yan Posted March 20, 2023 Share Posted March 20, 2023 So here’s another question. Can you do an heroic intervention if your enemy didn’t make a charge move that turn? Link to comment https://bolterandchainsword.com/topic/377976-heroic-intervention-without-charges/ Share on other sites More sharing options...
Jolemai Posted March 20, 2023 Share Posted March 20, 2023 Yes, it's a separate step during the charge phase found in the rulebook. Emperor Ming, Kallas, Xenith and 1 other 1 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/377976-heroic-intervention-without-charges/#findComment-5922012 Share on other sites More sharing options...
Xenith Posted March 21, 2023 Share Posted March 21, 2023 16 hours ago, yan said: So here’s another question. Can you do an heroic intervention if your enemy didn’t make a charge move that turn? As above, it gives you an option in case your opponent does something like moving to within 1" of your lines and stopping there, blocking your movement. Link to comment https://bolterandchainsword.com/topic/377976-heroic-intervention-without-charges/#findComment-5922215 Share on other sites More sharing options...
yan Posted March 21, 2023 Author Share Posted March 21, 2023 His argument was that, because there where no charges, there was no charge phase. But thats then incorrect. Thanks for clearing this up! Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/377976-heroic-intervention-without-charges/#findComment-5922276 Share on other sites More sharing options...
Jolemai Posted March 21, 2023 Share Posted March 21, 2023 Just because nothing happens in a particular phase, doesn't mean there's no phase. Furthermore, the Charge Phase is broken down into two steps: Charges Heroic Interventions You follow it sequentially like any other phase and skip any step if need be. yan, Kallas and Emperor Ming 3 Back to top Link to comment https://bolterandchainsword.com/topic/377976-heroic-intervention-without-charges/#findComment-5922286 Share on other sites More sharing options...
Lord_Ikka Posted March 22, 2023 Share Posted March 22, 2023 Every Phase happens in each player's turn, even if that player doesn't use/have anything to do in the turn. For example, the Psychic Phase happens for T'au/Necrons, but they just don't have any units capable of doing psychic stuff. Link to comment https://bolterandchainsword.com/topic/377976-heroic-intervention-without-charges/#findComment-5922521 Share on other sites More sharing options...
Xenith Posted March 22, 2023 Share Posted March 22, 2023 23 hours ago, yan said: His argument was that, because there where no charges, there was no charge phase. But thats then incorrect. Thanks for clearing this up! As charges can only occur in the charge phase, by their logic, there have been no charges, so there is no charge phase, so no one could ever declare a charge. Use that one next time he tries to charge. Link to comment https://bolterandchainsword.com/topic/377976-heroic-intervention-without-charges/#findComment-5922599 Share on other sites More sharing options...
