Theduke08 Posted May 23, 2023 Share Posted May 23, 2023 While the sky is falling for most Death Guard players I still have a smile on my face with a paintbrush in my hand. The idea behind the Order of the Fly is that they all despise Typhus and were all in some way negatively(more so than normal) affected by the transition to Nurgle. These legionaries were reluctant converts that were either on the Terminus Est or exposed to Typhus' corruption shortly afterward. Seeing no other way forward they have accepted their rotted fate. Due to this they all have donned white helms, not in hommage to Typhus but in mockery. Grotsmasha, Firedrake Cordova, Alex_Art_Workshop and 10 others 9 4 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/ Share on other sites More sharing options...
Firedrake Cordova Posted May 23, 2023 Share Posted May 23, 2023 I really like the weathering - whilst it would be wrong to call it "subtle", it's quite reserved, doesn't take over, and is pretty realistic. I think it works well with the flatter/more realistic tones of the model (i.e. not the 'Eavy Metal edge-highlight style, which is a bit cartoony even though I like it!). Mithrilforge and Theduke08 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5950538 Share on other sites More sharing options...
Theduke08 Posted May 23, 2023 Author Share Posted May 23, 2023 7 minutes ago, Firedrake Cordova said: I really like the weathering - whilst it would be wrong to call it "subtle", it's quite reserved, doesn't take over, and is pretty realistic. I think it works well with the flatter/more realistic tones of the model (i.e. not the 'Eavy Metal edge-highlight style, which is a bit cartoony even though I like it!). Thanks, dude! I love messing with all the weathering effects. Oil paints and enamel paints are fun to work with. Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5950542 Share on other sites More sharing options...
Mithrilforge Posted May 24, 2023 Share Posted May 24, 2023 This Looks great!, I'll be keeping an eye on this thread for sure, I love your lore of hating Typhus (I'd be in your camp on that matter also) and i do love your Subtle but super effective weathering 2x Cheers, M. Theduke08 1 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5950685 Share on other sites More sharing options...
Theduke08 Posted May 24, 2023 Author Share Posted May 24, 2023 I was planning on putting together a couple bolter or blade plague marines but couldn't resist painting up the Champion. This gut plate armor is quite fun to work with. Here is the pre-weathering WIP. Thanks for looking. Grotsmasha, DaBoiKyknos, Firedrake Cordova and 2 others 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5950930 Share on other sites More sharing options...
Firedrake Cordova Posted May 25, 2023 Share Posted May 25, 2023 Looking good. I like that you've put damage into the area covered by the Nurgle fly (which I assume is a transfer rather than freehand?) I really helps integrate it into the model (all too often we paint models with battle damage and weathering ... except for the transfers which went on after, and it doesn't look right). Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5951036 Share on other sites More sharing options...
apologist Posted May 25, 2023 Share Posted May 25, 2023 Very nice idea – and I like your painting style a lot. It's beautifully subtle and desaturated; distinctive and effective. It also complements the converting and kitbashing you've done to take off some of the more exaggerated and extreme mutations. Is it coincidence that all so far have used the helmets with a central, balanced hole or set of holes? Might be nice to follow that through as another visual theme. Looking forward to seeing where you take this project. Theduke08 and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5951040 Share on other sites More sharing options...
Theduke08 Posted May 25, 2023 Author Share Posted May 25, 2023 7 hours ago, Firedrake Cordova said: Looking good. I like that you've put damage into the area covered by the Nurgle fly (which I assume is a transfer rather than freehand?) I really helps integrate it into the model (all too often we paint models with battle damage and weathering ... except for the transfers which went on after, and it doesn't look right). I always try to do my transfers prior to any weathering. It just seems out of place if it's not integrated properly. Nurgle/DeathGuard and transfers kind of fall into a weird place in my mind. I feel like they should have some markings but depending on how corrupt they are they might be worn away or fully covered. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5951133 Share on other sites More sharing options...
Theduke08 Posted May 25, 2023 Author Share Posted May 25, 2023 6 hours ago, apologist said: Very nice idea – and I like your painting style a lot. It's beautifully subtle and desaturated; distinctive and effective. It also complements the converting and kitbashing you've done to take off some of the more exaggerated and extreme mutations. Is it coincidence that all so far have used the helmets with a central, balanced hole or set of holes? Might be nice to follow that through as another visual theme. Looking forward to seeing where you take this project. @apologistI typically try to match the helmets throughout the entire squad for plague marines and have some symmetry within the squad. I like the gas mask-type helmets the best but I've used nearly all of the ones I own. I try to keep the weathering toned down and attempt to get a little bit of realism. The original plague marine sculpts are super busy and if you don't have a simple method for painting them you'd be lucky to finish a few marines and a month. Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5951135 Share on other sites More sharing options...
Rusted Boltgun Posted May 25, 2023 Share Posted May 25, 2023 Really cool to see the 'before weathering' shot, looking forward to comparing it with the 'after'. A much brighter green in the 'before' photo than I was expecting. I'm trying out some DG myself (picking up where I left off in the early '90s) so will be following with interest. Theduke08 1 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5951208 Share on other sites More sharing options...
Theduke08 Posted May 25, 2023 Author Share Posted May 25, 2023 The Champion is finished. Not 100% happy with the plasma pistol but it will do. Starting to come together nicely. Might work on a terminator next. Thanks for looking. Rusted Boltgun, Aarik, Grotsmasha and 6 others 7 2 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5951272 Share on other sites More sharing options...
Torbenos Posted May 27, 2023 Share Posted May 27, 2023 A brutal looking trio. I quite like the green and the weathering, to echo what's been said above. How do you play to abse them? Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5951758 Share on other sites More sharing options...
Theduke08 Posted May 30, 2023 Author Share Posted May 30, 2023 @Torbenos I'm not sure how ill base them to be honest. Maybe just something simple. I like to use simple texture paints with weathering powder over the top of them. Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5952540 Share on other sites More sharing options...
Urauloth Posted May 30, 2023 Share Posted May 30, 2023 Very nice! The white helms are a good spot colour and the weathering looks great. These seem quite a bit less "busy" with growths and tentacles and the like than DG models usually are - I assume that took you some time? Swapping the shoulder pads out for plain ones also makes a big difference to the silhouette. Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5952608 Share on other sites More sharing options...
Theduke08 Posted May 30, 2023 Author Share Posted May 30, 2023 @Urauloth the bodies are actually from Tortuga Bay. Everything else is from the Plague Marine kits. Pretty simple to put it all together. Im not a huge fan of how many tentacles and crazy mutations are on those kits. The shoulder pads are just the MK IV ones from the HH kits. Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5952629 Share on other sites More sharing options...
Pearson73 Posted June 1, 2023 Share Posted June 1, 2023 The pink plasma was a great choice, it looks great against the drab green and white. The white helmets are a nice touch too, and I agree regarding the level of tentacles and stuff on the GW base models, yours look much more how I imagine the plague marines to be. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5953157 Share on other sites More sharing options...
Theduke08 Posted June 1, 2023 Author Share Posted June 1, 2023 I've added 2 double plague knife marines to the unit. I made my own blades in a few places with plasticard and I feel like they came together nicely. Firedrake Cordova, andes, Dr_Ruminahui and 3 others 4 2 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5953432 Share on other sites More sharing options...
Pearson73 Posted June 1, 2023 Share Posted June 1, 2023 The new additions look cracking, the rust is really well done. Firedrake Cordova and Theduke08 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5953694 Share on other sites More sharing options...
Boc Posted June 2, 2023 Share Posted June 2, 2023 Positively revolting Firedrake Cordova and Theduke08 2 Back to top Link to comment https://bolterandchainsword.com/topic/378729-death-guard-order-of-the-fly/#findComment-5953920 Share on other sites More sharing options...
