to a week. Also depends on how thick the oil paint is. A thin wash will dry quicker than a denser one for instance.
You can! Once they're dry they're stable, just be sure you're not gonna use anymore thinner/oils afterwards.
Register a new account
Sign in
