NemoVonUtopia Posted April 25, 2023 Share Posted April 25, 2023 I am considering trying an abhuman muster militia list using my beastmen models that are on 32mm bases. Is there a significant game mechanic effect for using 32mm instead of 25mm? Since the abhuman muster gives bulky(2) so it seem justified to use 32mm but I wan to make sure I am not overlooking anything. Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/ Share on other sites More sharing options...
Noserenda Posted April 25, 2023 Share Posted April 25, 2023 There arent fixed base sizes in the game afaik, other than use what the model came on, so i cant see you running into issues. Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/#findComment-5939504 Share on other sites More sharing options...
SkimaskMohawk Posted April 26, 2023 Share Posted April 26, 2023 I'd bet money they added those rules to take advantage of the beastmen models for kill team. Using them as a guide for basing and model size is pretty safe imo. The only real game mechanic the bigger bases influences is that it's harder to get multiple models in base contact, which matters the most for Hammer of Wrath (another bonus you get). So it only really penalizes you, making it a safe option to go up in base size. Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/#findComment-5939648 Share on other sites More sharing options...
Fallen11 Posted April 26, 2023 Share Posted April 26, 2023 6 hours ago, SkimaskMohawk said: The only real game mechanic the bigger bases influences is that it's harder to get multiple models in base contact, which matters the most for Hammer of Wrath (another bonus you get). So it only really penalizes you, making it a safe option to go up in base size. Well, it's harder for blasts to cover more models compared to smaller bases. Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/#findComment-5939694 Share on other sites More sharing options...
Stitch5000 Posted April 26, 2023 Share Posted April 26, 2023 You;re taking a Militia list so accusations of modelling for advantage are pretty much unfounded (especially when it's something as straightforward as using the bases the models were supplied on). Petitioner's City, Noserenda and Brother Sutek 3 Back to top Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/#findComment-5939710 Share on other sites More sharing options...
Cactus Posted April 26, 2023 Share Posted April 26, 2023 3 hours ago, Fallen11 said: Well, it's harder for blasts to cover more models compared to smaller bases. Conversely, terrain may force them to bunch up more due to each model's larger footprint and be more vulnerable. In my experience the advantages and disadvantages are niche, marginal, situational, cut both ways and just not worth worrying about. Noserenda and Petitioner's City 2 Back to top Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/#findComment-5939726 Share on other sites More sharing options...
Cleon Posted April 26, 2023 Share Posted April 26, 2023 I guess I'd say just be aware of what you are doing and play appropriately - if you think your bases might be a bit big, don't use them to spread your units about to the absolute maximum to abuse board control, if you think your bases might be a bit small don't bunch your units up into tiny hidden clumps. Cactus 1 Back to top Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/#findComment-5939729 Share on other sites More sharing options...
SkimaskMohawk Posted April 26, 2023 Share Posted April 26, 2023 3 hours ago, Fallen11 said: Well, it's harder for blasts to cover more models compared to smaller bases. Yea ofc, as well as losing a bit of range/targetability due to the smaller nature of the bases; I mainly read it in terms of what special rules interact with the models. And having said that, going from 25mm to 33mm will give the unit a larger footprint, and make it easier for Tyrant to be applied to them. So maybe a slight buff. Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/#findComment-5939732 Share on other sites More sharing options...
Noserenda Posted April 26, 2023 Share Posted April 26, 2023 Harder to miss the unit with a scattering blast though, or squeeze them out of LOS. Ultimately though, if someone is seriously quibbling about a reasonable (Like, supplied with) base size for chaff units thats probably a red flag :D Gorgoff 1 Back to top Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/#findComment-5939737 Share on other sites More sharing options...
Petitioner's City Posted May 2, 2023 Share Posted May 2, 2023 I must admit I tend to go with what base feels right for a model - in part from size of model, or class of fighter. Like I tend to put characters on bigger bases, as that feels appropriate to their role, even if the models generally come on smaller ones. But others won't do that, which is fair. But anyway if your militia are more modern scale models, why not use 32mm? Anyone who argues about it is being a bit silly I think with militia, however, a big thing that will play a role is movement trays - you'll probably need them? Link to comment https://bolterandchainsword.com/topic/378434-militia-infantry-on-32mm-bases/#findComment-5942658 Share on other sites More sharing options...
