Redsun Posted June 8, 2023 Share Posted June 8, 2023 I was tempted to get the Chaos Space Marine combat patrol box, but as they recently announced that some of the old space marine dreadnoughts were going to Legends, this kind of has me thinking that the current hellbrute model may also go that way as it's a similar scale? Do you think this is likely to get a new model? I may get it anyway and kitbash it with a redemptor dreadnought's legs, seems like that might be easy enough to do. (I only play casually so I'm not worried about 'tournament standard' as such) Link to comment https://bolterandchainsword.com/topic/378889-upscaled-hellbrute-possibility/ Share on other sites More sharing options...
TwinOcted Posted June 8, 2023 Share Posted June 8, 2023 It's pretty unlikely, to be honest. It's a relatively recent kit (younger than the Venerable Dreadnought), and I think it's pretty good. I'm a big fan of the fact it comes with every option on the sprue. I wouldn't say no to corrupted Redemptor chassis, though. 2 Back to top Link to comment https://bolterandchainsword.com/topic/378889-upscaled-hellbrute-possibility/#findComment-5956580 Share on other sites More sharing options...
Dr_Ruminahui Posted June 8, 2023 Share Posted June 8, 2023 (edited) I wouldn't take the legending of the old boxnaught as what might occur to the hellbrute, as it is kind of a special case. With the collapsing of the distinction between first born and primaris that appears to be occurring in 10th, and with variants of the retributor which duplicate the roles of most of the boxnaught variants, GW probably felt that it was redundant and didn't make any sense to keep around the old models that had been superseded by newer variants and that the space those took up (both in terms of shelf and with their datasheets) could be best used otherwise. Hellbrute isn't like that, as there isn't the same duplication as it is the only model we have in that role. Plus, as noted, it is relatively modern kit (at least compared to the boxnaughts) and it fits in well with the rest of the chaos range, even if it is a bit static. Edited June 8, 2023 by Dr_Ruminahui 3 Back to top Link to comment https://bolterandchainsword.com/topic/378889-upscaled-hellbrute-possibility/#findComment-5956830 Share on other sites More sharing options...
Iron Father Ferrum Posted June 8, 2023 Share Posted June 8, 2023 It's also in the Chaos Marine Combat Patrol, so it's not going to get pulled unless they release a new Combat Patrol. That's possible, but it's not likely to occur until our codex drops which was. . . what, early 2024 I think? So we probably have some time to kill anyway. Link to comment https://bolterandchainsword.com/topic/378889-upscaled-hellbrute-possibility/#findComment-5956896 Share on other sites More sharing options...
Tokugawa Posted June 8, 2023 Share Posted June 8, 2023 It is a "relatively" new model kit. There are still some ancient trash in CSM product range, which need to be replaced ASAP. There are also some plastic kits older than it and don't have quite a "modern" quality. So the priority of making a new hellbrute is very low, if any. Link to comment https://bolterandchainsword.com/topic/378889-upscaled-hellbrute-possibility/#findComment-5956906 Share on other sites More sharing options...
sitnam Posted June 9, 2023 Share Posted June 9, 2023 I wouldn't mind a beefier Helbrute (mostly so I have an excuse for a second) but I don't think it is likely with this cycle. My only hope is that the now discontinued Decimator gets a plastic refresh to become the Chaos Redemptor. Link to comment https://bolterandchainsword.com/topic/378889-upscaled-hellbrute-possibility/#findComment-5956938 Share on other sites More sharing options...
Urauloth Posted June 9, 2023 Share Posted June 9, 2023 Absolutely zero possibility I'm afraid. Only thing we might see is a new unit that's a bigger walker (there were rumours about this for a while a few years ago, don't know what happened to them). I'd love to see something on par with the primaris dreads. I guess we'll see. Link to comment https://bolterandchainsword.com/topic/378889-upscaled-hellbrute-possibility/#findComment-5956991 Share on other sites More sharing options...
Iron Father Ferrum Posted June 9, 2023 Share Posted June 9, 2023 You mean like the Fiends? Link to comment https://bolterandchainsword.com/topic/378889-upscaled-hellbrute-possibility/#findComment-5957428 Share on other sites More sharing options...
Lord Abaia Posted June 9, 2023 Share Posted June 9, 2023 Just give me an upscaled defiler! I need a giant enemy crab. 2 Back to top Link to comment https://bolterandchainsword.com/topic/378889-upscaled-hellbrute-possibility/#findComment-5957483 Share on other sites More sharing options...
