Dont-Be-Haten Posted June 25, 2022 Share Posted June 25, 2022 Hey BT, By chance do you have any good resources for apps/army list builders for HH & AoD? Lord Krungharr 1 Back to top Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/ Share on other sites More sharing options...
Brother Tyler Posted November 22, 2022 Share Posted November 22, 2022 I'm sorry that I didn't see and reply to this sooner. No, I don't have any good apps. Note that I've split this off into its own topic for better visibility. Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5886111 Share on other sites More sharing options...
Noserenda Posted November 22, 2022 Share Posted November 22, 2022 Just battlescribe afaik? At least its being developed. Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5886138 Share on other sites More sharing options...
Rosterizer Posted November 22, 2022 Share Posted November 22, 2022 4 hours ago, Noserenda said: Just battlescribe afaik? At least its being developed. Yeah, for now you need Battlescribe (and the data is still in progress), or one of its derivatives like newrecruit.eu We have several people in the Rosterizer beta working on HH data ingestion, but that's not useful until we're out of closed beta so... see above. :) Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5886235 Share on other sites More sharing options...
SlickSamos Posted November 22, 2022 Share Posted November 22, 2022 (edited) Battlescribe is sufficient but not always correct. Good enough for playing around with ideas on your phone which is fine for me. Addendum: it is worth noting that the load times are miles better for the new rule set. So if that was something putting you off, I'd suggest giving it a second chance Edited November 22, 2022 by SlickSamos LameBeard and tinpact 2 Back to top Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5886262 Share on other sites More sharing options...
Brother Kraskor Posted November 25, 2022 Share Posted November 25, 2022 I've found battlescribe has improved a lot on accuracy, early on in the new edition it was close to unusable but now the reverse is true. Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5887143 Share on other sites More sharing options...
Varyn Posted November 27, 2022 Share Posted November 27, 2022 I think Quartermaster is the best option, although it is IOS only Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5887518 Share on other sites More sharing options...
General Zodd Posted November 29, 2022 Share Posted November 29, 2022 On 11/27/2022 at 4:58 PM, Varyn said: I think Quartermaster is the best option, although it is IOS only I tried using Quartermaster, noticed that the points for chaplains were wrong and didn’t have the patience to go through and double check everything, so I’ve been using BattleScribe ever since and it works fine. Not always the most intuitive interface, but it seems accurate at least! SlickSamos 1 Back to top Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888031 Share on other sites More sharing options...
Gorgoff Posted November 29, 2022 Share Posted November 29, 2022 19 minutes ago, General Zodd said: I tried using Quartermaster, noticed that the points for chaplains were wrong and didn’t have the patience to go through and double check everything, so I’ve been using BattleScribe ever since and it works fine. Not always the most intuitive interface, but it seems accurate at least! Agree. It isn't a rulebook though and shouldn't be used like that. But it does a decent job on creating army lists. SlickSamos and General Zodd 2 Back to top Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888035 Share on other sites More sharing options...
Burni Posted November 29, 2022 Share Posted November 29, 2022 On 11/27/2022 at 4:58 PM, Varyn said: I think Quartermaster is the best option, although it is IOS only I tried to keep with Quartermaster, as it UI was more my taste but it was buggy and incorrect too often. So ended up with Battlescribe and it's weird UI choices. Has Quartermaster gotten more stable? Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888049 Share on other sites More sharing options...
SlickSamos Posted November 29, 2022 Share Posted November 29, 2022 4 hours ago, General Zodd said: I tried using Quartermaster, noticed that the points for chaplains were wrong and didn’t have the patience to go through and double check everything Be aware that there are still points errors in Battlescribe (Whirlwind most outstanding example), not everything is listed in some lists and RoW mostly still in WIP. Also worth keeping in mind all of this praise for Battlescribe is focused around the Space Marines rather than the other factions... 4 hours ago, Gorgoff said: It isn't a rulebook though and shouldn't be used like that This Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888085 Share on other sites More sharing options...
Cactus Posted November 29, 2022 Share Posted November 29, 2022 I haven't used Battlescribe in a few years but when I did it was easy to edit simple errors like points values in your data files. SlickSamos and General Zodd 2 Back to top Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888090 Share on other sites More sharing options...
SlickSamos Posted November 29, 2022 Share Posted November 29, 2022 I hadn't thought of doing that! Hmm, that could be an interesting little project for the weekend. How does it work when the files update, would you have to re-enter your values? Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888112 Share on other sites More sharing options...
Cactus Posted November 29, 2022 Share Posted November 29, 2022 Essentially you are creating your own fork of the data file. Give it a new name so you know it's your version. Save a copy somewhere other than the folder that BS uses for data, so that if you do download new data from a repository it won't overwrite your only copy of your changes. I was doing this on a PC where file management is much easier than on a mobile device. Beware you might fall down the rabbit hole and start editing the data to only contain models you own, or changing how upgrades are presented because you think you've found a better way. SlickSamos and Rosterizer 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888119 Share on other sites More sharing options...
Sparika Posted November 30, 2022 Share Posted November 30, 2022 I started my Heresy journey thanks to Battlescribe. I did not have the book by that time (~2013) and scrolling to what I could read was really tedious. I made a ton of dream lists out of that tool but by the end of HHv1 it was becoming slow. I guess due to the sheer amount of rules and stats to load. Now, 10 years later Horus Heresy is translated in french and so I enjoy reading the book! I may try Battlescribe again but really haven't felt the need yet. Is it faster with the v2 data ? Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888481 Share on other sites More sharing options...
SlickSamos Posted November 30, 2022 Share Posted November 30, 2022 V2 is much faster and, more importantly, hasn't crashed for me yet.... I think it's faster as they split each legion as their own army so it wasn't having to deal with so much at once, but I have no real idea how it works Noserenda 1 Back to top Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888497 Share on other sites More sharing options...
Dont-Be-Haten Posted November 30, 2022 Author Share Posted November 30, 2022 On 11/22/2022 at 10:16 AM, Noserenda said: Just battlescribe afaik? At least its being developed. Back when I posted this, BS was in limbo or had been in limbo, and there was no volunteer updates for HH 2.0. There is now, but it still has loads of problems and wrong rules. Link to comment https://bolterandchainsword.com/topic/376632-horus-heresy-army-builder-apps/#findComment-5888516 Share on other sites More sharing options...
