Inquisitor_Lensoven Posted January 16, 2023 Share Posted January 16, 2023 Just curious if anyone knows what the most common stats are for each stat category for weapons throughout the game. so most common number of shot. most common S most common AP most common damage Maybe even what percent of weapons have blast, and melta rules etc. Link to comment https://bolterandchainsword.com/topic/377188-most-common-of-each-stat-for-weapons/ Share on other sites More sharing options...
Xenith Posted January 16, 2023 Share Posted January 16, 2023 I don't think anyone has bothered to actually go through and work this out, but I'd assume it would be roughly bolter level, though to the tail end of 9th I'd assume the most common would be ap-1. So S4 AP-1 D1. You then have to calibrate that to the frequency of the weapons used. For tactical squad options, say you have bolter, meltagun, lascannon, plasma cannon, multimelta, etc. On paper, one of those weapons is S4 AP0 D1, the rest are S7-9, AP-3+, DD6 etc, this would give the false impression that strong weapons are in the majority, however in reality, those strong weapons are in a 1:4 ratio with bolters. MARK0SIAN 1 Back to top Link to comment https://bolterandchainsword.com/topic/377188-most-common-of-each-stat-for-weapons/#findComment-5900445 Share on other sites More sharing options...
MARK0SIAN Posted January 16, 2023 Share Posted January 16, 2023 Yeah I think Xenith is right, doing it on a weapon by weapon basis probably wouldn’t tell you much because you wouldn’t know the frequency that those weapons were used. You might find more useful info if you break it down by purely troops category and see what the most common basic stat is for the default troops weapon. Even then it wouldn’t really tell you much unless you knew whether people were taking those troops. The only way I can think where you’d get meaningful information is to break down the tournament lists from various events and look at the variety of weapons taken. That might give you an idea of what people tend to pack into their lists and what’s the most common in actual games rather just straight numerical information. Link to comment https://bolterandchainsword.com/topic/377188-most-common-of-each-stat-for-weapons/#findComment-5900461 Share on other sites More sharing options...
MegaVolt87 Posted January 28, 2023 Share Posted January 28, 2023 For dmg, D2 or D2+D3 dmg are pretty common. Link to comment https://bolterandchainsword.com/topic/377188-most-common-of-each-stat-for-weapons/#findComment-5904408 Share on other sites More sharing options...
