Glute Posted November 27, 2022 Share Posted November 27, 2022 So in the new codex the Lasgun Array weapon no longer has any wording a requirement for a unit to be embarked in it to shoot with it. I think this is on purpose as the prior wording required a unit to have LASGUNS embarked in the transport. Not all units that could be in a transport have lasguns (Commisars, Commanders, etc.) So as it's worded right now - I'm going to play it as RAW and fire the Lasgun Array's even if no one is embarked in it. This could be a miss by GW but it appears to be an obvious omission. Then again -- it could be a FAQ item. Link to comment https://bolterandchainsword.com/topic/376686-9th-ed-chimera-lasgun-array-change/ Share on other sites More sharing options...
Inquisitor_Lensoven Posted November 27, 2022 Share Posted November 27, 2022 Looking at the datasheet I don’t see any mention of the vehicle needing a passenger to use the weapon 3 hours ago, Glute said: So in the new codex the Lasgun Array weapon no longer has any wording a requirement for a unit to be embarked in it to shoot with it. I think this is on purpose as the prior wording required a unit to have LASGUNS embarked in the transport. Not all units that could be in a transport have lasguns (Commisars, Commanders, etc.) So as it's worded right now - I'm going to play it as RAW and fire the Lasgun Array's even if no one is embarked in it. This could be a miss by GW but it appears to be an obvious omission. Then again -- it could be a FAQ item. I mean it seems like by the 41st millennium there’d be a remote way to fire such an array, even if it’s basically just 6 servitor brains plugged into each gun. Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/376686-9th-ed-chimera-lasgun-array-change/#findComment-5887614 Share on other sites More sharing options...
Santaclauswitz Posted November 27, 2022 Share Posted November 27, 2022 I just think it's a simplification of rules. It just makes the chimera a good transport. Even with born soldiers 12 not very buffable ap0 shots doesn't seem broken to me. The thing that I could see being nerfed is the regimental standard. Currently the rules state the buff aura is from the unit not just the model, same for the relic. So that's core units rerolling 1's to wound and potentially ignoring hit and wound modifiers from a unit of 5-9 bases. One of those bases could be an ogyrn! Each base gives a 6" aura as described above. I could see that being changed in an FAQ to the standard bearer itself. Sorry I know I've mentioned this before but I've a new found love of the command squad. It probably won't kill anything but it doesn't half make frfsrf a good alternative to take aim. Inquisitor_Lensoven and Emperor Ming 2 Back to top Link to comment https://bolterandchainsword.com/topic/376686-9th-ed-chimera-lasgun-array-change/#findComment-5887617 Share on other sites More sharing options...
jarms48 Posted November 27, 2022 Share Posted November 27, 2022 Can confirm. Chimera definitely doesn't need anyone inside anymore to fire. Which actually makes it a great target for that suppressing fire order. Inquisitor_Lensoven, Montford, MrKoolPants and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/376686-9th-ed-chimera-lasgun-array-change/#findComment-5887631 Share on other sites More sharing options...
