Dwango Posted January 22, 2023 Share Posted January 22, 2023 I'm looking to convert an Excindio Battle-automata, one of the 'men of iron'. It's roughly the same stats as a contemptor dread so I want it to be of similar size. I have an idea of using the legs of a canoptek reanimator and I have a contemptor and other necron bits I can use, including the rear carapace of a canoptek spyder. I can work out weapons etc. but really struggling with legs torso combination. Has anyone converted one of these or has any suggestions? I've hit a bit of a wall with it. Link to comment https://bolterandchainsword.com/topic/377274-in-need-of-some-inspiration-excindio-battle-automata/ Share on other sites More sharing options...
Solution Grotsmasha Posted January 22, 2023 Solution Share Posted January 22, 2023 What about Dunecrawler legs with Kastelan torso? Dwango 1 Back to top Link to comment https://bolterandchainsword.com/topic/377274-in-need-of-some-inspiration-excindio-battle-automata/#findComment-5902176 Share on other sites More sharing options...
Trokair Posted January 22, 2023 Share Posted January 22, 2023 (edited) Have a look at the Adeptus Titanicus range, a Reaver would be of a simmilar size, or the Porphyrion could make a good torso if you have spider legss from elsewhere. Edited January 23, 2023 by Trokair Xin Ceithan and Dwango 2 Back to top Link to comment https://bolterandchainsword.com/topic/377274-in-need-of-some-inspiration-excindio-battle-automata/#findComment-5902192 Share on other sites More sharing options...
Dwango Posted January 31, 2023 Author Share Posted January 31, 2023 Thank you both for your quick responses and suggestions. Sorry I've taken so long to reply!! I was hoping to be able to use something that I already own for the basis but I now realise I'm not going to get the look that I want (not that I fully know what that is!). I do like the idea of using the dune crawler legs Grot. This is something I'm going to explore. I have started on a dark mech force and have just purchased a few kastelans so could mock this up. I'm definitely going to look at the AT range as well. Something I had not considered. Grotsmasha and Trokair 2 Back to top Link to comment https://bolterandchainsword.com/topic/377274-in-need-of-some-inspiration-excindio-battle-automata/#findComment-5905560 Share on other sites More sharing options...
