yan Posted March 18, 2023 Share Posted March 18, 2023 So last night i played a game and wanted to charge my terminators into a beastboss on squigosaur, wich was behind a building like 1” from the wall. So he was to far to fight trough the wall and to close to fit a base in between the character and the wall. Is it correct that i had to make the charge around the building? I remember there were some updates on this rule which got removed again right? so im not sure anymore 1 Back to top Link to comment https://bolterandchainsword.com/topic/377959-charging-into-buildings/ Share on other sites More sharing options...
Emperor Ming Posted March 19, 2023 Share Posted March 19, 2023 You are correct, models have to go around if they cant go through or there's not enough room to fit Gw did try and patch this a while ago by making engagement range of ruins 2 inches. But that created more problems than it solved and was reversed. 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/377959-charging-into-buildings/#findComment-5921489 Share on other sites More sharing options...
