Doctor Perils Posted May 9, 2023 Share Posted May 9, 2023 (edited) When responding to a long post, I often like to cut it up into bite-sized portions in order to be more legible. Unfortunately when on mobile, the quote tags are complicated to copy and paste, which makes editing such a post really complicated compared to what it should be. Would some kind of UI system for cutting quotes into portions be feasible? Or at least an accessible option to view the BCCode tags on mobile (such a thing was possible on the old website IIRC) Edited May 9, 2023 by Doctor Perils Link to comment https://bolterandchainsword.com/topic/378592-quote-snipping/ Share on other sites More sharing options...
Mazer Rackham Posted May 9, 2023 Share Posted May 9, 2023 Don't know if it works on mobiles, so apologies if I am asking your maternal grandmother to suck eggs, but if you quote the full block and hit the return key somewhere inside the quote where you want to reply... 6 minutes ago, Doctor Perils said: When responding to a long post, I often like to cut it up into bite-sized portions in order to be more legible. Unfortunately when on mobile, the quote tags are complicated to copy and paste, which makes editing such a post really complicated compared to what it should be. <<< Hit the return key here >>> Would some kind of UI system for cutting quotes into portions be feasible? Or at least an accessible option to view the BCCode tags on mobile (such a thing was possible on the old website IIRC) And... 8 minutes ago, Doctor Perils said: When responding to a long post, I often like to cut it up into bite-sized portions in order to be more legible. Unfortunately when on mobile, the quote tags are complicated to copy and paste, which makes editing such a post really complicated compared to what it should be. Tadaa! 8 minutes ago, Doctor Perils said: Would some kind of UI system for cutting quotes into portions be feasible? Or at least an accessible option to view the BCCode tags on mobile (such a thing was possible on the old website IIRC) It will split the quote up for you. Similarly, you can make a line break by using the return key, then hitting the return key again, and it will split it normally. Does that help/make any sense? Apologies if I have misunderstood! Brother Tyler, Firedrake Cordova and Doctor Perils 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/378592-quote-snipping/#findComment-5945447 Share on other sites More sharing options...
Doctor Perils Posted May 9, 2023 Author Share Posted May 9, 2023 (edited) That _does_ seem to work, many thanks I don't know if there's a way to mark an answer as "accepted" if the original post wasn't marked as a question Edited May 9, 2023 by Doctor Perils Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/378592-quote-snipping/#findComment-5945678 Share on other sites More sharing options...
Brother Tyler Posted May 10, 2023 Share Posted May 10, 2023 On 5/9/2023 at 1:04 PM, Doctor Perils said: That _does_ seem to work, many thanks I don't know if there's a way to mark an answer as "accepted" if the original post wasn't marked as a question The Suggestion Box forum doesn't have that feature enabled because the "answers" are usually given by an administrator and we shouldn't be rewarded for those kinds of things. Doctor Perils and Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378592-quote-snipping/#findComment-5946276 Share on other sites More sharing options...
