Cruor Vault Posted December 7, 2022 Share Posted December 7, 2022 Has anyone tried swapping the Proteus Explorator front plate with the Spartan's extended ramp? I have two conversions I am planning and I'm hoping it will be a simple matter of swapping parts between the two kits. I want to make a Spartan with the flat armored front plate from the Proteus kit. I'm planning a Proto-Terminus Ultra conversion for my Ultramarines and wanted to use the longer hull of the Spartan. At the same time I am hoping to put the extended front ramp assembly from the spartan onto the Proteus' hull to copy this silly conversion from back in the day. Link to comment https://bolterandchainsword.com/topic/376790-swapping-the-forward-plates-between-spartan-and-proteus/ Share on other sites More sharing options...
dickyelsdon Posted December 7, 2022 Share Posted December 7, 2022 The plastic spartan hull is wider than the pastic proteus hull. So would likely need some serious platicard work to achieve. Link to comment https://bolterandchainsword.com/topic/376790-swapping-the-forward-plates-between-spartan-and-proteus/#findComment-5890588 Share on other sites More sharing options...
LameBeard Posted December 7, 2022 Share Posted December 7, 2022 If you take out the word “silly” and replace with “majestic” or similar word I’ll give your post a like. SlickSamos, Doghouse, Pearson73 and 2 others 2 3 Back to top Link to comment https://bolterandchainsword.com/topic/376790-swapping-the-forward-plates-between-spartan-and-proteus/#findComment-5890591 Share on other sites More sharing options...
