Valkyrion Posted March 10, 2023 Share Posted March 10, 2023 You have around 500 points to spend on tanks, up to and including Typhon and Cerberus. What do you buy to kill; 1) Standard infantry (T4, 1 wound, 3+ save) 2) elite infantry (e.g, 2+ save, or multi-wound, or T5 etc) 3) Dreadnoughts 4) other tanks 5) super heavy vehicles and knights 1) 4 Scorpius 2) 4 Scorpius/2 Arcus 3) 3 Neutron Blaster Predators? Concussive and Shock Pulse for WS and Snap Shots 4) 3 Melta Predators 5) Cerberus? Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/ Share on other sites More sharing options...
Mandragola Posted March 10, 2023 Share Posted March 10, 2023 Well those are some seriously varied options. Personally I think you'll cover most bases with melta predators. They've got a respectably high rate of fire with an excellent anti-pretty-much-anything profile. They'll instant kill MEQ stuff, strip wounds of Custodes and even provide a serious threat to things like Spartans if they come within 18" (or a lot more than that, given the predator's speed). The Neutron laser seems vastly worse to me. One shot, not twin-linked just seems like an extremely easy way to fail. It's just a bad vehicle in my opinion, in any scenario. The Arcus is great for killing infantry and dreadnoughts but not heavy vehicles. Point for point I think I prefer the Predators because they're more versatile. A Scorpius is an entirely different proposition. By all means sit one of these behind your lines. But it's more a disruptor than a killer. It will kill models and occasionally pin stuff but won't tend to wipe out squads and isn't much help against hard targets. The Cerberus is good against hard targets and it's quite tough. It's very hard to kill at range and can suppress stuff. It isn't as killy as equivalent points of predators though. Lord Krungharr 1 Back to top Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5918473 Share on other sites More sharing options...
Valkyrion Posted March 10, 2023 Author Share Posted March 10, 2023 @Mandragola I was intending for each list to have a different answer, not one 500 selection to cover all bases - sorry if that was unclear! Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5918475 Share on other sites More sharing options...
SkimaskMohawk Posted March 10, 2023 Share Posted March 10, 2023 1 hour ago, Mandragola said: A Scorpius is an entirely different proposition. By all means sit one of these behind your lines. But it's more a disruptor than a killer. It will kill models and occasionally pin stuff but won't tend to wipe out squads and isn't much help against hard targets. The Scorpius only needs to hit 4 models to average the same amount of ap2 wounds as the melta pred. Obviously single models only take 1 hit, but against units it certainly is a killer. Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5918492 Share on other sites More sharing options...
arnesh88 Posted March 10, 2023 Share Posted March 10, 2023 10 Rhinos Hfran Morkai and Lord Krungharr 2 Back to top Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5918507 Share on other sites More sharing options...
Dont-Be-Haten Posted March 11, 2023 Share Posted March 11, 2023 Typhon siege tank! Scorpius is great for TEQ. Lord Krungharr 1 Back to top Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5918563 Share on other sites More sharing options...
Lord Krungharr Posted March 12, 2023 Share Posted March 12, 2023 I'd probably go with 5 javelin speeders w las and multimeltas over any tanks, though that's 525 points. Guess one could be barebones. They can hit tanks, terminators, and absorb overwatch for charges. Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5918777 Share on other sites More sharing options...
Hfran Morkai Posted March 12, 2023 Share Posted March 12, 2023 On 3/10/2023 at 7:04 PM, arnesh88 said: 10 Rhinos What would you do with your remaining 150 points? Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5918793 Share on other sites More sharing options...
General Zodd Posted March 12, 2023 Share Posted March 12, 2023 4 hours ago, Hfran Morkai said: What would you do with your remaining 150 points? Four more Rhinos? Xenith and Gorgoff 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5918810 Share on other sites More sharing options...
Xenith Posted March 31, 2023 Share Posted March 31, 2023 1) Standard infantry (T4, 1 wound, 3+ save) - 2x Punisher w/4x heavy bolters. That's 36 S6 shell shock shots and 32 heavy bolter shots with 100pts left over. 2) elite infantry (e.g, 2+ save, or multi-wound, or T5 etc) 3x melta/las preds, or 2x arcus 3) Dreadnoughts 3x melta/las preds, or 2x arcus or melta/Las Kratos with flare 4) other tanks 3x melta/las preds as they won't get return fired. 5) super heavy vehicles and knights 3x melta/las preds Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5927579 Share on other sites More sharing options...
Gorgoff Posted March 31, 2023 Share Posted March 31, 2023 Try saying Shell Shock shots three times in a row as fast as you can. Link to comment https://bolterandchainsword.com/topic/377859-500-points-on-tanks/#findComment-5927605 Share on other sites More sharing options...
