Valkyrion Posted December 17, 2022 Share Posted December 17, 2022 I think I've doing Brutal wrong. If a Contemptor Dreadnought with a Gravis Power Fist hits a tactical squad 3 times how many models can die? Link to comment https://bolterandchainsword.com/topic/376901-brutal/ Share on other sites More sharing options...
Solution Lord Marshal Posted December 17, 2022 Solution Share Posted December 17, 2022 (edited) Three, because excess wounds from Brutal don't spill over. Edited December 17, 2022 by Lord Marshal LameBeard, Blight1 and Valkyrion 3 Back to top Link to comment https://bolterandchainsword.com/topic/376901-brutal/#findComment-5893117 Share on other sites More sharing options...
Valkyrion Posted December 17, 2022 Author Share Posted December 17, 2022 I owe an opponent 6 marines then.... I think I just got so caught up in the internet proclaiming how good Contemptors are that I figured only removing 3 tactical marine hardly qualifies as being super powerful so it must be that 9 failed saves is 9 removed models because they only have 1 wound each so there is no excess to waste. What a silly sausage. Cactus, LameBeard, SlickSamos and 3 others 2 4 Back to top Link to comment https://bolterandchainsword.com/topic/376901-brutal/#findComment-5893119 Share on other sites More sharing options...
Xenith Posted December 19, 2022 Share Posted December 19, 2022 It's like damage in 40k - one model receives the wounding hit, then has to receive the damage from the attack (40k) or make 3 saves (heresy). Brutal 3 is very good as it means you're very likely to get through a 4+ invulnerable, or 3+ in the case of fists and sallies. It basically means that each wound from a dread fist is probably a dead model, regardless of whether you're a tactical marine or legin elite. Link to comment https://bolterandchainsword.com/topic/376901-brutal/#findComment-5893426 Share on other sites More sharing options...
Spagunk Posted December 19, 2022 Share Posted December 19, 2022 Brutal 3 just means you're also pasting terminators and veterans along with regular joes. It less about quantity and more about quality. The issue being that units likely to get wounds on a dreadnought are less likely to get attacks in before the dread does (PFist, THammers etc.). Brofist 1 Back to top Link to comment https://bolterandchainsword.com/topic/376901-brutal/#findComment-5893528 Share on other sites More sharing options...
Orange Knight Posted January 19, 2023 Share Posted January 19, 2023 On 12/17/2022 at 1:33 PM, Valkyrion said: I owe an opponent 6 marines then.... I think I just got so caught up in the internet proclaiming how good Contemptors are that I figured only removing 3 tactical marine hardly qualifies as being super powerful so it must be that 9 failed saves is 9 removed models because they only have 1 wound each so there is no excess to waste. What a silly sausage. For this reason it's better to keep the Contemptor away from larger squads. 10 Tactical Marines could potentially stall the Dreadnough for 3 - 4 turns in combat. Having Brutal, however, means that the Contemptor is extra effective at crushing vehicles and individual models that are powerful. BLACK BLŒ FLY 1 Back to top Link to comment https://bolterandchainsword.com/topic/376901-brutal/#findComment-5901261 Share on other sites More sharing options...
arnesh88 Posted January 19, 2023 Share Posted January 19, 2023 @Orange Knight I don't know if you meant that a contemptor with a fist is flexible enough to both break through vehicles and the brutal allowing it to be good vs non-vehicle models, or if you are saying that Brutal applies to armour pen rolls, because Brutal doesn't affect such rolls. I just wanted to clarify for other people. Gorgoff and Brofist 2 Back to top Link to comment https://bolterandchainsword.com/topic/376901-brutal/#findComment-5901277 Share on other sites More sharing options...
Vostroi Posted January 24, 2023 Share Posted January 24, 2023 Can non instant death brutal attacks cause more than one wound on a multiwound model per attack? Link to comment https://bolterandchainsword.com/topic/376901-brutal/#findComment-5902982 Share on other sites More sharing options...
MARK0SIAN Posted January 24, 2023 Share Posted January 24, 2023 42 minutes ago, Vostroi said: Can non instant death brutal attacks cause more than one wound on a multiwound model per attack? Yes. The model will lose a wound for each save it fails (or if the attack goes through the save). So if a model was hit and wounded with a brutal 3 attack they could lose 3 wounds if they fail all three subsequent saves. Link to comment https://bolterandchainsword.com/topic/376901-brutal/#findComment-5903000 Share on other sites More sharing options...
Valkyrion Posted January 25, 2023 Author Share Posted January 25, 2023 Yes, excess wounds are lost. Brutal 3 can kill a 3 wound model with non instant death attacks assuming failed/no saves. It can also only kill one 1 wound model with the same Brutal 3 attack. That was my brain fart in the first post! Link to comment https://bolterandchainsword.com/topic/376901-brutal/#findComment-5903342 Share on other sites More sharing options...
