Agramar_The_Luna_Wolf Posted April 27, 2023 Share Posted April 27, 2023 Hello, I have a doubt. I lack if paired lighting claws for my SoH in power armor, but I have several Cataphractii lighting claws spare and, I was thinking, to use the in power armored miniatures. The problem is the design. I don't know how to transform them, or where to cut. Anyone tried to do the same before? It is possible to "recycle" this bits? And how? Any help, tutorial,... Is more than welcome. Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/ Share on other sites More sharing options...
Guest Posted April 27, 2023 Share Posted April 27, 2023 (edited) Not fully the answer you want but I did this with Tart ones. I think it works. Edited April 27, 2023 by Brother Captain Arkley Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/#findComment-5940254 Share on other sites More sharing options...
Grotsmasha Posted April 28, 2023 Share Posted April 28, 2023 I'm literally walking out the door for work, BUT, these are the type of questions I LOVE. When I get home, I'll dig some of my spares out, see if I can make it work, take pictures and show my results. That'll be 10hrs or so from now. Firedrake Cordova and Agramar_The_Luna_Wolf 2 Back to top Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/#findComment-5940286 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted April 28, 2023 Author Share Posted April 28, 2023 8 hours ago, Brother Captain Arkley said: Not fully the answer you want but I did this with Tart ones. I think it works. Tartaros' TLC are far more easy to transform. But sadly in my case, mine are all in good use... Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/#findComment-5940365 Share on other sites More sharing options...
Firedrake Cordova Posted April 28, 2023 Share Posted April 28, 2023 9 hours ago, AGRAMAR said: Tartaros' TLC are far more easy to transform. But sadly in my case, mine are all in good use... If you don't mind additional expenditure, Bitz Box have the lightning claws up for 50p per claw (and have ~30 pairs available), and 60p per powerfist arm (~10 available), which works out to about £2.20/marine - I don't know if the ease of conversion is worth it? Agramar_The_Luna_Wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/#findComment-5940547 Share on other sites More sharing options...
Grotsmasha Posted April 29, 2023 Share Posted April 29, 2023 Sorry, long night last night, am sitting down now to play with some Cataphractii arms.... Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/#findComment-5940748 Share on other sites More sharing options...
Solution Grotsmasha Posted April 29, 2023 Solution Share Posted April 29, 2023 So my first thought was just to trim the shoulder down to accommodate at Terminator / Gravis shoulder pad, which worked, but only ofr the straighter arms and not the really bent ones, So my second thought was to more aggressively trim the top of the Cataphractii arm and just add a new shoulder, which works for both bent and straight arms, I tried with both power armour arms/pads, and terminator arms/pads, The trick ended up being to glue the arm into the shoulder pad and then once set, trim the arm off level with the bottom lip of the shoulder pad, and finally some pics with them poster-puttyied to an Art Scale marine, Hopefully you find this helpful. Cheers, Jono Dr_Ruminahui, Agramar_The_Luna_Wolf, space wolf and 3 others 2 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/#findComment-5940759 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted April 29, 2023 Author Share Posted April 29, 2023 Thank you so much. Yes, is really helpful! Grotsmasha 1 Back to top Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/#findComment-5941339 Share on other sites More sharing options...
space wolf Posted May 13, 2023 Share Posted May 13, 2023 (edited) I'd imagine if you had Powerfist arms for primaris, you just cut the power claws right behind thumb, separating the front part of the hand from the rest of the hand. Then do the same to the powerfist and glue on the power claw hand. May need to do some gap filling depending on thr neatness of the cut. Edited May 13, 2023 by space wolf Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/#findComment-5947301 Share on other sites More sharing options...
gideon stargreave Posted May 13, 2023 Share Posted May 13, 2023 I use cataphracti stuff for my marines all the time, but beware, not all arms are made equal. Some are much much longer than others, and will need attaching to primaris biceps. I’ll have a go when i get home Link to comment https://bolterandchainsword.com/topic/378462-cataphractii-lighting-claws-in-power-armors/#findComment-5947312 Share on other sites More sharing options...
