Beaky Brigade Posted November 15, 2022 Share Posted November 15, 2022 My beard is not long enough to know this, but can anyone explain why the MK1 Predator was originally plastic before being replaced with IMO uglier metal / plastic hybrid variants? Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/ Share on other sites More sharing options...
Magos Takatus Posted November 15, 2022 Share Posted November 15, 2022 I wish I knew. I owned one of each of one of those, the first in my Blood Angel Army and the second when I switched to Crimson Fists. The turret of the second looked positively Orky in comparison to every other variant of the Predator. Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884237 Share on other sites More sharing options...
Leonaides Posted November 15, 2022 Share Posted November 15, 2022 (edited) To ditch the og predator sprue, and concentrate on plastic rhino sprues plus upgrade parts. Same formula as the og whirlwind with a metal top hatch and launcher, and the vindicator with its metal front end and gun. That was their formula for russes, chimeras etc as well. Probably they realised that people were only buying 1 predator but 2-3 rhinos and it streamlined their stock and design process slightly. At a guess... (speaking as an owner of one og, one box turret, 1 dome turret and 2 baals with the newer plastic turret, I prefer the og) Edited November 15, 2022 by Leonaides Beaky Brigade and N1SB 2 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884247 Share on other sites More sharing options...
Noserenda Posted November 15, 2022 Share Posted November 15, 2022 It was a change of direction, they moved from plastic only kits to hybrids for some reason, and a bunch of the old plastics kits went oop before the hybrids even came out (notably the land raider which skipped the whole hybrid era) which makes me think there was some specific issue because the cost of plastic kits is all up front, so it makes sense to keep them in production as long as possible. I dont think its a look thing either because on the Predator for example it all seems fine bar the bolter, which matched the rhino ones anyway which stayed around. As for why the metal predator turret/sponsons changed so much? I think its primarily it changing material so they couldnt build it the same way without it being big ole lumps of permanently falling off metal, well, more than they turned out to anyhow. :D Beaky Brigade and N1SB 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884248 Share on other sites More sharing options...
Beaky Brigade Posted November 15, 2022 Author Share Posted November 15, 2022 17 minutes ago, Noserenda said: It was a change of direction, they moved from plastic only kits to hybrids for some reason, and a bunch of the old plastics kits went oop before the hybrids even came out (notably the land raider which skipped the whole hybrid era) which makes me think there was some specific issue because the cost of plastic kits is all up front, so it makes sense to keep them in production as long as possible. I dont think its a look thing either because on the Predator for example it all seems fine bar the bolter, which matched the rhino ones anyway which stayed around. As for why the metal predator turret/sponsons changed so much? I think its primarily it changing material so they couldnt build it the same way without it being big ole lumps of permanently falling off metal, well, more than they turned out to anyhow. :D Not to derail my own thread, but wasn't there a legend that the MK1 Land Raider injection moulds were lost at sea while being shipped to a factory where GW did their North American production runs? N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884252 Share on other sites More sharing options...
Noserenda Posted November 15, 2022 Share Posted November 15, 2022 Sounds plausible tbh, whilst ive not read a savage tell all, all the polite interviews ive read mention or hint at some utter madness during that era :D Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884256 Share on other sites More sharing options...
Slave to Darkness Posted November 16, 2022 Share Posted November 16, 2022 The plastic pins holding the turret in place and lascannons in the sponsons were really thin, knock the tank too hard and you have fudged it. Lascannons and heavy bolters snapped off the Landraider easy back then as well. Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884277 Share on other sites More sharing options...
OttoVonAwesome Posted November 16, 2022 Share Posted November 16, 2022 Metal was cheap back then. Simple as that. Logistically it made more sense as GW was a smaller company and they couldn't make the molds in house and had to make kits for Guard and Eldar. The trend continued for sometime for kits like the original Land raider crusader and landspeeder variants and other variant kits. Logistics really was the only reason. Doghouse 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884291 Share on other sites More sharing options...
Magos Takatus Posted November 16, 2022 Share Posted November 16, 2022 (edited) I suppose another reason I didn't consider before was that it was about that time they introduced the Annihilator variant with a lascannon turret and heavy bolter sponsons. I imagine that the additional options in metal would be seen as an advance. Edited November 16, 2022 by Magos Takatus Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884312 Share on other sites More sharing options...
Doghouse Posted November 16, 2022 Share Posted November 16, 2022 9 hours ago, OttoVonAwesome said: Metal was cheap back then. Simple as that. Logistically it made more sense as GW was a smaller company and they couldn't make the molds in house and had to make kits for Guard and Eldar. The trend continued for sometime for kits like the original Land raider crusader and landspeeder variants and other variant kits. Logistics really was the only reason. Yeah that's pretty much it. I can't speak for the land raider or predator but I do remember talk of them outsourcing the rtb01 marines to Matchbox who made toy cars. I expect cheapness and more detail played a large part. Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884434 Share on other sites More sharing options...
Xenith Posted November 16, 2022 Share Posted November 16, 2022 Yea, I was thinking a combination of the tooling costs for plastic moulds, plus the speed and low cost of making metal moulds, combined with the low metal costs in the late 80's early 90s. GW kept a lot in metal and only really started to shy away from it with the insane tin price increase from Nov 2005 - Summer 2008 where it almost doubled in price. Doghouse, Beaky Brigade and N1SB 3 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5884437 Share on other sites More sharing options...
lhg033 Posted November 22, 2022 Share Posted November 22, 2022 On 11/15/2022 at 9:59 PM, Magos Takatus said: I wish I knew. I owned one of each of one of those, the first in my Blood Angel Army and the second when I switched to Crimson Fists. The turret of the second looked positively Orky in comparison to every other variant of the Predator. IIRC there were some pretty good Deff dread conversions at the time using the turrets for the body. I was always jealous of my mates having the plastic predator though a young, teen, me didnt dislike the metal ones either. I'd always assumed it was an issue with the molds that they stopped these HH2.0 is hitting me hard for wanting to get the 'new' versions of these. I'm taking the ork view, boys before toys! Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5886043 Share on other sites More sharing options...
AlexAbroad Posted November 22, 2022 Share Posted November 22, 2022 On 11/15/2022 at 11:39 PM, Beaky Brigade said: Not to derail my own thread, but wasn't there a legend that the MK1 Land Raider injection moulds were lost at sea while being shipped to a factory where GW did their North American production runs? I remember being told a variation of this by my local GW manager a year or so after it was discontinued. Although he said that the mould had been dropped and either damaged or outright broken beyond repair. Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5886140 Share on other sites More sharing options...
JeffJedi Posted November 22, 2022 Share Posted November 22, 2022 Not only the turret connection to the hull but the Autocannon itself was very breakable. The weapon mounts on the Landraider as well. Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5886157 Share on other sites More sharing options...
Toxichobbit Posted November 23, 2022 Share Posted November 23, 2022 That Imperial Fists predator is clearly a fake. It's grab rails haven't snapped and it still has all it's exhausts! ;) Magos Takatus, LameBeard, Trokair and 5 others 1 7 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5886558 Share on other sites More sharing options...
Dark Legionnare Posted November 24, 2022 Share Posted November 24, 2022 6 hours ago, Toxichobbit said: That Imperial Fists predator is clearly a fake. It's grab rails haven't snapped and it still has all it's exhausts! ;) Blast from the past... Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5886618 Share on other sites More sharing options...
Brother Carpenter Posted November 24, 2022 Share Posted November 24, 2022 On 11/22/2022 at 5:19 PM, AlexAbroad said: I remember being told a variation of this by my local GW manager a year or so after it was discontinued. Although he said that the mould had been dropped and either damaged or outright broken beyond repair. Yes this was what i was told as well. Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/376562-history-of-mk1-predator-kits/#findComment-5886662 Share on other sites More sharing options...
