TheWarmaster Posted January 31, 2023 Share Posted January 31, 2023 If I write a post, or a reply etc on mobile and I accidentally add an emoji.. how can I remove it? (On mobile!) Link to comment https://bolterandchainsword.com/topic/377397-how-to-remove-an-emoji-on-mobile/ Share on other sites More sharing options...
Brother Tyler Posted January 31, 2023 Share Posted January 31, 2023 I just use the delete key to remove an emoji while on a mobile device. I just tested it on the B&C and it worked. I have an Android device. Does your mobile device keyboard have the delete key? BLACK BLŒ FLY 1 Back to top Link to comment https://bolterandchainsword.com/topic/377397-how-to-remove-an-emoji-on-mobile/#findComment-5905518 Share on other sites More sharing options...
pawl Posted January 31, 2023 Share Posted January 31, 2023 I have the same problem, as it happens. When I forget and try to use an emoji in a post I end up having to duplicate the page, then hard refresh the duplicate to remove the draft. I then copy and paste from one window to another, remove the emoji and post. For some reason the delete key doesn't seem to work on them for me. I'll take a video later to show it. Link to comment https://bolterandchainsword.com/topic/377397-how-to-remove-an-emoji-on-mobile/#findComment-5905530 Share on other sites More sharing options...
Brother Tyler Posted February 1, 2023 Share Posted February 1, 2023 For those of you that are experiencing this problem: what devices/browsers (and their versions) are you using? Link to comment https://bolterandchainsword.com/topic/377397-how-to-remove-an-emoji-on-mobile/#findComment-5905697 Share on other sites More sharing options...
pawl Posted February 1, 2023 Share Posted February 1, 2023 (edited) Samsung Galaxy S22 Ultra Firefox 109.1.1 and Chrome 109.0.5414.117 https://i.imgur.com/ro52MA6.mp4 Edit: its worth noting that before you try and send the post the emoji can be deleted. Edited February 1, 2023 by pawl Link to comment https://bolterandchainsword.com/topic/377397-how-to-remove-an-emoji-on-mobile/#findComment-5905809 Share on other sites More sharing options...
Grotsmasha Posted February 5, 2023 Share Posted February 5, 2023 I'm on Google Pixel 7 Pro Chrome 109.0.5414.117 The error occurs AFTER trying to Submit the post, it will spit an error and the emoji is no longer selectable, or deletable, I've encountered this one myself. The only way I've found is to close the application, and start again because there is some sort of "post memory" that happens if I dont. Link to comment https://bolterandchainsword.com/topic/377397-how-to-remove-an-emoji-on-mobile/#findComment-5906822 Share on other sites More sharing options...
pawl Posted February 5, 2023 Share Posted February 5, 2023 15 hours ago, Grotsmasha said: I'm on Google Pixel 7 Pro Chrome 109.0.5414.117 The error occurs AFTER trying to Submit the post, it will spit an error and the emoji is no longer selectable, or deletable, I've encountered this one myself. The only way I've found is to close the application, and start again because there is some sort of "post memory" that happens if I dont. If you reload it usually gives you the option to clear the saved post, which is what I tend to do. Link to comment https://bolterandchainsword.com/topic/377397-how-to-remove-an-emoji-on-mobile/#findComment-5907041 Share on other sites More sharing options...
