Kaiju Soze Posted May 17, 2023 Share Posted May 17, 2023 1 hour ago, Daimyo-Phaeron Lenoch said: STEALTH is -1 to hit, dunno if we’ve seen that yet. I know this was suspected, I don't know if it was confirmed. Daimyo-Phaeron Lenoch 1 Back to top Link to comment Share on other sites More sharing options...
Frogian Posted May 17, 2023 Share Posted May 17, 2023 38 minutes ago, Doobles88 said: Still reading through this in detail, but one thing I'm slightly disappointed that they've not pulled across from AoS's rules in the referencing. Each section is numbered specifically (1.1, 1.2......3.5.2 etc) so it's easy to cross reference rules rather than using page numbers. Also means that when you need to point someone to a rule it doesn't matter if they're using the big book, app, mission pack etc. it's the same reference number and place regardless. Minor gripe, but still a shame. The odd thing is I'm sure they said they were going to do that. Also annoying that all the weapon abilities aren't in alphabetical order. MithrilForge, Khornestar and Rune Priest Jbickb 3 Back to top Link to comment Share on other sites More sharing options...
Doobles57 Posted May 17, 2023 Share Posted May 17, 2023 Just noticed Overwatch is in the shooting and charge phase. And with any unit within 24" not just the target of the charge. Interesting. The core strats as a whole seem quite good and cover a lot of bases. Means the limited selection in detachments isn't as big a restriction as it might have seemed. Saving throws added to the list of can't be modified more than +1 (that is new right?). Fight First rule seems to clarify that phrase. And that charging gives the unit Fight First. Interestingly no mention of Fights Last so no more working out how those two things interact! Link to comment Share on other sites More sharing options...
WrathOfTheLion Posted May 17, 2023 Share Posted May 17, 2023 (edited) 7 minutes ago, Frogian said: The odd thing is I'm sure they said they were going to do that. Also annoying that all the weapon abilities aren't in alphabetical order. They said they were going to use page numbers, but they would be 1, 2, 3, etc. in all publications, normalizing the page numbers. So page 4 would be page 4, whether in the Leviathan book, a pdf document, the core rules in the starter box or any other of their publications. Edited May 17, 2023 by WrathOfTheLion Aarik 1 Back to top Link to comment Share on other sites More sharing options...
TrawlingCleaner Posted May 17, 2023 Author Share Posted May 17, 2023 2 minutes ago, Frogian said: The odd thing is I'm sure they said they were going to do that. Also annoying that all the weapon abilities aren't in alphabetical order. It's likely that this isn't a finalised version between these two and the Example datasheet having 9th ed terms (Angels of Death and Core), my guess is that it's a playtest version or one given to staff to train them so may subject to change Verbal Underbelly, Khornestar and Harleqvin 1 1 1 Back to top Link to comment Share on other sites More sharing options...
Kaiju Soze Posted May 17, 2023 Share Posted May 17, 2023 11 minutes ago, Doobles88 said: Saving throws added to the list of can't be modified more than +1 (that is new right?). Pretty sure that's new. Link to comment Share on other sites More sharing options...
Vassakov Posted May 17, 2023 Share Posted May 17, 2023 I really like a lot of this, actually. A lot of it seems like "tidying up" or consolidating lots of similar effects into a number of consistent rules, and Overwatch is a good example of this. It essentially smooshes Overwatch and the plethora of "Auspex Scan" effects into one strategem, making it more versatile and more consistent. It also gets rid of the annoyance of half the strategems doing slightly different things which was just a complete pain, I.e. for Marines it's any infantry, for Aelderi it's a unit near a Farseer, for Votann it's any unit and they get a special bonus and for Necrons you have to have a specific unit that's also in reserve, and room to place them, and also Mercury must be in retrograde. Or something. Yes I know that's not 100% accurate, I'm exaggerating for comedic effect. MithrilForge, Oxydo and QuarterPounder 3 Back to top Link to comment Share on other sites More sharing options...
AenarIT Posted May 17, 2023 Share Posted May 17, 2023 23 minutes ago, TrawlingCleaner said: It's likely that this isn't a finalised version between these two and the Example datasheet having 9th ed terms (Angels of Death and Core), my guess is that it's a playtest version or one given to staff to train them so may subject to change Could be, but I'm more likely to think those are genuine mistakes and this is the final version. It looks like a real rulebook, while playtest versions tend to be digital files. Harleqvin and Khornestar 2 Back to top Link to comment Share on other sites More sharing options...
Cleon Posted May 17, 2023 Share Posted May 17, 2023 Did I read overwatch right? Say you manage to get a unit with a lot of torrent (say rubrics with warp flamers) next to an enemy unit. You can now trigger overwatch in the move phase if they move at all AND potentially in the assault phase if they want to charge you (or anyone close to you). That's potentially a lot of hits. Blight1, Cruor Vault, Iron Father Ferrum and 1 other 3 1 Back to top Link to comment Share on other sites More sharing options...
Tokugawa Posted May 17, 2023 Share Posted May 17, 2023 Vehicles/monsters under half wounds also need to take battle shock test. This is another form of "bracket". VengefulJan 1 Back to top Link to comment Share on other sites More sharing options...
Marshal Reinhard Posted May 17, 2023 Share Posted May 17, 2023 (edited) 9 hours ago, Tokugawa said: The sample datasheet is not 10th, maybe for confidentiality reason. This is a weird fact. There seems to be rules references on the example sheet that supposedly aren't relevant in 10th. Which brings the question, why have an outdated data sheet (even if it is a big obvious example sheet, with example weapons etc listed on it) in the BRB? I'd have thought such examples would be fully consistant with the edition they're printed in. Lends credibility to the idea that this might be an earlier play tester version, or maybe a version of the rules that were available at the 10th box reveal event? If so, there might be differences to these and the final rules. Or this could just be me trying to read way way way too far into this, but it just strikes me as odd. Just as having "an example sheet" with clearly placeholder names is kinda weird. Typically I would expect a finished product to have the tactical squad sheet exactly as it is if I were looking at a finished example, not randomly changed with references to old rules. Edited May 17, 2023 by Marshal Reinhard Oxydo and Interrogator Stobz 2 Back to top Link to comment Share on other sites More sharing options...
Borbarad Posted May 17, 2023 Share Posted May 17, 2023 Tank Shock!!! SteveAntilles, Runefyre, Verbal Underbelly and 1 other 3 1 Back to top Link to comment Share on other sites More sharing options...
Vassakov Posted May 17, 2023 Share Posted May 17, 2023 2 minutes ago, Cleon said: Did I read overwatch right? Say you manage to get a unit with a lot of torrent (say rubrics with warp flamers) next to an enemy unit. You can now trigger overwatch in the move phase if they move at all AND potentially in the assault phase if they want to charge you (or anyone close to you). That's potentially a lot of hits. No, because you can only use Overwatch once per turn. Final line of the "Restrictions" paragraph. Link to comment Share on other sites More sharing options...
Ming the Merciless Posted May 17, 2023 Share Posted May 17, 2023 3 minutes ago, Cleon said: Did I read overwatch right? Say you manage to get a unit with a lot of torrent (say rubrics with warp flamers) next to an enemy unit. You can now trigger overwatch in the move phase if they move at all AND potentially in the assault phase if they want to charge you (or anyone close to you). That's potentially a lot of hits. See Restrictions at the bottom, Overwatch is used once per turn. Link to comment Share on other sites More sharing options...
ZeroWolf Posted May 17, 2023 Share Posted May 17, 2023 So, who's expecting the proper free rules to drop sooner rather than later? VengefulJan and Khornestar 2 Back to top Link to comment Share on other sites More sharing options...
Tokugawa Posted May 17, 2023 Share Posted May 17, 2023 "Engagement range" is quoted many times, but how long is it? Does this leak clearly defined it 1 inch? VengefulJan and Khornestar 2 Back to top Link to comment Share on other sites More sharing options...
Dried Posted May 17, 2023 Share Posted May 17, 2023 I can't find the rules for the "psychic" weapon ability. Is it there? Link to comment Share on other sites More sharing options...
Frogian Posted May 17, 2023 Share Posted May 17, 2023 6 minutes ago, Dried said: I can't find the rules for the "psychic" weapon ability. Is it there? No - looks like there is a left hand page missing (honestly who ever took these photos - why didn't they get every page from core rules???) Khornestar 1 Back to top Link to comment Share on other sites More sharing options...
TrawlingCleaner Posted May 17, 2023 Author Share Posted May 17, 2023 4 minutes ago, Dried said: I can't find the rules for the "psychic" weapon ability. Is it there? From what we have, this is it: It doesn't need to be explained more than this mind you as damaging powers are ranged attacks and other powers are now just abilites that activate on dice rolls. It being tagged as a [Psychic] keyword means that things like Sister of Silence, Strats like Scorn of Sorcery etc can interact with it as there's not an explicit Cast or Deny roll Spyros, VengefulJan and Khornestar 1 2 Back to top Link to comment Share on other sites More sharing options...
Chapter Master Valrak Posted May 17, 2023 Share Posted May 17, 2023 They can’t blame this one on me Loquille, Dark Shepherd, Silas7 and 24 others 2 24 1 Back to top Link to comment Share on other sites More sharing options...
WARMASTER_ Posted May 17, 2023 Share Posted May 17, 2023 Might be the wrong crowd but I’m loving the new filler art!! Super grim dark Ammonius, tinpact and VengefulJan 3 Back to top Link to comment Share on other sites More sharing options...
Karhedron Posted May 17, 2023 Share Posted May 17, 2023 2 hours ago, tzeentch9 said: So necrons etc bring back their dead before battleshock phase. Interesting Surprising but very welcome to Overlords everywhere. VengefulJan and MithrilForge 1 1 Back to top Link to comment Share on other sites More sharing options...
Dried Posted May 17, 2023 Share Posted May 17, 2023 I don't understand why fly is still a keyword and not a core ability. Aramis K 1 Back to top Link to comment Share on other sites More sharing options...
Tokugawa Posted May 17, 2023 Share Posted May 17, 2023 14 minutes ago, Dried said: I don't understand why fly is still a keyword and not a core ability. Because there would be abilities about "when targeting fly unit…"? Link to comment Share on other sites More sharing options...
Emperor Ming Posted May 17, 2023 Share Posted May 17, 2023 So is the 25% strategic reserves apply to reserves, if not what the reserves limit, I'm not seeing it Link to comment Share on other sites More sharing options...
