The Scandinavian Posted October 6, 2022 Share Posted October 6, 2022 Hey guys, Pretty sure this is the appropriate place to post this. If not, I :cuss:ed up, and the Arbites will retroactively rule me a suicide per Inquisitorial mandate following my disappearance. Anyway, I recently finished work on a Python script that generates randomised space marine Chapters. Frankly, it's nothing fancy, and the code itself probably isn't particularly elegant, but it works. It even has a part that works, but I have no idea why. Making a wild guess that the machine spirit is responsible, and I must have done something to placate it. Anyway, initially I just made it for myself, but I eventually decided to have a go at sharing it with the rest of the 40k community, on the off chance that someone out there might be interested in something like this. It's rudimentary stuff, it just spits out a .txt file with a bunch of information about YOUR GUYS™ - founding date, combat doctrine, mutations, organisation, that sorta stuff. Use should be fairly straight-forward, especially if you consult the readme.https://github.com/TheScandinavian/ChapterCreator Dosjetka, Gamiel, Dark_Angel_Dragon85 and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/376129-space-marine-chapter-creator-script/ Share on other sites More sharing options...
The Scandinavian Posted June 24, 2023 Author Share Posted June 24, 2023 I'm back. After not touching the project for a while, I decided to return to it. Nothing major so far, but I've tidied it up and also added a rudimentary GUI. With that, I'm gonna return to obscurity. See you whenever I add something worth posting about.https://github.com/TheScandinavian/ChapterCreator Link to comment https://bolterandchainsword.com/topic/376129-space-marine-chapter-creator-script/#findComment-5964727 Share on other sites More sharing options...
The Scandinavian Posted June 27, 2023 Author Share Posted June 27, 2023 Quick update: The script is now an .exe. All this really means is that you no longer need Python installed to use it. Just run the .exe and you're in business. N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/376129-space-marine-chapter-creator-script/#findComment-5965718 Share on other sites More sharing options...
