INKS Posted October 7, 2022 Share Posted October 7, 2022 I have a unit with 2 shield custodes and 1 spear custodes. If that unit gets shot by say a lascannon. Can I choose to take it on the shield and make a save? Can I assign that the shield guys get hit first to protect the non shield guy as long as there are less than (in this case) 2 hits Link to comment https://bolterandchainsword.com/topic/376148-assigning-damage/ Share on other sites More sharing options...
Karhedron Posted October 7, 2022 Share Posted October 7, 2022 I think that is allowed, yes. The only thing to bear in mind is that if you have different saves in a unit, you have to declare who is taking the save before you roll. If you fail, it has to be that model that is removed. In the above example, if you fail the Shield save, it has to be Shield Guy that gets removed, not Spear Guy. Dr_Ruminahui and INKS 2 Back to top Link to comment https://bolterandchainsword.com/topic/376148-assigning-damage/#findComment-5872852 Share on other sites More sharing options...
INKS Posted October 7, 2022 Author Share Posted October 7, 2022 Perfect, thanks Link to comment https://bolterandchainsword.com/topic/376148-assigning-damage/#findComment-5872866 Share on other sites More sharing options...
Dr_Ruminahui Posted October 7, 2022 Share Posted October 7, 2022 As well, in 9th once you declare a model who is being allocated the attack, that model has to be allocated all attacks until either it is removed or that particular unit that is shooting it is finished shooting. So, no swapping back and forth between models to take the optimal save - at least, not until that model dies. Xenith, Karhedron, Kallas and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/376148-assigning-damage/#findComment-5872989 Share on other sites More sharing options...
INKS Posted October 7, 2022 Author Share Posted October 7, 2022 This makes sense. thank you Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/376148-assigning-damage/#findComment-5873016 Share on other sites More sharing options...
Blight1 Posted October 9, 2022 Share Posted October 9, 2022 Just to clarify it's allocate to that model until either it dies or the phase is over. So once you allocate to it you can't change that until the whole shooting phase is done. Your opponent can use this to "bait" you into allocating onto a model and then use a different type of gun that it's worse against. INKS, Dr_Ruminahui, BLACK BLŒ FLY and 1 other 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/376148-assigning-damage/#findComment-5873684 Share on other sites More sharing options...
