happyslugger Posted December 10, 2022 Share Posted December 10, 2022 Hi folks, I've Managed to bag a LOC BNIB and just want to ask how you have built this? Doesn't look like the most magnet friendly model so is there a particular way to build it that would enable me to use it as a LOC and KAIROS without running into too many issues with people? Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/ Share on other sites More sharing options...
Closet Skeleton Posted December 10, 2022 Share Posted December 10, 2022 (edited) If you just build it as Kairos than I doubt most people would care if you use it as a regular Lord of Change. But I'd also suggest that with mutli-option kits sometimes its best to just make a choice and not worry about failing to get maximum option value out of an expensive purchase. You might find it more fulfiling to customise your model and write a name and backstory than in preparing for some potential future option where you made the wrong choice. I'm still saving up for my plastic LoC but I'm only going to magnetise the weapons and that's all I did with the other Greater Daemons with special character options because I had no intention of choosing a colour scheme that would fit those special characters and painting someone else's daemon would have limited by creativity. If you want to magnetise a model do it because you enjoy it not out of some unhealthy idea about optimising your investment in a hard to justify recreational purchase. Edited December 10, 2022 by Closet Skeleton apologist, TwinOcted, The Neverborn and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5891425 Share on other sites More sharing options...
happyslugger Posted December 10, 2022 Author Share Posted December 10, 2022 I have magnetised my GUO and various other models. I even kitbashed a Rotigus conversion out of the GUO bits and a glotkin (I was proud of it). I've got a fleabay maulerfeind on the way that I plan to magnetise, but if I can build it without the magnets it saves time. Was just thinking if there was a particular build that could pass as both then that would save me the worry. I've found a video on YT going over magnetising the model, so may have a look at that also. I don't play that much and not competitively so I suppose it doesn't make too much difference... Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5891444 Share on other sites More sharing options...
Progenitor Posted December 12, 2022 Share Posted December 12, 2022 On 12/10/2022 at 7:22 PM, Closet Skeleton said: If you just build it as Kairos than I doubt most people would care if you use it as a regular Lord of Change. This is the plan that I had with mine and that's what I did. happyslugger 1 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5891758 Share on other sites More sharing options...
happyslugger Posted December 12, 2022 Author Share Posted December 12, 2022 (edited) 4 hours ago, Progenitor said: This is the plan that I had with mine and that's what I did. Did you pick a particular paint scheme (official one) or go with your own? I will likely follow a youtube video and have seen two I like, one GW and the other TWG Edited December 12, 2022 by happyslugger Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5891775 Share on other sites More sharing options...
The Neverborn Posted December 13, 2022 Share Posted December 13, 2022 The GOU has a lot of large flat surfaces, it's probably one if the easiest miniatures to magantise available. Of the other 3 i'd probably say the LOC is about the hardest, specifically the head option as there's no real "neck" to work with despite the model having a very large neck. happyslugger 1 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5892011 Share on other sites More sharing options...
Progenitor Posted December 13, 2022 Share Posted December 13, 2022 On 12/12/2022 at 11:31 AM, happyslugger said: Did you pick a particular paint scheme (official one) or go with your own? Not got to that point yet. It was originally for the Disciples of Tzeentch and Chaos Daemons project to use the same models for both games, but that never came to pass. I've used him as Kairos with the new Daemons codex once but he's just boring grey plastic right now. I did ponder upon doing a Monochrome Tzeentch scheme as something different from what we normally get. happyslugger and Mithrilforge 2 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5892018 Share on other sites More sharing options...
happyslugger Posted December 13, 2022 Author Share Posted December 13, 2022 (edited) 1 hour ago, The Neverborn said: The GOU has a lot of large flat surfaces, it's probably one if the easiest miniatures to magantise available. Of the other 3 i'd probably say the LOC is about the hardest, specifically the head option as there's no real "neck" to work with despite the model having a very large neck. I found a video on YouTube but it looks a faff and I am not a competitive player, so will just build it up as fateweaver and proxy. 1 hour ago, Progenitor said: Not got to that point yet. It was originally for the Disciples of Tzeentch and Chaos Daemons project to use the same models for both games, but that never came to pass. I've used him as Kairos with the new Daemons codex once but he's just boring grey plastic right now. I did ponder upon doing a Monochrome Tzeentch scheme as something different from what we normally get. Ah okay. I'm working on my thousand sons at the moment, so mine won't get built for quite a while. I got a deal on it so thought why not as I have some nurgle and khorne daemons and belakor. TBH I don't play that much but I like to build and paint when I get the time. Edited December 13, 2022 by happyslugger Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5892039 Share on other sites More sharing options...
Mithrilforge Posted December 14, 2022 Share Posted December 14, 2022 If you do magnetise Him/It, please post em up so we can see and when you paint it as well Cheers, M. happyslugger 1 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5892409 Share on other sites More sharing options...
happyslugger Posted December 15, 2022 Author Share Posted December 15, 2022 Sure, will do. It will be a while though as working on my thousand sons over the Xmas period. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5892537 Share on other sites More sharing options...
Mithrilforge Posted December 15, 2022 Share Posted December 15, 2022 Well good luck over Christmas then Also when you finish those "Spirits in a full shell" make sure to put thousand sons in your Signature as another one of your armies... Cheers, M P.S. you saying that has reminded me, I need to get my Chaos daemons done over Christmas !! Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5892616 Share on other sites More sharing options...
happyslugger Posted April 5, 2023 Author Share Posted April 5, 2023 (edited) Well I've finished the thousand sons and Magnus now. I've painted up ten pink, blue and brimstone horrors, so just the LOC left. Would love to see some of your LOC models for inspiration :-) I think I'm just going to build it one way and forget magnetising it (unless it is easy) so just need to decide a paint scheme. seen a couple of YouTube videos which I could follow. I may just follow Duncan here: Edited April 5, 2023 by happyslugger Mithrilforge and Ulfast 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5929746 Share on other sites More sharing options...
INKS Posted April 6, 2023 Share Posted April 6, 2023 This is my LOC. I kind of wish I did him as Kairos. I think it's better to do that and then call it a LOC then do a LOC and call it Kairos. So at some point I'll have to buy the model again and make Kairos which I am not looking forward to. It was ok to build, and ok to paint. There are still some things like cloth that I could improve on but overall I am happy with him. The Neverborn, sitnam, Dr_Ruminahui and 4 others 5 2 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5930169 Share on other sites More sharing options...
Dr_Ruminahui Posted April 6, 2023 Share Posted April 6, 2023 I think he looks great - and yeah, I've heard that the cloth on this guy is pretty tricky. INKS 1 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5930232 Share on other sites More sharing options...
happyslugger Posted April 6, 2023 Author Share Posted April 6, 2023 I think he looks fab. The model wasn't the best to put together and one of the wings didn't fit 100% on mine not matter what I did. The legs and pelvic area were also a faff. I've built mine as Karios but am painting him similar to yours. I looked online and Reddit and most people don't care how he is built or what colour the model is. I've just finished painting Magnus and his red Wings, etc so fancied following Duncan's blue this time around. INKS and Mithrilforge 2 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5930240 Share on other sites More sharing options...
sitnam Posted April 6, 2023 Share Posted April 6, 2023 I agree, @INKS you did a great job. Since we’re showing off our prized birds: Spoiler INKS, Ulfast, Dr_Ruminahui and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5930388 Share on other sites More sharing options...
happyslugger Posted April 7, 2023 Author Share Posted April 7, 2023 (edited) Won't let me upload images as files too large. Edited April 7, 2023 by happyslugger Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5930962 Share on other sites More sharing options...
Dr_Ruminahui Posted April 8, 2023 Share Posted April 8, 2023 Have you tried uploading them to the gallery or a service like imgur first? That might fix the issue. happyslugger 1 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5931215 Share on other sites More sharing options...
happyslugger Posted April 8, 2023 Author Share Posted April 8, 2023 Will do / try later. Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5931282 Share on other sites More sharing options...
happyslugger Posted April 8, 2023 Author Share Posted April 8, 2023 Still WIP so see if these phone potato pictures work.. sitnam, Dr_Ruminahui and INKS 3 Back to top Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5931327 Share on other sites More sharing options...
Dr_Ruminahui Posted April 9, 2023 Share Posted April 9, 2023 They certainly do - it looks great. Link to comment https://bolterandchainsword.com/topic/376838-lord-of-change-model/#findComment-5931545 Share on other sites More sharing options...
