happyslugger Posted December 17, 2022 Share Posted December 17, 2022 (edited) Hi folks I hope all is well. Anyone running a hellbrute and if so what loadout are you running? I'm contemplating adding one, but wonder if it best to run it as a long range anti tank / armour fire platform (las and ML) or something like a las / fist / hammer loadout? I don't play a lot (more of a collector and painter) but I do play against my son who has marines (ultras), Grey Knights and Imperial Knights.. Edited December 17, 2022 by happyslugger N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/376904-hellbrute/ Share on other sites More sharing options...
Karhedron Posted December 17, 2022 Share Posted December 17, 2022 MM + Fist is probably the way to go I think. Then you have something that can be a decent threat in the midfield in both shooting and melee. I like the fist best as it has a good balance between number of hits and hitting power. 3 Damage is a kind of sweet spot as you can one-shot elite infantry like Terminators and also pose a significant threat to vehicles. You can take a firepower loadout but the only ranged weapon for the left arm is the missile launcher which I find pretty underwhelming. I would much rather put that fist to good use and threaten to crush anything that gets too close. happyslugger, N1SB and WrathOfTheLion 3 Back to top Link to comment https://bolterandchainsword.com/topic/376904-hellbrute/#findComment-5893205 Share on other sites More sharing options...
dice4thedicegod Posted December 18, 2022 Share Posted December 18, 2022 (edited) Oops - thought it was in general CSM forum Edited December 18, 2022 by dice4thedicegod Link to comment https://bolterandchainsword.com/topic/376904-hellbrute/#findComment-5893237 Share on other sites More sharing options...
Karhedron Posted December 18, 2022 Share Posted December 18, 2022 To be fair, I would give the same advice regardless of Legion. Verbal Underbelly, happyslugger and WrathOfTheLion 3 Back to top Link to comment https://bolterandchainsword.com/topic/376904-hellbrute/#findComment-5893271 Share on other sites More sharing options...
WrathOfTheLion Posted December 18, 2022 Share Posted December 18, 2022 4 hours ago, Karhedron said: To be fair, I would give the same advice regardless of Legion. That's how I used mine in Black Legion, from the Helbrute sculpt from Dark Vengeance, which is a really awesome sculpt for push fit at the time. I don't think I'd change anything for the Thousand Sons I'm working on. Like most of Chaos, it gives nice access to a multimelta, which isn't readily available elsewhere. happyslugger 1 Back to top Link to comment https://bolterandchainsword.com/topic/376904-hellbrute/#findComment-5893302 Share on other sites More sharing options...
happyslugger Posted December 18, 2022 Author Share Posted December 18, 2022 (edited) I have three for my death guard. Two are as suggested and I forget what the third is, possibly LC and ML...it was one I converted. They were cheap eBay purchases of the Dark Vengeance model when ebay was flooded with them ages ago. Edited December 18, 2022 by happyslugger Link to comment https://bolterandchainsword.com/topic/376904-hellbrute/#findComment-5893332 Share on other sites More sharing options...
Xenith Posted December 22, 2022 Share Posted December 22, 2022 Adding my voice to multimelta + fist - the MM is really one of the standout weapons of 9th, and they're hard to get elsewhere in chaos armies. The dread will be a threat to anything and punch above it's points - they're marginally better as TSons as they gen an invuln also. happyslugger and Verbal Underbelly 2 Back to top Link to comment https://bolterandchainsword.com/topic/376904-hellbrute/#findComment-5894076 Share on other sites More sharing options...
