Looking to start emperors children going into 10th. Played in the early 2000s but haven't played since then. But not sure where to start with converting models to noise marines. What are you guys using in order to make these some marines and terminators look more noisy
Welcome to the Emperor's Children!
As for noise marines, are you having trouble sourcing the weapons, or are you looking to go a bit further and modify the model itself to make it more appropriate?
If its the weapons, at least in Canada resin versions are available through the GW webstore:
https://www.games-workshop.com/en-CA/Chaos-Space-Marines-Noise-Marine-Sonic-Weapons
https://www.games-workshop.com/en-CA/Chaos-Space-Marines-Noise-Marines-Upgrade-Pack
Or, the Forge World cacaphoni weapons also work, though are harder to source on my side of the pond:
https://www.forgeworld.co.uk/en-CA/Emperor-s-Children-Legion-Kakophoni
If it is the later, there are a number of ways to do so.  For mine, I have given them capes from the old Warhammer/Sigmar Chaos Warriors boxed set - you can see my tutorial for doing so here.  Also works with the newer chaos space marine kit, with the added advantage of not needing to cut the legs - here is an unpainted and painted example.  Not sure how it will work with the new Chaos Warriors box, though - I've bought one, but haven't tried it yet (certainly its of less value, there being fewer models as well as some with shields on their backs that you might not want to use).
This thread may also be useful - some awesome models in there converted by members here.
Edited by Dr_Ruminahui
Register a new account
Sign in
