Gryphon65 Posted October 6, 2022 Share Posted October 6, 2022 (edited) Been playing with the idea, just for giggles . Rite of war; serpents bane. HQ Corswain; warlord. Centurion; librarian Elites; 2x Apothecary ( attached to troop ), stormwing. Troop; 10 Tactical, Vex, N-vox, chainswords, stormwing. 10 Tactical, Vex, N-vox, chain bayonet, stormwing. 10 Tactical support, Volkite charger, rhino with dozer blade Fast attack 2x firewing Enigmatus with missile launcher, stasis missile 8 Seeker Squad, 4x combo-melts, 3 Combi-plasma, sgt plasma pistol, power fist, rhino, dozer blade, multi-melta. Heavy 10 Heavy support squad, missile launchers, stasis missiles, augury. 1 Vindicator laser destroyer, dozer blades, searchlight. Total 1998 pts Edited October 6, 2022 by Gryphon65 Link to comment https://bolterandchainsword.com/topic/376133-da-firewing-2000pts/ Share on other sites More sharing options...
Gryphon65 Posted October 7, 2022 Author Share Posted October 7, 2022 Not hopeful about the lack of comments, you have me worrying about this list now Link to comment https://bolterandchainsword.com/topic/376133-da-firewing-2000pts/#findComment-5872728 Share on other sites More sharing options...
WrathOfTheLion Posted October 7, 2022 Share Posted October 7, 2022 Do your compulsory troops need to have the Firewing trait for the Serpents Bane RoW? Don't have Liber Astartes in front of me to check. Link to comment https://bolterandchainsword.com/topic/376133-da-firewing-2000pts/#findComment-5872731 Share on other sites More sharing options...
Gryphon65 Posted October 7, 2022 Author Share Posted October 7, 2022 (edited) Long answer I’m afraid; Each type picks it’s own trait, the book states, “ all units composed entirely of models with the Legiones astartes (dark angel ) special rule must select a Hexagrammaton sub type, All models within a unit must have the same subtype”. Each subtype gets their own buffs ie shooting, combat with blade, wounds bonus or movement, regardless of RoW ! Plus if I give a line troop “stormwing” +1 to hit in shooting and chainswards, then attach an apothecary with “deathwing” +1 to hit in assault, it states “ at the start of a players turn any model under the players control include models with different Hexagrammaton subtypes the controlling player must select one of their subtypes whose benefits will be applied to the models in the unit until that start of the current players next turn”. so unit gets shooting buff from subtype, add deathwing Apothecary with another sub type, they get buff in assault when jumped on ! Edited October 7, 2022 by Gryphon65 Spell check keeps messing with me Link to comment https://bolterandchainsword.com/topic/376133-da-firewing-2000pts/#findComment-5872761 Share on other sites More sharing options...
tinpact Posted October 7, 2022 Share Posted October 7, 2022 Short answer: Quote All units selected as Troops choices in a Detachment using this Rite of War must have the Firewing Unit Sub-type Your Warlord also has to be Firewing, so either Corswain is out or it needs to be on your centurion. I don't think stasis missiles are really that good but I'd consider swapping at least one of the tactical squads for despoilers to take advantage of Concussive (you can give up to three of your troops choices Infiltrate). You might also want to split the missile launcher squad into two so you can target two units. If you had room, I'd see if you could squeeze in some Destroyers or Terminators and/or a Dreadnought. TheNineteenth and Allart01 2 Back to top Link to comment https://bolterandchainsword.com/topic/376133-da-firewing-2000pts/#findComment-5872767 Share on other sites More sharing options...
