Orange Knight Posted March 15, 2023 Share Posted March 15, 2023 I can't seem to find it on the website, and perhaps I have the name wrong or it was updated? If it's no longer sold, what is a good alternative that people are using? Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/ Share on other sites More sharing options...
Karhedron Posted March 15, 2023 Share Posted March 15, 2023 I haven't seen it lately. I have switched to using Halfords car lacquer. You can get it in either matt or satin finish depending on your preference. Satin Matt Orange Knight 1 Back to top Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920139 Share on other sites More sharing options...
Solution Firedrake Cordova Posted March 15, 2023 Solution Share Posted March 15, 2023 Wasn't it replaced with Munitorum Varnish? Tale of Painters has a review on it, if it's any help. I've been happy with the Vallejo polyurethane varnishes (e.g. 26.652), but you do need an airbrush so probably not that much help! (they also do an aerosol version of it, but I haven't tried that) Mithrilforge, Helias_Tancred and Orange Knight 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920140 Share on other sites More sharing options...
Orange Knight Posted March 15, 2023 Author Share Posted March 15, 2023 Thanks guys! Much appreciate the quick feedback! Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920232 Share on other sites More sharing options...
Sir Clausel Posted March 15, 2023 Share Posted March 15, 2023 As someone who has used both then Munitorom varnish is a little more matt. I really like it as a standard overall varnish. Good protection and look. And only one time i have had a problem with misting Firedrake Cordova and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920263 Share on other sites More sharing options...
Grotsmasha Posted March 16, 2023 Share Posted March 16, 2023 I use Munitorum Varnish for all of my Commission work and have yet to have a n issue. Firedrake Cordova and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920361 Share on other sites More sharing options...
OttoVonAwesome Posted March 16, 2023 Share Posted March 16, 2023 Ideally any matte varnish used with airbrush with satin, gloss and ultramatte used to achieve different finishes for different surfaces ie metals, cloths but if it's gotta be a spray testors dullcote next best thing. I started using the Vallejo polyeurethane ones recently and can never go back. Mithrilforge and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920381 Share on other sites More sharing options...
Xenith Posted March 16, 2023 Share Posted March 16, 2023 (edited) I recall that the old purity seal varnish had a lot of issues with frosting or generally wrecking models, so it wasn't actually sold for that long before getting replaced with munitorum in maybe 2014, last time they redid the main paint range? I have a can of it that I've been too afraid to use once I'd seen the reviews online. Edited March 16, 2023 by Xenith Helias_Tancred and Trokair 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920461 Share on other sites More sharing options...
Orange Knight Posted March 17, 2023 Author Share Posted March 17, 2023 I actually got hold of the Munitorum Varnish spray yesterday from a local GW have used it on a few models. It's excellent. Absolutely no complaint. Thanks again everyone, I would have gone for the 3rd party spray if it hadn't been available. Mithrilforge and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920968 Share on other sites More sharing options...
WrathOfTheLion Posted March 17, 2023 Share Posted March 17, 2023 (edited) I quite like the finish Munitorum Varnish gives. It will frost up on you if you put too much on. You can always do a second coat, so patience will fix that. I think it might frost up in more humid temperatures? I never spray over 80% humidity, and try to go a decent bit lower than that to spray varnish. I'm in the deep south so I can't be too picky on humidity though. It also will look weird if you use stormshield or a matte varnish to seal in decals, the two matte varnishes interact weirdly when applied over each other. So I switched to just gloss varnish again for that, the munitorum will take the finish down to the same. To make it really blend in, I tested airbrushing a satin varnish then moving to munitorum on my most recent tank, and that worked really well to blend the glossy part back in. You could probably achieve the same by just making a brush-on satin by mixing some stormshield with the ardcoat. Edited March 17, 2023 by WrathOfTheLion Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920980 Share on other sites More sharing options...
Firedrake Cordova Posted March 17, 2023 Share Posted March 17, 2023 37 minutes ago, Orange Knight said: I actually got hold of the Munitorum Varnish spray yesterday from a local GW have used it on a few models. It's excellent. Absolutely no complaint. Glad to hear it! 19 minutes ago, WrathOfTheLion said: It will frost up on you if you put too much on...I think it might frost up in more humid temperatures? I think aerosols are quite sensitive to temperature and humidity because of the way it interacts with the propellant. I've seen some people advocating putting the can in hot water to warm the propellent up prior to spraying. Artis Opus also have a video on primers, but it's applicable to aerosol varnishes too in some respects. Xenith and Mithrilforge 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5920992 Share on other sites More sharing options...
Mithrilforge Posted March 18, 2023 Share Posted March 18, 2023 On 3/18/2023 at 12:00 AM, Firedrake Cordova said: Glad to hear it! I think aerosols are quite sensitive to temperature and humidity because of the way it interacts with the propellant. I've seen some people “advocating putting the can in hot water to warm the propellent up prior to spraying.” This, I always put my spray into the sink with medium hot water for about 5 mins and it sprays on super smooth!, never had a problem with any spray after doing this method…even with GW’s old white spray !! M. WrathOfTheLion, Firedrake Cordova and Bryan Blaire 3 Back to top Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5921472 Share on other sites More sharing options...
lhg033 Posted March 20, 2023 Share Posted March 20, 2023 I switched to brush on varnish for my orks following the clouding issues from one of the GW spray varnishes. Before this I only even had an issue once with a spray very early on - skull white from a bit to far away going chalky on some guardians many, many year ago. I'm generally pretty careful with sprays ever since then so was crushed when varnishing messed up about 20 of my orks. It'd have been one thing if it was an undercoat - but this was after a lot of effort to actually paint models which isnt always easy for me to get the umph to do. Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5921877 Share on other sites More sharing options...
Evil Eye Posted March 22, 2023 Share Posted March 22, 2023 I still have a nearly full can of Purity Seal. I tried it out on something unrelated and it actually worked quite well. Definitely satin rather than matte, but honestly I don't mind satin finishes. Link to comment https://bolterandchainsword.com/topic/377924-what-happened-to-the-purity-seal-spray-from-gw/#findComment-5922500 Share on other sites More sharing options...
