Hellven Posted May 9, 2023 Share Posted May 9, 2023 Hi! Order of Lacyraemarta grant Incorruptible Flesh rule: "Any Hits allocated to a model with this special rule, or any model with the Infantry Unit Type in a unit they join, with the Rending (X), Poisoned (X) or Fleshbane special rules only affect that model on a D6 roll of a 6 instead of their usual effect." Fleshbane rule: "If a model has this special rule, or is attacking with a Melee weapon that has this special rule, they always Wound on a 2+ in close combat." So, if unit with 4S and fleshbane hit unit with 4T and Incorruptible Flesh rule, it wound only on 6 or 4+? Link to comment https://bolterandchainsword.com/topic/378591-lacyraemarta-incorruptible-flesh-and-fleshbane/ Share on other sites More sharing options...
Kain Mor Posted December 13, 2023 Share Posted December 13, 2023 By my interpretation you would still wound as normal via the chart, it just changes the activation parameter of the special rule to be 6+; but doesn’t effect the standard wound process. Agramar_The_Luna_Wolf, General Zodd and Unknown Legionnaire 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/378591-lacyraemarta-incorruptible-flesh-and-fleshbane/#findComment-6009299 Share on other sites More sharing options...
Unknown Legionnaire Posted December 15, 2023 Share Posted December 15, 2023 Nope. It wounds on sixes. Fleshbane has nothing to do with double strength, activation number or other shenanigans. There's also no such thing as 'Fleshbane (X)' It's simly a rule that states that you cause a wound on a 2+ Which Lacyraemarta effectivaly and beautifuly changes to a measely 6+ Link to comment https://bolterandchainsword.com/topic/378591-lacyraemarta-incorruptible-flesh-and-fleshbane/#findComment-6009676 Share on other sites More sharing options...
